Old Jan 11, 2012, 03:18 PM
United States, IL, Edwardsville
Joined Dec 2011
Build Update.
Duct and mid-hatch completed and glassed. Nose section framed. Trying to figure out how to approach the front hatch. Vertical fin and all control surfaces cut and shaped. Will work on installing the nose gear and cleaning up the main retracts next week. After all items installed there will be a sanding and one final coat of Polycrylic prior to paint. Will hopefully hit the 1 1/2 lb weight target.
flyingfitz737 is offline Find More Posts by flyingfitz737
Old Jan 23, 2012, 02:08 PM
Joined Dec 2011
Name: 2012-01-23 14.03.13.jpg
Description:
Progress. Way too slow, but progress.
Old Jan 23, 2012, 10:35 PM
Current project: Electrolyte
pdawg's Avatar
SoCal
Joined Apr 2004
Looking great! Very cool how you have taken this old school plan and replaced the balsa with the more modern and lighter depron!
pdawg is offline Find More Posts by pdawg
Old Jan 24, 2012, 01:49 PM
Joined Dec 2011
Thanks. It has been a great project but taking longer to complete than I planned. Learning a lot. I havent scratch built in probably 20 years! I would definately tweak the design a little if I was to do it again. I could save a little more weight and streamline the build.
Old Jan 31, 2012, 10:17 PM
Joined Dec 2011
I am going to see how it flies before I go much farther on any details. Maiden next week. It will have elevons and canard for flight controls. No landing gear. No paint. With a 2200 battery it will be right at the 1 1/2 lb weight. My smaller batteries are not a high enough c rating to support the anticipated load. If it flies ok I will continue with the details.
Name: 2012-01-31 21.17.16.jpg
Description:
Name: 2012-01-31 21.18.14.jpg
Description:
Old Jan 31, 2012, 10:38 PM
Janusz Jawien's Avatar
Los Angeles Van Nuys, California, United States
Joined Apr 2002
I wonder if just going with elevons as controls would be a better option.
Canars could be tricky at least at maiden.....
Wishing you best luck!
Janusz
Janusz Jawien is offline Find More Posts by Janusz Jawien
Old Jan 31, 2012, 11:19 PM
Joined Dec 2011
I thought about that too... I think I will put the canard on a mix switch so i can turn it on if it survives the launch Thanks for the input.
Old Feb 02, 2012, 06:09 AM
USA
Joined Apr 2007
launch
II found out to under hand launch it's a lot safer. Read up on it
space 1 is offline Find More Posts by space 1
Old Feb 02, 2012, 06:21 AM
USA
Joined Apr 2007
I see you went to prop in duct. what prop & KV motor
Old Feb 02, 2012, 09:14 AM
Joined Dec 2011
Medusa 3400 kv on 3s. Prop is a 4 in apc. Pitch is either 4.1 or 4.2. Will load check the motor and try to pull 30 amps or so. If this prop falls short I have a 4.75 x4.75 I will trim down to 4. Will try to load check on monday. The local shop is out of bullet connectors right now.
Old Feb 02, 2012, 02:00 PM
USA
Joined Apr 2007
I think better to use cut down 9x6 three blade prop or similar. Lot's three blade EDF's out there. I got three 64mm 3 blade fan's dwr 16amp. on 3s- 1600ma. PS try find 4 blade prop
Old Feb 02, 2012, 02:17 PM
Joined Apr 2002
IMHO if you will use elevons you should keep canards 0-0 and have some reflex
on elevons - so your wing will act as a flying wing.....this way you will have more chance for successful maiden. You will start to add canards to the equation later when you will feel confortable with flying wing.
Just a suggestion....
Oh, one more point - glue 220 grid sandpaper strips in areas where you will grip the fuse for
under hand lounch - this way you will have much better control over the model during this critical moments.
Old Feb 02, 2012, 04:47 PM
Joined Dec 2011
Great stuff. Keep it coming! All advice is appreciated. Canard will be locked to zero for maiden and all prop options will be explored once power is to the motor.
Old Feb 02, 2012, 05:09 PM
Capt. Z
falcon5's Avatar
Tonopah, Nevada
Joined Dec 2004
Looking great Fitz!!!
falcon5 is offline Find More Posts by falcon5
Old Feb 02, 2012, 05:12 PM
Joined Dec 2011
Thanks. I have the family on a ski trip right now and am trying not to think about this build! Will hit it hard when I get back.
Discussion AJ-37 Viggen Sture Smidt Foamy EDFs 5 Dec 13, 2011 02:37 AM
Discussion SAAB Viggen MIT KID Micro EDF Jets and Power Systems 7 Nov 26, 2011 08:16 AM
For Sale Ziroli F4U-1 Corsair RTF kksejwilson Aircraft - Fuel - Airplanes (FS/W) 7 Nov 02, 2011 01:07 PM
Off Site ~Closed~ WINDSHEAR II Aircraft - Fuel - Airplanes (FS/W) 0 Oct 28, 2011 10:14 PM
Discussion Electric Motor for a Ziroli Stuka Greybranch Electric Warbirds 3 Sep 17, 2011 09:20 AM
