Old Dec 30, 2011, 04:28 PM
sts41 is offline
Find More Posts by sts41
Canada, ON, Stouffville
Joined Nov 2011
Help!
Setting the throw on the elevator
Hi All....
I need help with what is probably a simple thing.....But I don't see the solution.
I got a Nexstar EP, and I am trying to adjust the elevator throw. Here is the issue....
I turn on the transmitter and receiver and the servo goes to center. The Arm looks like it is perpendicular and centered on the servo. I then adjust the clevise so that the elevator is set to the center per the instructions.
Now the throw should be even...1/2" up and Down. But I am getting 1/4" up and about 3/4" down. So more throw down than up. It looks like the servo is moving the same amount in both directions...but this does not translate into even amounts of throw at the elevator.
DR is not set and neither is Expo...They should not have any effect.
Changing the EPA changes both up and down equally....
Any Idea's what I am doing wrong.
Thanks Steve
sts41 is offline Find More Posts by sts41
Old Dec 30, 2011, 06:55 PM
wolfewinde is offline
Find More Posts by wolfewinde
My Co-Pilots Rock!!
wolfewinde's Avatar
United States, FL, Clearwater
Joined May 2011
See if the servo is moving when you give it up - that would push against the servo, down would pull. And make sure the servo arm is centered in the neutral position with the TX on
Wolfe
wolfewinde is offline Find More Posts by wolfewinde
Old Dec 30, 2011, 08:17 PM
Wintr is offline
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
Perpendicular to what, exactly? It should be at 90* to the control rod, not to the body of the servo.
Wintr is offline Find More Posts by Wintr
Old Dec 30, 2011, 08:30 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
The angle between the servo arm and the servo case has no effect on anything. To get equal throw in each direction the servo arm needs to be perpendicular to the pushrod regardless of the arm's angular relationship with the servo case. Also the pushrod should be perpendicular to a line drawn to the elevator hinge line where the pushrod connects to the elevator control horn.
Are you sure about that? It would be very unusual. On most transmitters there is a separate EPA adjustment for each direction of travel on a given servo.
Another thing to check is to make sure the pushrod is not flexing with up elevator.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Dec 30, 2011, 11:41 PM
immelguy is offline
Find More Posts by immelguy
immelguy's Avatar
Joined Jan 2011
Originally Posted by Lnagel View Post
Another thing to check is to make sure the pushrod is not flexing with up elevator.Larry
Interesting comment, reminded me of something that happened to a friend many moons ago. His real life ultralight crashed on maiden (he was okay) because all adjustments were made from a static position, once in the air there seemed to be way too much slop in the controls with speed/air resistance.
immelguy is offline Find More Posts by immelguy
Old Dec 31, 2011, 01:05 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
A picture always helps.
Look at the elevator horn push rod hole to hinge angle, the servo arm need to be roughly the same.
eflightray is offline Find More Posts by eflightray
Old Dec 31, 2011, 06:43 PM
sts41 is offline
Joined Nov 2011
Thanks all...I will try a few things once the hangover is OVER
I also had a few idea's on what to check...mainly the distance the rod is traveling...should be easy enough with a marker and some calipers...Check it connected and un connected to the horn...I will also make sure the horn was properly attached at the factory.
Happy New Year to all....
Steve
Old Dec 31, 2011, 07:26 PM
alibongo is offline
Find More Posts by alibongo
alibongo's Avatar
United Kingdom, England, Dorset
Joined Apr 2010
Larry
That can't be right, surely? Imagine the servo arm has been pressed on almost inline with the servo,pointing forward to the nose.While the servo arm will move the same number of degrees each way if unattached,when connected to the pushrod the backwards movement will move the pushrod a considerable distance, but forward movement will not move the pushrod at all, it will just produce binding and stall the servo.this is an extreme example, but will translate whenever the arm is not at 90 degrees to the servo body.If I need excessive trim, I adjust the clevis and recentre the arm.Am I missing something?
alibongo is offline Find More Posts by alibongo
Old Dec 31, 2011, 10:53 PM
Lnagel is offline
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Yes, you are missing the part where the pushrod is perpendicular to the servo horn. It will not be in your scenario.
Larry
Old Jan 03, 2012, 09:51 AM
sts41 is offline
Joined Nov 2011
Ok...after re reading the manual for the Radio...there is indeed a way to change both of the throws independently...It just wasn't very well explained in the manual.
I now have everything set to the manufacturese recommended settings, and I Thank everyone for the help.
Steve
Old Jan 03, 2012, 10:02 AM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Think you missed the point ... lnangel is 100% correct - servo arm should be perpendicular to CONTROL ROD / LINK to surface to get full proper movement.
Centre servo ... centre surface .... then place arm on servo with arm at 90 deg's to rod / link. Servo doesn't care what angle arm is as long as SERVO is centred at centre surface ... it then travels both ways without problem ...
I'm having trouble geometrically imagining your example ...
solentlife is offline Find More Posts by solentlife
Help! setting sail throw Wass Sailboats 3 Jul 10, 2011 02:49 PM
Elevator throw mod for crap AM radios. DennisRB Slope 9 Jul 13, 2005 04:07 AM
Attitude elevator throw kenny_dilger 3D Flying 6 Feb 09, 2004 08:05 PM
Elevator throw on a Tiger Moth olly49 Parkflyers 3 Oct 12, 2003 09:10 PM
Bandit elevator throw? Bill Franke Electric Sailplanes 5 Mar 18, 2002 07:05 PM
