Old Oct 04, 2003, 03:00 AM
Robert Cina
Robert Cina
Guest
n/a Posts
Tower Hobbies .46 ABC Engine
Hello,
I am just getting introduced to the hobby and received by Sig LT-40
ARF yesterday. I bought a Tower Hobbies .46 ABC engine to go along
with it. After reading several posts, I wonder if this engine was the
right choice. Should I return it for a Thunder Tiger .46, or should I
keep it. Could anyone with experience with this engine offer some
insight. Thanks so much for your help.
Rob
Old Oct 05, 2003, 03:00 AM
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
Re: Tower Hobbies .46 ABC Engine
If you get a good one, they are great. If not, they can be very
frustrating.
Paul McIntosh
Desert Sky Model Aviation
http://fly.mcintoshcentral.com
"Robert Cina" <robert@drcina.com> wrote in message
news:3b367ab8.0310031849.26eed524@posting.google.c om...
> Hello,
> Thanks,
> Rob
Dr1Driver
Dr1Driver
Guest
n/a Posts
>keep it.
I'd get a TT Pro, OS FX, ST, or Webra.
Dr.1 Driver
"There's a Hun in the sun!"
Ted Campanelli
Ted Campanelli
Guest
n/a Posts
On 10/3/2003 10:49 PM Ted shuffled out of his cave and grunted these
great (and sometimes not so great) words of knowledge:
I started out with a Tower 46 engine (had been away for 30 years).
I would not suggest it as a first engine. They are a powerful engine,
BUT can be VERY frustrating to someone just starting out. They are
notorious for not shutting off with the transmitter and there are
numerous reports of poor idle (mine idled great - just would not shut off).
My first choice for someone just starting out is the OS 46 FX. This
engine will run "Right Out Of The Box" and is as user friendly as you
can get. It is a powerful engine you can use for other planes as well.
It is a little more expensive than a TT (about $110 against about $90).
My second choice is the TT 46 PRO (make sure you get the Pro - it has
the ball bearings). This engine is equal to the OS in almost every way.
The reason I put it at #2 is because the needle valve is on the carb
and therefore closer to the prop. The TT will also need a longer
break-in period than the OS. The OS will perform great after 2 - 3
tanks of fuel, the TT needs about 1/2 gallon before it comes into it's own.
> Hello,
> Thanks,
> Rob
James D Jones
James D Jones
Guest
n/a Posts
The newer TT Pro 46 engines come with a needle valve which is angled to
the rear. This keeps your fingers out of the way of the prop without
introducing the adjustment lag often noticed with remote needle valves.
This might make it your first choice.
Jim - AMA 501383
> I started out with a Tower 46 engine (had been away for 30 years). I
> off).
> you can get. It is a powerful engine you can use for other planes as
> well. It is a little more expensive than a TT (about $110 against
> about $90).
> way. The reason I put it at #2 is because the needle valve is on the
> carb and therefore closer to the prop. The TT will also need a
> longer break-in period than the OS. The OS will perform great after
> 2 - 3 tanks of fuel, the TT needs about 1/2 gallon before it comes
> into it's own.
Morgans
Morgans
Guest
n/a Posts
"James D Jones" <texasrcflyer@yahoo.com> wrote in message
news:TBBfb.1780$gA1.782@newsread3.news.pas.earthli nk.net...
> Jim - AMA 501383
Does it have one needle or two?
Jim in NC
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
Two needles. It appears to be the same carb but with the main needle
casting at an angle.
Paul McIntosh
"Morgans" <jjsumnorkgan@charter.net> wrote in message
news:vnu2l2npc8m8c5@corp.supernews.com...
> > Jim - AMA 501383
> Jim in NC
Old Oct 08, 2003, 03:00 AM
WINZER
WINZER
Guest
n/a Posts
I bought one. It sucks. It has never run right. I own an OS SF46 that has
been the greatest.
> Hello,
> Thanks,
> Rob
Old Jul 15, 2007, 06:56 PM
mathew0214 is offline
Find More Posts by mathew0214
Joined Jul 2007
go with os
mathew0214 is offline Find More Posts by mathew0214
Old Jul 16, 2007, 11:10 PM
Crabs
Crabs
Guest
n/a Posts
mathew0214 wrote:
> go with os
check the date of the posting that you replied to...
It's 4 years old.
I've got an OSMax .46 FX, an OSMax LA. 46, a Thunder Tiger .46 Pro, and
a Tower Hobbies .46 ABC.
All are great motors.
No problems at all with any of them.
The Tower Hobbies .46 has more power than all the others, hands down.
Crabs
Discussion tower hobbies 46 ABC mathew0214 Engines 21 Jul 28, 2007 08:48 PM
Sold Tower Hobbies .46 Ball Bearing ABC Engine chris8105 Aircraft - Fuel - Airplanes (FS/W) 3 Sep 15, 2005 08:21 PM
FS- NIB Tower Hobbies .46 BB ABC Engine Dellonious Aircraft - Fuel - Airplanes (FS/W) 5 Jan 27, 2005 11:22 PM
