Old Dec 30, 2011, 02:10 PM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
How much time would .5 amps knock of my charging time.
I have a 3-cell 2200mah 30c eflite lipo that came with a 1.8 amp charger and i only have the aligator clips for it. So i use the hobby zone charger to charge from the house wall which is for a 3-cell 1300mah 15c lipo which charges at 1.3 amp. So my question is if im charging the 3-cell 2200mah 30c from the wall at 1.3 amps and it takes an hour to charge, About how much time would i knock off if i charge the 3-cell 2200mah 30c lipo with the 1.8 amp charger with aligator clips to the car?
skarface is offline Find More Posts by skarface
Old Dec 30, 2011, 02:41 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
Seems like it would be 38% less time.
It should not matter if it is from the wall or your car the charge amount should stay the same.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Dec 30, 2011, 03:35 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
If it's taking 1 hour to charge at 1.3A, that's possibly only 50 minutes at full 1.3A rate followed by 10 minutes at reducing amps, constant voltage, rate. So your charger may have only put about 1100mAh into the pack (i.e. the pack was only half discharged). To do the same thing at 1.8A would take about 33 minutes full rate plus the same 10-minute constant voltage phase.
As TheWoodCrafter has said, it doesn't matter where the charger is getting its power from. But the battery's condition, and the way the chargers are designed, will affect my assumption about how long it takes for the reduced-amp constant-voltage phase of the charging and, thus, the calculations for total charge time.
abenn is offline Find More Posts by abenn
Old Dec 30, 2011, 03:40 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Probably much less than you think. The constant current phase will last longer with the lower current so in the end, the difference isn't that great.
See the note on "Fast Charging" in this article.
http://sites.google.com/site/tjinguy...-chargers-work
From Battery University -
Increasing the charge current does not hasten the full-charge state by much. Although the battery reaches the voltage peak quicker with a fast charge, the saturation charge will take longer accordingly. The amount of charge current applied simply alters the time required for each stage; Stage 1 will be shorter but the saturation Stage 2 will take longer. A high current charge will, however, quickly fill the battery to about 70 percent.
Fast charging will be faster but not linear to the charge current.
The advantage of fast charging is much greater if the user is happy at cutting off the charge at 90-95%. The CC phase quickly takes it up to 70% and then cut the CV stage by accepting a lower charge %.
hoppy is offline Find More Posts by hoppy
Discussion How much is too much of a difference in charging parallel lipos? TheNiceGuy Batteries and Chargers 1 Dec 30, 2011 01:59 PM
Question How to calculate run time at max amps? Bugman Jeff Batteries and Chargers 4 Dec 17, 2011 11:59 AM
Discussion How Much Should Government Do? How Much Is Too Much? How Much Debt? LcJ Life, The Universe, and Politics 80 Jul 28, 2011 07:43 PM
Sold NOT for sale but a feeler how much would you pay for 2 blade cx2's and tons of parts? gaaunapoi Aircraft - Electric - Helis (FS/W) 8 May 11, 2011 01:20 PM
Discussion How much flight time would I have left? bdshort Batteries and Chargers 10 Jan 30, 2011 02:48 AM
