Old Feb 16, 2012, 03:07 AM
flyzguy is offline
Find More Posts by flyzguy
prefer lift over drag anyday
flyzguy's Avatar
Joined Jun 2005
Here's a few of my wings. The large pink foam and glass wings were 10 Ft, MH60, twisted for very nearly minimum induced drag. Recorded about 19:1 using an Attopilot integrating airspeed and averaging ground speed in a loiter circle. Would do a nice body free flutter mode about 80 km/hr. The small combat wing is a PW51 EPP wing with < 4oz/ft^2 and 4 degrees of washout retains energy very well. Covered with laminating film and painted.
flyzguy is offline Find More Posts by flyzguy
Old Feb 17, 2012, 07:07 PM
Taurus Flyer is online now
Find More Posts by Taurus Flyer
I bail out, anywhere, anytime
Taurus Flyer's Avatar
The Netherlands, OV, Almelo
Joined Nov 2010
Gents,
Always under development, (electro propulsion) but I still have the original construction photographs of ten years ago,
Own design Horten glider, 2,60 m.
All wood construction and silk and dope covering.
First picture to show the control elements and pushrods, before covering
Spoilers near the centre only on top.
Drag rudders, only on top of the wing.in the closed sections right side wing drag rudder is visible
Ailerons and elevators combined, so elevons.
The plane is conrolled with the use af a special controller device in the transmitter which calculates the postion of the drag rudders depending of elevator input and aileron input. There is always one rudder closed, or both in neutral position of rudder control,
Second photograph, close up.
Other pictures made in the Eiffel, Germany slope gliding.
Cees
Taurus Flyer is online now Find More Posts by Taurus Flyer
Old Feb 17, 2012, 07:44 PM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Yea baby
I like the Taurus Flyer. That's one cool looking Horten! Looks like a very light buiild too. It must have been a trick to program the drag rudders to operate as they did.
Kent
Knoll53 is offline Find More Posts by Knoll53
Old Feb 18, 2012, 04:57 AM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Mmmm... Intriguing - the control system sounds most interesting. Lovely build as well
Shedofdread is offline Find More Posts by Shedofdread
Old Feb 18, 2012, 04:58 AM
ohmite is offline
Find More Posts by ohmite
ohmite's Avatar
Eden NY
Joined Sep 2001
Originally Posted by Taurus Flyer View Post
Gents,
Cees
Cees,
This glider looks very nice, impressive. Can you provide more information on the methods and principles of your rudder control device, or more pictures? Maybe a diagram that explains the principle? Did you find it more effective than elevon alone? Did these rudders allow you to using less washout?
Best Regards,
-Eric
ohmite is offline Find More Posts by ohmite
Old Feb 18, 2012, 06:11 AM
Joined Nov 2010
Originally Posted by ohmite View Post
Cees,
Best Regards,
-Eric
Eric, gents,
Last question first. but I think it isn't new for you, only to complete the story.
Basicly for a Horten glider I personally don't like to talk about washout! Main reason for that is the Horten principle doesn't work without different AOA on several locations of the wing, It has to do with "basic design requirement"!!!
Just a way of talking but has to do with the reason: Why does the tip airfoil less AOA than the root and how much?
It all depends on, to create a bell shape lift schedule generating over the wing.
We all know but I need the complete story to answer the question!!!
So,
For which speed is an individual Horten designed?
Basicly the value of airspeed in which the lift of the tip is zero, cruise speed!
Too slow and the top has to generate lift. Too fast and the tip will generate negative lift.
But, that not only depends of airspeed, but also weight!! Yes indeed!
So, do dragrudders to allow me using less washout?
No at least not in thraight flight because both are closed and there isn't any difference in flying related with without.
Important in the principle, and that's why I did write it in the first post, both are closed in neutral position of rudder input.
Cees
Old Feb 19, 2012, 09:52 AM
Joined Nov 2010
Gents,
A short added note about the drag rudders.
The Horten was designed for two systems of the dragrudders.
First methode a mechanical mixer in the centre section.
Both elevons do have their local servo in the wing and two pushrods were used to activate the mixer in the centre secton, see the picture.
The mixer did eliminate the up and down input, only detected was the difference, so aileron action.
The aileron action did activate the right dragrudder to prevent (too much) adverse yaw. (left side pivot isn't visible but the same as right side.)
It is a fixed system and ratio, only to be changed by mechanical adjustment.
Flying the plane I discoved very less drag rudder deflection is needed to realize good control.
I did make a electronic mixer in my transmitter after that
A single servo is placed in the centre on same location as the mechanical mixer to activate the rudders
The amount of deflection was calculated in the transmitter and could be changed during flight by a ratio and zero adjustment.
Because I use an analog tranmitter (anti) logarithmic amplifiers are used for calculation.
My obeservation did show the second system give good curvature of turning.
Adjustment was experimental determined.
I never could compare the system with existing Hortens with same aspect ratio. I also never did fly without the system.
Goal of my experiments was, have a system that could be used and adjusted for Horten gliders with high values of aspect ratio like HO IV / HO VI and also to control slip of the plane with use of measurement and controller(s).
I did need the experiments to have an idea of dimensioning of rudders and deflection which is about 5 mm's max opening.
The Horten is in the workshop and In the future the plane will have electro propulsion and because of higher wing loading, redesigned tips with some more span and maybe combined with Schempp Hirth drag rudders.
Under development is also a slip measurement system.
Cees
Old Feb 19, 2012, 10:03 AM
ohmite is offline
ohmite's Avatar
Eden NY
Joined Sep 2001
Cees,
Nice ingenious system. I'm sure with the microprocessors and sensors available now an onboard system with mixing and sensing should be much easier to implement. Thank you for the additional information.
Best Regards,
-Eric
Old Feb 19, 2012, 10:25 AM
Joined Nov 2010
.Eric,
Thanks for response,
I do fly "old school" so control systems are all analog for several reasons just as my construction methodes are "classic".
But, result can be the same.
Cees
Old Feb 19, 2012, 12:19 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Hi Cees,
Really interesting mixer. I do have some questions regarding the linkage system though. Any additional comments, photos or drawings would be appreciated.
So each elevon is operated by a conventional wing servo located at the elevon. Those elevon servos were also connected to the mixer at the center. So both the elevons servos drive the one mixer.
Right. If both servos pushed or pulled, as with elevator only control, the mixer would not move the drag rudders.
But here's the question. If with aileron input, one servo pushes and the other pulls, then the mixer will be offset to one side, causing both drag rudders to operate. One drag rudder linkage gets pushed and one gets pulled. That means one drag rudder would project above the wing and one would be drawn down into the wing.
That can't be what happened. What am I missing? Did you have some sort of one-way-only device at the drag rudder that eliminated movement from one direction?
Kent
Old Feb 19, 2012, 02:12 PM
Joined Nov 2010
Ahhh Kent, you did make you message longer, so my drawing is a little bit "overdone". but, makes more clear for other members.
English isn't MY language, If it was my language I would have used pushpullrod for two directions, push and pull.
Using this way of formulation the drag rudder is activated by a pull rod and spring loaded.
The mechanical mixer was located near the TE in the center of the fuselage,
The drag rudder is right positioned on your picture, the other location in the wing is for the elevon servo.
Maybe you know, but principles of mixers like these we used in the past, in the first generation of proportional transmitters. for V-tails for example.
Now I did need a kind of "RE MIXER" with inverted action to generate an "aileron"
signal, because that is the result of the pull pull rods.
Because it was a temporary solution I did mix the aileron and elevator in the transmitter and remixed it back to ailerons for the drag rudders in the Horten.
All possible, because the Horten originally was a cuckoo-clock inside too (LOL)
Cees
Old Feb 19, 2012, 03:06 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Nice drawing Cees! I get it now. Push only at the drag rudder.
I really like the mechanical mixer. With modern ball links and proper geometry, I'm sure it can be very serviceable. Thus saving the precious Tx programming for other uses.
We have an old saying in this country (stolen from the Chinese, no doubt), " a picture is worth a thousand words".
A good drawing is worth much more.
Oh, and thanks for posting in MY language.
Kent
Old Feb 21, 2012, 02:00 PM
Peter Wick is offline
Find More Posts by Peter Wick
Kopenhagen
Joined Apr 2005
My Amokka
still going....the Amokka 2.0 is in the making
Yours Peter
Peter Wick is offline Find More Posts by Peter Wick
Old Feb 21, 2012, 02:29 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Originally Posted by Peter Wick View Post
My Amokka
Yours Peter
What a beautiful place to to fly.Can you post some details on the plane please.
Regards Stuart
Stuart A is offline Find More Posts by Stuart A
Old Feb 22, 2012, 04:16 AM
Kopenhagen
Joined Apr 2005
Dear Stuart
here is the (old) thread about the Amokka and a vid:
http://www.rcgroups.com/forums/showt...ghlight=amokka
the pictures here are from my last summer holidays in Danmark....and yes we rentet the house on the picture!!!!! Guess who made the choice :-)
Link RC kite build logs.. show your kite and link it to your build log davereap RC Paragliders and Kites 19 Mar 31, 2016 06:03 PM
Contest Show us your Nano in action contest! JimDrew Xtreme Power Systems 103 Jul 15, 2014 06:45 PM
Discussion Model your model(Show your model Part V) Woody610NB Chit Chat 340 Sep 02, 2013 12:19 AM
Gallery Show us your scratchbuild hanger Jab69 Foamies (Scratchbuilt) 14 Dec 18, 2011 12:15 AM
Discussion Out of all your helis, Show a pic of your Fav. jenn123 Electric Heli Talk 29 Sep 16, 2011 09:17 AM
