Palo Alto, California, United States
Joined Jan 2003
Here's my Oblique Flying Wing (OFW) demonstrator built for NASA in 1994. It's a scaled down version of an SST concept that is highly efficient over a wide range of cruise Mach Numbers. The model has a 20 ft span and weighs 80 lbs. Power is from 2 x 0.91 ducted fans and there's an on-board computer system for augmented stability in the pitch and yaw axes. The model was flown with oblique sweep varying between 20 and 55 degrees (i.e. like a surfboard flying sideways through the air).
Joined Jan 2003
This one isn't a model, but many RC models were tested before the full size version was built. It's a rigid-wing hang glider with a pilot fairing for reduced drag. Max L/D is close to 20:1. I own this glider but a higher performance version is still in production:
http://www.aeriane.com/swiftlight.htm Steve |
Steve, that oblique wing is very impressive. Those oblique wings have fascinated me. I was intrigued by the one Geode built for sloping - http://www.rcgroups.com/forums/showt...hlight=oblique and now we have a "rocket scientist" showing us his stuff.
A tip of the hat to you sir. Mark |
Thanks lads,
the Schapel is one of my favorites too. I enjoyed a lot the design and construction. It's a very well balanced design, which spans over the complete range: fast, dynamic and slow. I have not measured the L/D, but it should be around 12 - 15, which is not bad for an AR of 7 and such a small model (2 m span). @Stuart: I use a pusher now. I think the space is not large enough for an impeller fan and it was the easiest way to shift away from a turbine - a Lambert Kolibri with 25 N of thrust. @Steve: I like the Swift, although I'm not really into winglets... @Brian: Maybe we find an arrangement concerning the plans ![]() Andrés p.s. Here's another photo of the whole Schapel family. Although the small ones share the planform, these are quiet different designs. The small one was made for speeeeddddd
Nothing to show,but maybe my q will produce something.Iwas looking on the site of the people I hope to use to cut parts for Uwe's Ellie and the HoX if it comes to fruition((falcon.aviation.com-giant plane specialists,20ft Vulcan for example)Among the list of kits they have cut is the Horten 33v2.Have any of you guys built this?
Regards Stuart |
the only drawing from the Horten 33 V2, which are Horten III wings with a tandem middle section, it is from the german "Verlag für Technik und Handwerk" who release the FMT. We had a discussion to built one but the design was not so good. Here is a link to the drawings FMT Ho 33 V2 Regards Jörg |
Horten 33 v2
Stuart
I have the FMT plan and the details are that it was drawn by Kriz (no surname), on the 28,12,1992, is to 1/6 scale and there are 2 pages to the plan. It has been on my to do list both as an electric soarer and as an indoor rubber scale job for years. I even have vac formed the canopy for the indoor one. It was this plan of mine that Falcon aviation scanned ready to cut the parts. They also scanned the SZD Wampir and Nietoperz plans I had. I should be surprised if they have cut any parts yet though. Regarding the Ho33, the airfoil section is very thick for its chord at 20% thickness at both the root and tip. Reflexed root and a NACA type symetrical tip with 9* negative twist. Regards John |
Thanks a lot John.Coincidence-I'm on and off building a He162 by the same Kriz!I half heartedly tried to find some details about him without success.
Jorg,are these the same plans you were working with? This is the beauty of this forum,all the info in one place. Regards Stuart |
| Thread Tools | |
| Discussion Model your model(Show your model Part V) | Woody610NB | Electric Plane Talk | 333 | Aug 14, 2012 11:10 PM |
| Gallery Show us your scratchbuild hanger | Jab69 | Foamies (Scratchbuilt) | 14 | Dec 18, 2011 12:15 AM |
| Contest Show us your Nano in action contest! | JimDrew | Xtreme Power Systems | 67 | Nov 29, 2011 06:28 PM |
| Discussion Out of all your helis, Show a pic of your Fav. | jenn123 | Electric Heli Talk | 29 | Sep 16, 2011 09:17 AM |
| Link RC kite build logs.. show your kite and link it to your build log | davereap | RC Kites | 3 | Mar 24, 2011 09:56 AM |
