Old Feb 15, 2013, 09:10 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
I've posted a link to here onto the HoIV build above
Stuart A is offline Find More Posts by Stuart A
Old Feb 15, 2013, 09:52 AM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Wow Andrés, that's quite a ship ! Spoilers are going to come in handy with that one. Even with the limitations of the Re numbers we live with, I'm thinking that this one will have a rather good glide..................
Flying a model with that wingspan will require some re-thinking of the normal flight plan. Those wing tips are WAY out there.
Kent
Knoll53 is offline Find More Posts by Knoll53
Old Feb 15, 2013, 10:16 AM
andrecillo76 is offline
Find More Posts by andrecillo76
andrecillo76's Avatar
Germany, BW, Stuttgart
Joined Oct 2009
Kent, yep, its a big wing and I'm happy to have access to a good and open place for flying. Nothing for small or crowded spots. Though it is large, it has only about half a metre more span per side than the H-XIV. On the table it does not feel that large, but I can feel already nervous just thinking about a maiden By the way, it has effective spoilers
Thanks Stuart!
Cheers
Andrés
andrecillo76 is offline Find More Posts by andrecillo76
Old Feb 15, 2013, 10:33 AM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
ha, ha, ha.... Top and bottom no less. Yes you have enough spoiler to wipe out lift for half of Germany! Looks good.
Kent
Old Feb 17, 2013, 06:41 PM
Dan D is offline
Find More Posts by Dan D
United States, OH, St Paris
Joined Apr 2000
1/2 a Horten
Hello everyone, CPDude ask me to make a post of my 1st Horten, It is one of Tigershark's Dwg files, andI would like to thank him too, for sharing the design while I am at it. It has been real fun to build this way. And fast way to build as far as I am concerned. I started around late November 2012 after work a few days a week and some weekends as far as building time thus far.
So thanks to CPDude and Tigershark!
Dan
Dan D is offline Find More Posts by Dan D
Old Feb 18, 2013, 02:44 AM
Tijgerhaai is offline
Find More Posts by Tijgerhaai
Tijgerhaai's Avatar
Germany
Joined Nov 2005
Dan,
You are welcome
It's nice to see, that someone is building this plane and is happy with it.
Lothar
Tijgerhaai is offline Find More Posts by Tijgerhaai
Old Feb 18, 2013, 03:21 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Dan
Very nice!I've often thought that a bench with sweep would be handy for these wings
Old Feb 18, 2013, 06:43 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
The Wiesel
Here's a plank with the PW51 airfoil.
Kent
Wiesel - Maiden Flight (0 min 0 sec)
Wiesel ... (0 min 34 sec)
Slopin at Marina (0 min 0 sec)
Old Feb 19, 2013, 12:30 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
3,8 M Giga Wiesel sloping. (2 min 5 sec)
You call that a Wiesel?This is a Wiesel:
Old Feb 19, 2013, 02:20 AM
Joined Oct 2009
Wow!
Andrés
Old Feb 19, 2013, 04:44 PM
guitarcher is offline
Find More Posts by guitarcher
Living on the Dark Side.
guitarcher's Avatar
Australia, QLD, Maryborough
Joined Jan 2013
Stealth glider.
Hi Fellas. Here is a pic of my scratch built glider. The wings are cut from el cheapo packaging foam. The outer wings are left overs from a stretched Alula I built and are thinned S5010 profile. The centre section is standard 5010 and was added in an attempt to reduce the amount of nose weight that was required. This did not pan out as planned and I needed to add a pod. A 3S 1300 mAh battery is in the nose and gives 3 0r 4 climbs to a couple hundred metres.
The ship is a real floater with only a few weather limited thermal opportunities thus far but has attracted close attention from the local eagle population. Surprisingly it also handles windy conditions well.
Currently the outboard control surfaces are set up as ailerons with the centre as elevators. I need to change this to outboard elevons and flaps in the centre and landings just go on and on forever.
Very happy with this ship that cost less than a hundred bucks all up.
Greg.
Name: Stealth foamy.jpg
Description:
guitarcher is offline Find More Posts by guitarcher
Old Feb 20, 2013, 04:38 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Nice.Have you tried any flights without the inboard or tip fins?
Old Feb 20, 2013, 01:54 PM
guitarcher's Avatar
Joined Jan 2013
Thanks Stuart.
My test flights were tried with much smaller inboard fins and the plane would not respond to aileron inputs resulting in crashes into the nearby gum trees. I tried increasingly larger fins until I arrived at the current set up. As for the angled tip fins on the forward swept outer wings I just replicated something similar to the Alula. This 2metre set up flies well in this configuration but I may try it without the tip fins at some stage. I am open to any suggestions.
Greg.
Old Feb 20, 2013, 07:30 PM
slebetman is offline
Find More Posts by slebetman
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
It's possible that those fins aren't really acting as the regular v-stab but rather side force generators (kind of like daggerboards on sailboats). I'm not entirely clear on the theory behind it myself but there is at least one design of a free flight plane that uses it as a replacement for dihedral.
Here's a picture of the plane. Circles perfectly fine with zero dihedral:
slebetman is offline Find More Posts by slebetman
Old Feb 21, 2013, 08:04 PM
cpdude is offline
Find More Posts by cpdude
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Stabiloplan IV
I cut a 1.5m Stabiloplan for a friend of mine. The plans are available here: http://www.nuricom.de/Models/index.htm. It's not done but it's going together pretty quickly.
Brian
cpdude is offline Find More Posts by cpdude
Link RC kite build logs.. show your kite and link it to your build log davereap RC Paragliders and Kites 19 Mar 31, 2016 06:03 PM
Contest Show us your Nano in action contest! JimDrew Xtreme Power Systems 103 Jul 15, 2014 06:45 PM
Discussion Model your model(Show your model Part V) Woody610NB Chit Chat 340 Sep 02, 2013 12:19 AM
Gallery Show us your scratchbuild hanger Jab69 Foamies (Scratchbuilt) 14 Dec 18, 2011 12:15 AM
Discussion Out of all your helis, Show a pic of your Fav. jenn123 Electric Heli Talk 29 Sep 16, 2011 09:17 AM
