Old Dec 15, 2012, 06:58 PM
Fly Wheel is offline
Find More Posts by Fly Wheel
Ochroma Pyramidale Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
Originally Posted by vincent123 View Post
This wing I made goes over 200km/h, according to the installed GPS, nice surprise !
http://www.youtube.com/watch?v=s5VXm...are_video_user
It sounds like a cross between my dads router and a honeybee!
I love your sheeting clamps - rubberbands and Legos! Adaptable and obviously effective. MacGyver would be proud!
Fly Wheel is offline Find More Posts by Fly Wheel
Old Dec 16, 2012, 02:26 AM
vincent123 is offline
Find More Posts by vincent123
InceCreations
vincent123's Avatar
Joined Jul 2009
Hi fly wheel, thanks for the compliment, yeah, it turned out to be a very stiff wing.
vincent123 is offline Find More Posts by vincent123
Old Dec 18, 2012, 03:20 PM
Fly Wheel's Avatar
Joined Sep 2007
Originally Posted by Vernon Hunt View Post
Here are some pics of my flying wings. Some of them anyway.
Vern
How much did this one set you back?
Old Dec 18, 2012, 04:12 PM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
As an aero towed ULGlider that looks like fun !!!
The CG seems a bit aft but what do I know about this design.
Back "in the day" I had an Easy Riser by UFM.
It had Dihedral, Sweep back and some Washout too.
I dont recall any reflex in the Foils.
Plans are buried somewhere after my move.
Bob
birdofplay is online now Find More Posts by birdofplay
Old Dec 19, 2012, 12:33 PM
Fly Wheel's Avatar
Joined Sep 2007
Bob
I would imagine the seat is adjustable fore-aft to accomodate different pilot weights, as being the heaviest single component of the AUW the pilot would be the determining factor as far as CoG is concerned.
Old Jan 01, 2013, 01:13 PM
Knoll53 is online now
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Well it may not be MY nurflugel, but at 29:35 there is a nice clip of, I believe, a Horten II flying in a thermal. Scattered through out the video there are some additional clips of the Horten II landing and launching, all of which I've never seen before. See 9:45. At least it appears to be original footage. I'm regularly fooled by modern computer graphics.
Kent
DOKU: Hitlers letzte Flieger (49 min 21 sec)
Knoll53 is online now Find More Posts by Knoll53
Old Jan 01, 2013, 04:10 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Thanks for posting that Kent,some interesting footage(and bad re-enactment.)
What do you make of the pic?Can't stop frame it on the ipad.
Stuart A is offline Find More Posts by Stuart A
Old Jan 01, 2013, 04:15 PM
less is more
Knoll53's Avatar
Joined Sep 2006
That IS what it appears to be. A Horten wing with canard mounted up front. I have read about it before, don't know more about this version than to know that it did exist. I'm a little baffled as to what problem it is attempting to solve. In my experience, Hortens have good pitch stability, but need help with yaw stability.
Kent
Old Jan 01, 2013, 04:16 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Been looking but have not discovered an English version of that Movie.
Stupot46: Saw that and presume that it's a "safety" test.
Like they were working on elevator authority but weren't sure about it.
Bob
Old Jan 01, 2013, 07:50 PM
andrecillo76 is offline
Find More Posts by andrecillo76
andrecillo76's Avatar
Germany, BW, Stuttgart
Joined Oct 2009
The "canard" was an attempt to reduce the so called "Mitteneffekt". The Horten brothers found that, the center section produced less lift than predicted by their calculations. As far as I know, this Mitteneffekt is just a discrepancy between the calculation and the outcome and not a true effect. Most probably it was an artifact of the numerical method used failing at calculating the lift dirtibution of thick and swept back wings with a canopy on top and bottom. This Mitteneffekt was also the reason for the shape of the unusual "Horten-Parabola".
Cheers and Happy New Year,
Andrés
andrecillo76 is offline Find More Posts by andrecillo76
Old Jan 01, 2013, 09:01 PM
nmasters is offline
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
One of the sweep effects is that the cl/alpha curve on the forward-most part becomes shallower. The Hortens misinterpreted this as a lose of lift on the center section, as Andres indicated, it's just a shortcoming of the math available at the time. The vorflugel was an experiment to try and get the lift back. Since they didn't build another plane with it it apparently wasn't considered an improvement. However it also apparently didn't hurt very much either considering that this is one of the H-IIIs that was destroyed by hail at 26,000ft.
--Norm
nmasters is offline Find More Posts by nmasters
Old Jan 02, 2013, 02:45 AM
xlcrlee is offline
Find More Posts by xlcrlee
Joined Apr 2006
Kent
http://www.youtube.com/watch?v=sGg5qyYU9z4
I think I can just barely make out the washout/wing-twist at 12:57, 13:39, and in the elevons at 13:49 in this video. Of course this would have to be increased at lower model-Rn.
Lee
xlcrlee is offline Find More Posts by xlcrlee
Old Jan 02, 2013, 03:17 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Andres,Norm,thanks for clearing that up.Hard to make out any support structure,but it sure looks a bit vulnerable stuck out there.
Any theories on it's aoa relative to the main wing?
Regards Stuart
Old Jan 02, 2013, 09:30 AM
Joined Oct 2009
Stuart,
they felt that the wing was nose heavy due to the "Mitteneffekt", so I would expect the Vorflügel to fly with positive AOA to increase the total AOA. The exact amount depends on many paremeters, such as size, airfoil and distance of the Vorflügel, and the pitch stability of the main wing. I do not think that the Vorflügel was affecting much the flow of the main wing, besides the pitching moment produced by the Vorflügel's lift (in contrast to, e.g. slats in usual wing configurations). Thus, the effect of the Vorflügel can probably be obtained by changing the twist distribution or by deploying the elevons. I guess that was what they did in their later desings, explaining why it was not used anymore. If I remeber right, Reimer Horten used it again in one of their Argentinian gliders, but I do not know which one anymore .
Cheers,
Andrés
Old Jan 02, 2013, 12:02 PM
John Wright is offline
Find More Posts by John Wright
United Kingdom, Harleston
Joined May 2004
Kent
Thanks for posting the link.
Is it really original footage of the Horten IX V1 at 32.38 and 38:40 ? I am not aware that any film has been shown before of it in flight.
John
John Wright is offline Find More Posts by John Wright
Link RC kite build logs.. show your kite and link it to your build log davereap RC Paragliders and Kites 19 Mar 31, 2016 06:03 PM
Contest Show us your Nano in action contest! JimDrew Xtreme Power Systems 103 Jul 15, 2014 06:45 PM
Discussion Model your model(Show your model Part V) Woody610NB Chit Chat 340 Sep 02, 2013 12:19 AM
Gallery Show us your scratchbuild hanger Jab69 Foamies (Scratchbuilt) 14 Dec 18, 2011 12:15 AM
Discussion Out of all your helis, Show a pic of your Fav. jenn123 Electric Heli Talk 29 Sep 16, 2011 09:17 AM
