Joined Jul 2012
Yes, I think it's a cool shape too- in a sort of 'angular scimitar' way. The glide is quite flat fast and straight, well it was with profile fuse I've got to wait for daylight to try with gear fitted.Surface throws are about 1/4" up/down and a bit spongy due to piano wire torsion rod though at this size quite immaterial. Hey ! I could have claimed that to be a designed in servo saver
, balance point is 1/2" fwd of root trailing edge.Trev |
good evening gentlemen,
Trev, I have to say..... really nice shape this little wing, fuselage enough big for perfect motor instalation. By the way, the avatar is my first plank with the new box shape spar. Here is the airfoil ClarcYS. This is thick enough to get a good stifness. It flies really easy and when you wish, like a little hotliner. Wingspan 2,5 m, weight app. 1,8 kg complete. You can find the build log here: http://www.rc-network.de/forum/showt...oud-Baubericht The clip: http://www.rcmovie.de/video/fe5a2e03...8/Flying-Cloud A lot of new unconventional ideas went in this design. Box shape spar, side cover at fuselage, cooling exit at the rear, variable motor down thrust. etc. gerd |
Joined Jul 2012
Well guys it would be great to say that this little all sheet Apparition flew great---- but I can't
By the time that all the gear was installed the trim CG position had moved too far forward for decent gliding flight, and it only flew at one speed, flat out under power and needed every bit of up elev [and some more] to avoid 'tent pegging' on arrival.As I don't fancy hanging weight on the wingtips to rebalance it's out with the knives and off with the pod for a rebuild. Still, failure is what spurs us all on to succeed I was told as a child!@ Gerd. Now this Avatar of yours I really do like Fantastic lines! After I've done all that which Management has decreed to be done I'll take a good look at your build log for it.Trev |
You don't have a failure, you have a challenge !
After the first flight test is when things start to get interesting.Would it be possible to relocate the servos out into the wings? Thus removing the torque rods and moving that weight back a bit. Then move the Rx and battery back until you like the CG. With the proper CG, this plane will jump when you hit the elevator. Kent |
Joined Jul 2012
Out with the knife and off with the pod, trim it up and refit an inch or so further aft , maybe fit servos under wings. Next step is arrange all components with sticky tape in place to get slightly tail heavy then rebuild Trev |
Joined Jul 2012
Rollin' & a Rockin', all the gear put back in to the (un)melodious sounds of Meatloaf
![]() As Kent said to view it all as a challenge, I thought why not try to do a miniature closed loop system to get rid of control slop, --- just luv a challenge me ![]() Anyway it all works , and CG is about 3mm aft of the testglide position to allow some noseweight if needed and if it flies halfokay I'll draw up a big version, anyone got airfoil suggestions for a relatively high A/R wing.? Might even try a frustrating couple of hours trying it in XFLR5--- just for the challenge of course ![]() Trev |
Every rebuild is an "opportunity" to try some thing new, as in your pull/pull linkage. Cool...like it.
BTW, all the Horten pilots who fly power, launch with a bungee just to assure a smooth transition to powered flight. I like a bungee for a short hard pull for initial test hops. It's just the easy way to get in the air. Kent
| Thread Tools | |
| Discussion Model your model(Show your model Part V) | Woody610NB | Electric Plane Talk | 333 | Aug 14, 2012 11:10 PM |
| Gallery Show us your scratchbuild hanger | Jab69 | Foamies (Scratchbuilt) | 14 | Dec 18, 2011 12:15 AM |
| Contest Show us your Nano in action contest! | JimDrew | Xtreme Power Systems | 67 | Nov 29, 2011 06:28 PM |
| Discussion Out of all your helis, Show a pic of your Fav. | jenn123 | Electric Heli Talk | 29 | Sep 16, 2011 09:17 AM |
| Link RC kite build logs.. show your kite and link it to your build log | davereap | RC Kites | 3 | Mar 24, 2011 09:56 AM |
