Old Aug 10, 2012, 11:33 AM
domll is offline
Find More Posts by domll
domll's Avatar
Norwich.uk.
Joined Oct 2007
can't believe its been a month since i last posted now have a week off work so will be looking at making some progress.
Just in time, the Lipo pack arrived today so i can get the wiring done.
Question: can anyone confirm for me, the Lipo (Zippy 5000mah 4cell 30C) has 8AWG wire and my Y connector is using 14AWG, same as the ESC's (60Amp). Am i going to have problems using 14AWG? I'm thinking not as i don't think the ESC's would have used it if there would be problems but I'm wavering in my own judgement.
domll is offline Find More Posts by domll
Old Aug 10, 2012, 02:53 PM
thnilsen is offline
Find More Posts by thnilsen
thnilsen's Avatar
Norway, Hordaland, Os
Joined Nov 2004
You should be fine with the 14AWG wire as long as you don't plan on pushing 60Amp for extended periods.
- Thomas
thnilsen is offline Find More Posts by thnilsen
Old Aug 10, 2012, 03:05 PM
LuvEvolution7 is online now
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
Yeah, your amps aren't high enough to be concerned. If you were 120+ amps, I'd be concerned with wire size differences and lengths. Smaller diameter and longer wires get hotter than larger diameter and shorter lengths. You'll be just fine.
You considering an HK Vixen when they come out
LuvEvolution7 is online now Find More Posts by LuvEvolution7
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Thanks for the confirmation.
Old Aug 11, 2012, 12:40 AM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Thanks again, thought i might be just needed a second opinion to confirm.
Yes i am or should it be will be . Got a few ideas that i want to try out that i couldn't do with this one. Any ideas on the release date yet?
Old Aug 11, 2012, 07:45 AM
D_FAST is online now
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
domll,
Are those opto's? If not, make sure you disable one of the internal bec's by removing one red wire to the receiver from one of those esc's.
D_FAST is online now Find More Posts by D_FAST
Old Aug 11, 2012, 08:26 PM
Joined Jan 2009
The HK Vixen should be out in the next 3-4 weeks at the very most. The maiden has been do.e and apparently it flies very well. No turrets, but easy to add. It also has cheater holes like the Vampire. Yuck. LOL
Old Aug 12, 2012, 01:53 AM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
D_Fast, thanks for the reminder. Hadn't forgot but as to make sure will do it now.
Sounds like they will be flying before me . With you on the cheater holes, they ruin the looks. Got a JP A4 Skyhawk and its peppered with them....not nice.
Think that's one of the possible mods i might look at
Old Aug 13, 2012, 10:20 PM
Joined Jan 2009
You can fill several of those holes on the Jepe A-4. It goes much better with them covered. There's a thread on here somewhere and it shows which ones to cover up.
Old Aug 18, 2012, 06:05 AM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Okay, another method chosen for sealing the EDF units to ducting: Using some foam tape overlaying the ends of the EDF tubes by approx 3mm and CAing into place I now have snug fit with no leaks. Ribbon is just wrapped under tubes to aid removal.
Started skinning underside, paper template made first then transferred to depron. I use the same template both sides to maintain symmetry. Exhaust pipes are wrapped in 3mm depron, three layers bringing them just proud of rear skin ready for sanding to shape later.
Wiring done as per diagram below, I’ve had problems with the controllers; can anyone tell me, should each controller be programmed together as per the diagram or each done separately. Currently when I start them up one fan begins and sometimes the second EDF starts but not always, when I does there doesn’t seem to be as much thrust from it not as much as first. Is it coincidental that the controller with red wire to receiver disconnected is the one not performing properly? Advice would be greatly appreciated.
In mean time I connected my meter/power analyser, at 40amps I was getting just over 610Amps.
Old Aug 18, 2012, 06:58 AM
Boogie_ is online now
Find More Posts by Boogie_
killed another thread
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
Lookin' good Dom.
Program the ESCs separately. Checking each fan separately with the watt meter, noting the amp draw at ½, ¾ & ful throttle. The numbers off each fan don't need to be exact just somewhat close.
I have twin (P-38) and the motors seldom start up together. But by ½ throttle they're in sync. No problems.
The exhausts of the Vix are very close together. I doubt very seriously if you would ever notice any yawing from uneven thrust.
Boogie_ is online now Find More Posts by Boogie_
Old Aug 18, 2012, 07:17 AM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Boogie - thanks for the quick response, will do as directed and post results.
One last question, what would be the advisable set-up as per the attached instruction sheet? I.e. what throttle/brake setting.
Old Aug 18, 2012, 08:56 AM
Boogie_'s Avatar
Joined Jun 2009
Set Option 1 for what ever battery your using.
However I like to set the cell count/voltage cut off for a lower voltage than what I actually using.
I fly with a timer, working my way up from 2 min. flights, then 3 min., then 4+ min. over a period of weeks. Checking voltage after every flight. Maiden flight day are usually 2 min shakedown flights. Next flying session is bumped up to 3 min, etc.
When flying jets, I don't like the ESC suddenly taking over when it hits the low voltage threshold. Makes setting up for a landing dicey. You can get away with it on a prop job but EDFs are not know for their dead stick landings.
I know by my timer where my batts are at and have maximum power available until touch down. I may lose a battery but I won't lose a plane due to the ESC shutting down.
So far I haven't lost either.
Option 2: •• — 2 Short + 1 Long Auto Throttle Range *
Option 3: ••• — 3 Short + 1 Long No Brake
High revving EDFs stopping suddenly have been known to throw the rotor off.
Option 4: use default
Option 5: This is where you have some leeway. Low timing is less power and amps. But will more than likely be what you'll stick with.
Higher timing setting usually will only up the amp draw, make heat (wasted power) with very little to show for it. Only with some super-duper batteries and a rockem-sockem motor would advancing the timing really help.
But it's fun to play with.
Hook it up to a watt meter and see how the different setting affect you power system.
Option 6: use default unless you have some weird issue.
I've never had to mess with this setting.
Old Aug 18, 2012, 09:27 AM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Awesome , many thanks.
Old Aug 18, 2012, 10:25 AM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
After re-programming controllers per Boogies advice here are the results.
Motor#1 Motor#2
Amps Watts Amps Watts
1/2 throttle 14.34 220 15.02 229
3/4 throttle 28.5 430 31.2 442
full throttle 33.49 498 33.12 492
Controller temp, 56 deg 56 deg
Motor temp 53 deg 55 deg
Both Motors
Amps Watts
1/2 throttle 23.15 345
3/4 throttle 49 701
full throttle
Controller temp 62 deg
Motor temp 69 deg
Didn't go as far as full throttle with both motors as at 3/4 throttle fuselage nearly leapt off its mount. Also didn't want to push ESC's without cooling as the temp increased significantly.
Well I'm pleased with the results, thanks again Boogie for your help.
Would i be correct in assuming that with both motors running the readings are cumulative i.e. 24 Amps and 350 Watts each... or am i assuming too much?
Sea Vixen fly20 Non R/C Items (FS/W) 6 Dec 12, 2011 09:54 AM
Discussion Search for help on Chris Golds DH 110 Sea Vixen jettrainer Scratchbuilt EDFs 0 Jul 18, 2011 12:12 AM
Discussion Search for Chris Golds DH 110 Sea Vixen review jettrainer Electric Ducted Fan Jet Talk 2 Jul 17, 2011 03:17 PM
de Havilland Sea Vixen FAW.2 drawings. bipeflyer Electric Ducted Fan Jet Talk 8 Sep 02, 2003 04:56 AM
Sea Vixen or vampire BruceWilkerson Electric Ducted Fan Jet Talk 15 Jun 12, 2003 04:40 PM
