Old Jun 15, 2012, 02:16 PM
domll is offline
Find More Posts by domll
domll's Avatar
Norwich.uk.
Joined Oct 2007
Whilst waiting for the motors to arrive (received confirmation that they will be shipping today) i done some work on the hatch using 1/16th balsa. final filling/sanding will be done at the end.
domll is offline Find More Posts by domll
Old Jun 27, 2012, 06:38 AM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Whilst still waiting for parts to arrive, decided to do some work on the hatch for access to the EDF's.
Made some 1/8" formers duplicating profiles of F8 and F9 and cut to fit over EDF's then running stingers down the length of the fuselage, CAing ( is that a word??)in place. Carefully i then cut through stringers releasing hatch skeleton and skinning with 3mm depron.
Old Jun 27, 2012, 07:22 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
wow..
Keenan smith is offline Find More Posts by Keenan smith
Old Jun 28, 2012, 05:41 AM
Boogie_ is offline
Find More Posts by Boogie_
killed another thread
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
Nice work on those hatches Dom.
What fan/motors are you going with?
Boogie_ is offline Find More Posts by Boogie_
Old Jun 28, 2012, 12:18 PM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Thanks Boogie.
Fan units are the E-flite Delta V-15:
http://www.e-fliterc.com/Products/De...ProdID=EFLDF15
It’s designed for the E-flite BL15 (or the other way round) but at a cost of over £50.00 each, decided to look for an alternative motor. The one I’ve selected is:
http://www.hobbyking.com/hobbyking/s...dProduct=18543
Here’s a little comparison list of the motors i looked at (as per data displayed with motors):
Old Jul 02, 2012, 12:34 PM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Received the motors, Turnigy L2855-2800, and after a small mod to the fan casing for the wires they fit perfectly.
Wish I could say the same for the fuselage though: With the cone on the rear of the motor they are just too big to fit. Tried every way possible but they just don’t fit. Only two options available;
1) Remove the rear offending former and create larger hatch.
2) Remove the cone on the rear of motor casing.
Closer inspection of the casing makes me think it is a press fit, anyone know? Failing that I will have to spin the casing up on a lathe and cut it off.
Old Jul 02, 2012, 03:58 PM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Sorted, cones unscrew, held with thread-lock and threaded anti-clockwise. Dropped in nicely now.
Old Jul 04, 2012, 10:06 AM
Joined Dec 2010
OOOOOooohhh
Old Jul 08, 2012, 06:29 AM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Help needed!!!
Well guys, I’m a little stumped at the moment with mounting the Fan units, thought I had it sorted but alas no. Thought by attaching a thrust tube this would resolve it, probably would normally but as the exit hole is the same diameter as the Fan unit I can’t slide it back allowing the fan to fit.
This is where I need some help; studying the plans I can see the Fan unit is wrapped in 1/64” ply and there are some ply rings that fit either end, pictures attached. Can anyone tell me how this is being held into place? The Womtec mini Fan has mounting lugs same as mine but on the original plans there are no rails showing as I added to mount mine….. I’m confused…. Only thing I can think of is that it glued in place but then how do I remove for maintenance?
Any help would be appreciated please as I can’t continue until this is resolved.
Old Jul 09, 2012, 11:38 AM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
After some thought and studying the drawings the only solution I could think of was to wrap EDF in 1/64 ply and use 1/16 or 1/8 ply rings either end. Retention would be using half circles, one for the EDF to seat onto and the other over lapping to stop tube falling out. Not show yet will be a small lug at the top of EDF rings for the use of a small screw to nip the rings close up to fire wall, hopefully preventing air leaks. Mounting lugs on EDF will still screw down onto bearers. Might need to remove the skin off the top so I can access inside, last thing I want I to glue half circles in the wrong place and the skin will be easily replaced.
Old Jul 09, 2012, 12:21 PM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Theory into practice...
Have a few minutes before popping out for a while: It works so far, simple ideas work best… well, nearly always anyway. Had a little problem removing units as there’s nothing to get hold of so will fix some kind of ribbon cradle to lift out with. Just need to make rings now but that will have to wait a little while.
Old Jul 09, 2012, 01:30 PM
Joined Dec 2010
yippeeee!
Old Jul 09, 2012, 02:28 PM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Just what i thought myself when it fitted in
Old Jul 13, 2012, 02:00 PM
Dmerino is offline
Find More Posts by Dmerino
Pollock Pines, CA
Joined Aug 2002
Beautiful build. I'm really impressed with the quality of construction.
Dennis
Dmerino is offline Find More Posts by Dmerino
Sea Vixen fly20 Non R/C Items (FS/W) 6 Dec 12, 2011 09:54 AM
Discussion Search for help on Chris Golds DH 110 Sea Vixen jettrainer Scratchbuilt EDFs 0 Jul 18, 2011 12:12 AM
Discussion Search for Chris Golds DH 110 Sea Vixen review jettrainer Electric Ducted Fan Jet Talk 2 Jul 17, 2011 03:17 PM
de Havilland Sea Vixen FAW.2 drawings. bipeflyer Electric Ducted Fan Jet Talk 8 Sep 02, 2003 04:56 AM
Sea Vixen or vampire BruceWilkerson Electric Ducted Fan Jet Talk 15 Jun 12, 2003 04:40 PM
