Old Apr 08, 2012, 08:57 AM
domll is offline
Find More Posts by domll
domll's Avatar
Norwich.uk.
Joined Oct 2007
Got the top of boons covered, supprised how stiff they are now, dispels any concern i had especially when the lower section is covered. nose area will be filled with block foam and sanded to shape. will finish the wing stubs today.
domll is offline Find More Posts by domll
Old Apr 08, 2012, 09:04 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Nice !
Keenan smith is offline Find More Posts by Keenan smith
Old Apr 14, 2012, 03:29 AM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Front upper section formers now skinned, only taped in place for now to make cutting access hatch easier. Just need to complete forward nose section but this will be done when lower section has been skinned, easier to sand accurate shape in pink foam then.
Next, need to skin rear exhaust section and build in TE for wing stubs.
Old Apr 16, 2012, 12:54 PM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
I need some help, can anyone help with knowledge of the Navigation lights as I want to add these. Checked all over the Web but just can't find any information. Attached is a picture of the location of known lights to me, I have a few questions:
1) On the tail she carries two lights; one I’m guessing is strobe the other appears red? Was this solid red or flashing also at what point would this have been used?
2) Nose door carried three lights; clear, landing light (correct me if wrong) but not sure on the red and green/blue (again not sure of which colour). Was told these indicated when the arrester hock was down?
Wing tips are easy.
Was there any other lights know of that adorned the vixen I’ve missed?
Much appreciated for any info.
Old Apr 16, 2012, 04:32 PM
TANGOSIERRAROM is offline
Find More Posts by TANGOSIERRAROM
James L
TANGOSIERRAROM's Avatar
Beck Row Mildenhall
Joined Mar 2009
There is a little info here http://www.seavixen.org/resources/42...Electrical.pdf
might be of general interest http://www.seavixen.org/resources/42...icalManual.pdf
Source of these documents http://www.seavixen.org/index.cfm?fa...ntGeneric.home
Good luck with the model it looks great so far.
TANGOSIERRAROM is offline Find More Posts by TANGOSIERRAROM
Old Apr 17, 2012, 12:54 PM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Thanks Tangosierrarom, did find that site but couldn't open the Pdf's at the time. Will have a good read.
Old Apr 25, 2012, 12:35 PM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
After searching over, found the below Sim, U-tube video showing the lights in use:
1) Tail light is white constant. The red strobe seems to have been manually switched on/off by the pilot depending on situation and location so won’t be wiring it up and use a dud LED for effect.
2) Wing tips red and green.
3) Landing lights white. The sim shows two landing lights but I can only find photos with one so will go with the one and the two other lights that I believe relate to the arrester hook, again doing the same as for the strobe. Landing light will be wired to a micro switch so when I raise UC light goes off and on when lowered.
For wire I will be using Cat5e cable stripped down. Now waiting for delivery of my LED’s before I can begin.
Sea Vixen.wmv (6 min 39 sec)
Old Apr 30, 2012, 04:07 PM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Whilst waiting for the LED's decided to look at the retracts:
Bearers in place and notched to receive retracts…. Blast, should have checked first, Just noticed this evening that the former in front of wheel when retracted will prevent wheel from retracting. Thought of moving the bearers further back but this will prevent a smooth ‘roll back’ when taking off as the CG is already in front of F7 (next one in front of the one fouling wheel). Did contemplate a little redesign but I think it looks awful. So next job will be to cut away the area shown allowing correct wheel cover profile to be used, just got to be careful of spar tube on the other side.
Old May 06, 2012, 10:36 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
man, that's looking real nice.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old May 08, 2012, 11:48 AM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
thanks LuvEvolution7, slow progress at the moment; pace picked up at work and new projects on the go. some work has been done a photos taken, wil update soon as i have sufficiant work done deaming it worth posting.
Visited the 2012 Rougham LMA show on saturday, awsome day, took afew pics before my camera packed up.
Old May 08, 2012, 02:36 PM
James L
Beck Row Mildenhall
Joined Mar 2009
One year I am going to make it to Rougham.
Old May 08, 2012, 03:04 PM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Definatley worth the trip. Wings n wheels next, June 23rd and 24th.
http://www.wingsnwheels.net/
Old May 09, 2012, 03:31 PM
domll is offline
domll's Avatar
Norwich.uk.
Joined Oct 2007
Started to build up nose area, stringers first then planked with depron. Couple more piece to do for this evening. Hatch area now cut out; will cap the ends and sides with thin balsa sheet to make it a little sturdier, giving a crisper edge. At the tail end added some shaped depron ready for skinning.
Old May 09, 2012, 03:59 PM
Joined Dec 2010
i've got my wings and Wheels tickets See ya there...
Old May 10, 2012, 05:11 PM
kinghelichopter is offline
Find More Posts by kinghelichopter
unbreakable ? give it to me !
kinghelichopter's Avatar
Joined Oct 2010
im going too
nice build i'm sure its going to turn out great
dave
kinghelichopter is offline Find More Posts by kinghelichopter
Sea Vixen fly20 Non R/C Items (FS/W) 6 Dec 12, 2011 10:54 AM
Discussion Search for help on Chris Golds DH 110 Sea Vixen jettrainer Scratchbuilt EDFs 0 Jul 18, 2011 01:12 AM
Discussion Search for Chris Golds DH 110 Sea Vixen review jettrainer Electric Ducted Fan Jet Talk 2 Jul 17, 2011 04:17 PM
de Havilland Sea Vixen FAW.2 drawings. bipeflyer Electric Ducted Fan Jet Talk 8 Sep 02, 2003 05:56 AM
Sea Vixen or vampire BruceWilkerson Electric Ducted Fan Jet Talk 15 Jun 12, 2003 05:40 PM
