Old Feb 22, 2012, 06:16 PM
scottdearinger is offline
Find More Posts by scottdearinger
Gravity? No, the Earth sucks
scottdearinger's Avatar
United States, IA, Des Moines
Joined Apr 2011
Originally Posted by Eagle202 View Post
Scott
Why don't you get one of those swivel chairs that they have on a fishing boat. Just strap in and pivot. It would be easy on your back and allow quick direction changes.
Of course you could get real dizzy spinning back and forth.
Vince
AN EXCELLENT IDEA VINCE ! and I can ask Eckace to carry it around for me and set it up-WHAT FUN ! lol
THAT WILL COST ME A LOT OF BEER!!!
scottdearinger is offline Find More Posts by scottdearinger
Old Feb 22, 2012, 06:47 PM
Zaurak3 is offline
Find More Posts by Zaurak3
Gravity-Compliant User
Zaurak3's Avatar
Nebraska USA
Joined Mar 2008
Originally Posted by Terry Rigden View Post
You will be able to land a given aeroplane in a smaller place if you fit it with flaps and spoilers but my point is that the Easy star isnt designed for STOL operation. It's too heavy , the prop is in the wrong place and the controls are not powerful enough for really slow speed flight.
To get something in and out of half a soccer pitch with obstructions round it you will need something with half the wing loading of a standard easy star (4oz /sqft) a power/weight ratio better than 1.2 :1 and the fan up the front to blow air over the wing. A high lift wing section , big flapprons so you can harrier it in at high alpha
So yes you can modfiy an ES to land in a smaller space than a standard one but it wont be as good as a model designed for that task.
The ES is a good trainer or camera carrier but thats about it.
Terry
Terry - I won't disagree that there are other plane designs that are better suited to STOL operations, but we're not talking harrier flying here. I know that with the modest flaps I have, and a slight headwind (5 mph or more), the EZ* will drop rather abruptly into a small area. But, fair enough, there are better designs for it (I am in the process of building a Multiplex Fun Cub, that should fall into that category).
Even without flaps, the EZ* can be handled rather well in a confined space, as is demonstrated by Jurgen in his video (of course, it's a tribute to his flying skills as well).
MPX EasyStar Indoor Action (1 min 0 sec)
Cheers,
Roger
Zaurak3 is offline Find More Posts by Zaurak3
Old Feb 22, 2012, 08:09 PM
G550Ted is offline
Find More Posts by G550Ted
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
http://www.youtube.com/watch?v=d9TJ2mwS-Gs
Cheers,
Roger
I'll second that. Although my plane is a Bixler they fly the same. Like in the video, the key is to not make a normal straight in approach. Rather, land out of a circle or figure 8 pattern. It's very easy to keep it in close and land near your feet.
Ted
G550Ted is offline Find More Posts by G550Ted
Old Feb 23, 2012, 02:23 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Ted
I agree. But it is all about experience and skill.
I have both an EZ* and a Bixler. The 'light' EZ* I can land in a designated area close to me. The Bix that has flaps, is even better. With that I can come in with a slower and steeper approach.
Flypoppa is offline Find More Posts by Flypoppa
Old Feb 23, 2012, 04:55 AM
AshtonFlyer is offline
Find More Posts by AshtonFlyer
AshtonFlyer's Avatar
United Kingdom, England, Bristol
Joined Dec 2011
Talking of Bixlers *cough*, I noticed on one of their threads that a possible cause of flying off to the right was due to motor torque and an incorrectly-wired motor.
Could this be the issue with my EZII? Weather's too bad to try it at the mo'.
AshtonFlyer is offline Find More Posts by AshtonFlyer
Old Feb 23, 2012, 05:01 AM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
I don't know if it has been suggested, but have you done a test glide? This would tell if it is the motor or a control surface fault. Even a warp in the model.
Or have you flown it with power off in a glide, and if so what did it do?
If it was a incorrectly wired motor it would not work or it would be turning the wrong way.
Old Feb 23, 2012, 05:29 AM
Joined Dec 2011
That was my understanding to date too.
Not tried the glide yet - it's like a marsh around here, but I'll give it go when it's drier.
When throttled off, it levels up better. When launching at half throttle, it almost corkscrews right.
Old Feb 23, 2012, 06:05 AM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
That doesn't sound like a cause from the motor, then. The torque may assist that tendency, but a warp or misaligned control surface would be needed to make it corkscrew
pdiddyg40 is offline Find More Posts by pdiddyg40
Old Feb 23, 2012, 07:31 AM
Colonel Blink is offline
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
My tuppenceworth...
Powertrain-wise, my EasyStar has undergone a steady evolution from the original Permax 400 with 7 then 8 cell NiMH and stock prop, then on to a Keda 2700kV 2835 inrunner on 2S Lipos & a 6x4E; and now 3S Lipos still with the 2700kV motor & 6x4E. Each step has shown a steady increase in power, climb rate and ability to perform the sky gyrations that I laughingly pretend are aerobatics. My figures taken during the 2S to 3S mod were
2S Rhino 2150mAh 20C:
93% charge
72W @ 10.2A, giving 320g static thrust
3S Turnigy 2200mAh 20C
48% charge [as delivered from HK]
200W @ 19A, giving 700g static thrust
I'll admit I've only had one session with the 3S Lipos (a development supposedly in support of intended FPV), but on first launch (my normal 1/3 throttle, with full throttle as soon as both hands are back on the Tx), full throttle induced a 45 degree right bank which my slightly enlarged rudder could not correct until I backed off the throttle a little. Later climbs also required a healthy amount of left rudder to counteract the bank, but were less alarming as I was ready for it and didn't let it develop or gain inertia.
In my opinion, the sole reason for the right bank is caused by the clockwise spinning (seen from the rear) cylinder of air coming off the prop. By the effect of angles of attack etc, this increases the lift created by the left tailplane, reduces it on the right, and creates a rightward 'lift' force on the fin. In other words, it blows the empennage clockwise. This was not evident at the 70W on 2S, but has suddenly manifested itself on the 200W (nearly 3x the input power) of 3S. On full size a/c like the Piper PA28, full throttle (esp on take off) requires right rudder to keep it in a straight line for the same reason, so the effect is genuine, girlfriends!
I am reasonably (but not highly) experienced. Newbies who start with this set up may well not be mentally equipped or have the reactions to deal with it when they've lobbed it in the air and slammed the throttle to the firewall.
Also, although the climb rate is far greater than 45degrees and loops can be completed almost from stall speed s&l (all of which is a right lark), part of me thinks that the 2S set up is the most pleasant and best matched to what the EasyStar is.
I thank you....
PS The reaction to the torque of a clockwise running motor & prop would be to turn the model to the left.....
Colonel Blink is offline Find More Posts by Colonel Blink
Old Feb 23, 2012, 09:10 AM
G550Ted is offline
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
Quite true, but a very easy skill to master. Even for a novice, practicing slow circles and figure 8s is a great training exercise and really not that difficult. Moderate pitch and bank angles, and easy on the throttle is key. Well worth the effort and fun, too.
Ted
Old Feb 24, 2012, 02:00 AM
digitalCAM is offline
Find More Posts by digitalCAM
John
United States, WA, Mason
Joined Apr 2011
digitalCAM is offline Find More Posts by digitalCAM
Old Feb 24, 2012, 12:00 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Well isn't that what friends are for?
Besides you might have collided with his plane due to your limited mobility. That could have cost Eckace a lot more than a case of beer. (it is cheaper by the case by the way )
Vince
Eagle202 is offline Find More Posts by Eagle202
Old Feb 24, 2012, 04:50 PM
eckace1 is offline
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Yes it will!! But even funnier will be the pic of you in the back of my truck sitting in a boat with said chair
eckace1 is offline Find More Posts by eckace1
Old Feb 24, 2012, 05:15 PM
eckace1 is offline
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
I ordered a new fuse for my EZ as I have the blue wings and tail feathers that I wanted to keep as they provide better lift and flight over the grey.
Scott bought me some debonder hope it works as I have never used this stuff before.
One question is if it works how do I debond the debonder so that I might glue my tail feathers to my new fuse and make it hold?
I think it's flypoppa and nightrunners fault for Scotts wreck do to them not helping him with an FPV setup that way he could have seen that he was heading for the ground along with increasing his left stick.
Old Feb 24, 2012, 05:44 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
The white ones have the best lift.
Use denatured alcohol to debond the debonder. Dry it completely by letting it sit in a hermetically sealed room of 87.5 degrees F with 62% humidity for 87 days. It that isn't possible then just blow on it some.
Instead of over priced debonder you can use nail polish remover. I'm sure Scott has plenty of that. Try to get the generic brand that doesn't have anything else added to it but if it does the alcohol will remove it on cleanup.
Or use a 5400psi pressure washer.
2500GENE is offline Find More Posts by 2500GENE
For Sale NIP proline tires with foams and ultra foams 48chebbie Cars - Trucks and Parts (FS/W) 0 Dec 09, 2011 03:47 PM
For Sale 1.9 Dark Soul wheels with Cobra tires and memory foams ATCH Cars - Trucks and Parts (FS/W) 0 Nov 14, 2011 05:14 PM
Discussion Different foams south.tx.dead.I Foamies (Scratchbuilt) 2 Sep 27, 2011 02:40 PM
Discussion Foams Guz Composites Fabrication 10 Apr 09, 2011 07:25 AM
Discussion Depron/Wall Foams highdesert Scratchbuilt Indoor and Micro Models 21 Mar 19, 2011 09:57 PM
