Old Jan 26, 2012, 07:56 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by 2500GENE View Post
I do not feel bad for Scott...or anybody for that matter. I'm incapable of most human emotions. He is a bunch of letters on a flat screen that wears a funny hat and flys a EZ* so I allow him to exist in my mind. You on the other hand have no face or funny hat and may not exist at all since you never sent up a picture of you and your EZ*. You could be programed random access memory posting learned responses to data input as far as I know. Classification is H4 which is 4 tiers above Invalid Response. A valid picture would change this to at least a B5 rated carbon based life form without a funny hat. The choice is yours.
Your talking funny Gene. Gone off your meds again?
Actually I shouldn't be posting here at all since I do not have the privilege of owning an EZ. Although it was the first RC plane I really wanted to get a few years ago. I just didn't have the cash to do it then. So last year I had to settle for a SkySurfer.
Vince
Eagle202 is offline Find More Posts by Eagle202
Old Jan 26, 2012, 08:04 PM
Wolveslayr is offline
Find More Posts by Wolveslayr
Team Daedalus
Wolveslayr's Avatar
Joined Jun 2008
Originally Posted by Colonel Blink View Post
Personally, I quickly went over XT60s - easier to seperate and to solder neatly.
Cue four pages of connector discussions...
Half my XT-60's it takes a football team to separate. Does anybody know a lubricant (graphite like for locks) that would be non conductive. Seriously, love em hate em when all my weight lifting friends have to help pull em apart.
Todd
Wolveslayr is offline Find More Posts by Wolveslayr
Old Jan 26, 2012, 08:06 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Vince
No, you're staying Vince. You are always a positive kind of guy and great to have around...besides, I may need some Gator bait someday.
Send a pic.
2500GENE is offline Find More Posts by 2500GENE
Old Jan 26, 2012, 08:07 PM
NightRunner417 is offline
Find More Posts by NightRunner417
Fly Like A Thing Posessed!
NightRunner417's Avatar
USA, FL, Fort Myers
Joined Nov 2010
Todd, I have the exact same problem but only with certain breeds of XT60s. The pairs I got from eBay all work great together, and the pairs I got from HK work great together... and they work with each other great together... but I got a parallel Y adapter and wow do they fit tight with the connectors on that thing, hard to pull apart. It's the first time I ever had a problem with XT60s being too tight, versus almost always with Deans.
One thing - be careful how hot an iron you use to do the soldering on them. The plastic can in fact melt, and this can misalign the connector parts. To prevent this, do your soldering with a pair actually mated together (so that the parts are braced) or use a lower wattage iron. I got a cheap iron from Wally World last month, and it's supposed to be only 20 some watts, but let me tell you that thing is a MONSTER, easily 40 watts guessing based on how viciously hot it gets. It will easily melt the plastic on both Deans and XT60s, I have to be really fast and careful unless I'm soldering very heavy gauge wire onto the connectors.
Rick NR417
NightRunner417 is offline Find More Posts by NightRunner417
Old Jan 26, 2012, 08:18 PM
Casey_S is offline
Find More Posts by Casey_S
Casey_S's Avatar
Joined Mar 2011
Originally Posted by AshtonFlyer View Post
I use identical batteries - they came with Deans (different source though)
Where from?
Casey_S is offline Find More Posts by Casey_S
Old Jan 26, 2012, 08:32 PM
G550Ted is offline
Find More Posts by G550Ted
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
Todd
Todd,
Plain old Vaseline is a great (and cheap) non-conductive lubricant. I keep a small pill bottle with some in my battery box along with some tooth picks to occasionally lube those tight fitting connectors.
Ted
G550Ted is offline Find More Posts by G550Ted
Old Jan 26, 2012, 08:34 PM
USA, FL, Fort Myers
Joined Nov 2010
So, I got my mod work done with moving electronics over to the new belly compartment. I ended up leaving the RX where it was (in the nose), and moving the OSD and the elevator and aileron gyros into the belly cavity. I also completed the changing of the motor mount, so that the motor now hangs off the rearward side of the mount.
Between the two modifications, I cleaned up a lot of the nose compartment clutter and also shifted the CG back to the tail considerably. Even with the GoPro on as FPV camera/HD recorder, the CG was still very tail heavy and I ended up losing a very satisfactory 32 grams worth of tail weight. I had a little trouble with battery cabling until I tried simply turning the battery around, and then everything worked out very neatly.
I like! It decluttered the wiring very nicely AND shed me some weight, and I'm very close to ready for a GoPro FPV maiden on Sunday or Monday morning.
Rick NR417
Old Jan 26, 2012, 08:43 PM
eckace1 is offline
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Ah the State fair has taken you over as we told you not to rummage through the varied industry building or the sheep barn. But my friend will I'm sure back you up as he has a fetish for Never Never land.
I will or someone will provide a pic but It's not my fault when your screen cracks or it causes uncontrolled mass hysteria on the Ez mind probe.
Of all people I thought you would understand trying to fly an EZ in a beer haze.
eckace1 is offline Find More Posts by eckace1
Old Jan 26, 2012, 08:55 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
Originally Posted by G550Ted View Post
Todd,
Ted
Bet I know where you keep the large bottle of it.....
Anyway, I never used XT-60s as I still use the good old Deans.
Mate them when soldering then add some dimples on the sides with the iron when done to grip them better. Works for me.
Old Jan 26, 2012, 09:01 PM
scottdearinger is offline
Find More Posts by scottdearinger
Gravity? No, the Earth sucks
scottdearinger's Avatar
United States, IA, Des Moines
Joined Apr 2011
Name: Snapshot 2 (1-26-2012 8-34 PM).png
Description:
Name: Snapshot 3 (1-26-2012 8-35 PM).png
Description:
Name: Snapshot 4 (1-26-2012 8-36 PM).png
Description:
Name: Snapshot 1 (1-26-2012 8-25 PM).png
Description:
okay Gene- I snagged some snapshots from videos of carbon based Lifeform Eckace1 take your pic of pics- best he could do was worst I could find-lol
scottdearinger is offline Find More Posts by scottdearinger
Old Jan 26, 2012, 09:12 PM
Brian_ is offline
Find More Posts by Brian_
United States, TN, Nashville
Joined Dec 2007
Originally Posted by photopilot View Post
I had the ezstar all put together and ready to fly but did not like the way the tail made it on. I had sprayed the activator on the plane portion then put med CA on the tail structure. As I was inserting the tail peice I felt the glue start to setup and jammed the tail in as fast as I could but ended up with a crooked layout. It was close but not perfect.
I just poured debonder in and separated the tail structure. Before I rejoin the two parts, tail and fuselage how should I clean up the pieces? How can I prevent a repeat performance? Should I skip the accelerator? Does the accelerator add strength or just speed in glue setup?
Ca is brittle already, but activator makes it even more weak. It's just meant for quick curing.
Brian_ is offline Find More Posts by Brian_
Old Jan 26, 2012, 09:13 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
I suppose this one will work....even though his fly is open.
Old Jan 26, 2012, 09:15 PM
eckace1 is offline
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Attachment 4583773
Attachment 4583774
Attachment 4583775
Attachment 4583776
Thanks Man a true friend
There ya go .25 Gene
Old Jan 26, 2012, 09:29 PM
eckace1 is offline
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
That's not a corn dog
But hay we made post #12 Priceless.
Old Jan 26, 2012, 11:34 PM
AshtonFlyer is offline
Find More Posts by AshtonFlyer
AshtonFlyer's Avatar
United Kingdom, England, Bristol
Joined Dec 2011
Originally Posted by Casey_S View Post
Where from?
GiantCod RC, UK
Talking of opening up the belly, this is what I'd love to get to fit in my EZ at a later date:
Pic doesn't show it so well, but it's fully retracteable.
A work in progress over at http://www.rcgroups.com/forums/showthread.php?t=1564878
AshtonFlyer is offline Find More Posts by AshtonFlyer
For Sale NIP proline tires with foams and ultra foams 48chebbie Cars - Trucks and Parts (FS/W) 0 Dec 09, 2011 03:47 PM
For Sale 1.9 Dark Soul wheels with Cobra tires and memory foams ATCH Cars - Trucks and Parts (FS/W) 0 Nov 14, 2011 05:14 PM
Discussion Different foams south.tx.dead.I Foamies (Scratchbuilt) 2 Sep 27, 2011 02:40 PM
Discussion Foams Guz Composites Fabrication 10 Apr 09, 2011 07:25 AM
Discussion Depron/Wall Foams highdesert Scratchbuilt Indoor and Micro Models 21 Mar 19, 2011 09:57 PM
