Old Feb 13, 2013, 04:42 PM
mike_o is online now
Find More Posts by mike_o
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
Originally Posted by Martin. View Post
Thanks! All three very worth watching, just beautiful! What props are you using, are they 3-blades? I always wonder if it would be economical to have two large props instead of one small prop at the back. It costs extra weight for ESCs and motors but on the other side it could be more efficient.
About video editing, I like Kdenlive a lot and it's for free! It's not for Windows though.
Martin
Martin,
thank you. I don't think two motors are more efficient than one, but I just wanted to try a twin. The sound is so sweet
When moving the motors in front of the CoG instead of rear as the original, you also need less weight in front; A smaller battery will now balance the plane. That way, you can lower AUW down to 500gr. On the other hand, you loose abilty to carry heavy batteries and FPV equipment.
Normally, I use counter rotating 6x4 APC props for this plane, as they seem the most efficient and well balanced. But since I needed a bit extra clearance for the snow, I chose 5x4.5 props, and I chose three-blades to compensate for the lower thrust per blade.
They come in cw/ccw pairs, many sizes, both as 2 and 3 blade version, and from various ebay vendors. Check the attached pic - I recommend them.
The 8A HK ESCs are mounted on the nacelles, and they really don't weigh much. Current consumption is 4A max per motor static @ 3S, so I guess the plane will cruise at 3-4A total, almost like it's standard, single motor sister.
EDIT: Col. Blink: Thanks for the hint to the attachment function, which I had not been aware of. This will save me the trouble of uploading pics to photobucket first.
mike_o is online now Find More Posts by mike_o
Last edited by mike_o; Feb 14, 2013 at 01:49 AM. Reason: Attaching pic rather than embedding it
Old Feb 14, 2013, 01:38 AM
Colonel Blink is offline
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Mike: I love the EZ Twin, and wouldn't mind doing one myself! You are imparting a lot of great info here, but can I ask a favour? Could you use the 'Manage Attachments' button instead of embedding photos in the text? It makes it a pain in the backside when you are reading a post and it keeps hopping off the screen because a previous post has loaded another photo!!!
Cheers!
Colonel Blink is offline Find More Posts by Colonel Blink
Old Feb 14, 2013, 03:25 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Mike-O. For video editing I use 'windows movie maker' or 'Windows live'. It's free and works OK when you sus out the kinks.
Flypoppa is offline Find More Posts by Flypoppa
Old Feb 14, 2013, 08:18 AM
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
I do have the Windows Movie Maker, but I can't get it to work with the file types, I get from my 808 #16 camera and from my groundstation.
Also, I like the slow motion / fast forward feature of the AVS editor, and I don't think Movie Maker can do that?
Old Feb 14, 2013, 10:47 AM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
The file types of the # 18 are .mov or you can load on a FW that gives you .avi.
I don't know about the #16.
Old Feb 14, 2013, 07:39 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
My #16 creates "avi" type files. I then use videopad software to convert them to "wmv" type files.
Eagle202 is offline Find More Posts by Eagle202
Old Feb 14, 2013, 08:07 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Conversion of video files degrades the quality of the original format. You can load many file types into WMM and save them in another format then re load the converted file for editing but it will be degraded as compared to the original.
Your videopad software is actually an alien being. Get it out of your house as soon as possible.
2500GENE is offline Find More Posts by 2500GENE
Old Feb 14, 2013, 08:56 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
Really? The software has worked pretty well for me especially allowing for editing a big file down to something I can post on you tube. Maybe having something not of this world isn't a bad thing.
Old Feb 15, 2013, 02:44 AM
mutski is offline
Find More Posts by mutski
mutski
United States, AK, Fairbanks
Joined Jan 2011
Mike-O - So you're making international flights? I see your video in Google Earth. Here's the spot!
mutski is offline Find More Posts by mutski
Old Feb 15, 2013, 04:56 AM
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
Hehe - well spotted
Old Feb 18, 2013, 06:25 AM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
I got a goal with my Easystar.
https://www.youtube.com/watch?featur...&v=XoLlteKgJcA
Old Feb 18, 2013, 07:39 AM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Mount Question
I am changing the mount on my ES and have one of these. I was wondering what kind of glue would be best for gluing the aluminum base tube into the foam nacelle?
http://www.headsuprc.com/servlet/the...ustable/Detail
Rickochet is offline Find More Posts by Rickochet
Old Feb 18, 2013, 08:13 AM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Gorilla glue, or gator glue, double sided sticky tape.
Old Feb 18, 2013, 11:13 AM
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
I guess the tube section is a pretty tight fit in the pod (nacelle), so I wouldn't bother glueing that part - it only makes it impossible to take apart again. I'd probably try applying a little hot glue to the pod rim (where the alu flange sits) and then push in the mount.
Apply hot glue to the foam, not to the alu - it will stiffen before you can do anything.
Old Feb 18, 2013, 11:23 AM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
It would have to be a very tight fit for it not to turn without some sort of fixative when the motor is running.
For Sale NIP proline tires with foams and ultra foams 48chebbie Cars - Trucks and Parts (FS/W) 0 Dec 09, 2011 03:47 PM
For Sale 1.9 Dark Soul wheels with Cobra tires and memory foams ATCH Cars - Trucks and Parts (FS/W) 0 Nov 14, 2011 05:14 PM
Discussion Different foams south.tx.dead.I Foamies (Scratchbuilt) 2 Sep 27, 2011 02:40 PM
Discussion Foams Guz Composites Fabrication 10 Apr 09, 2011 07:25 AM
Discussion Depron/Wall Foams highdesert Scratchbuilt Indoor and Micro Models 21 Mar 19, 2011 09:57 PM
