Old Feb 09, 2013, 03:29 PM
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
Yes thanks I'll do that
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Feb 09, 2013, 08:32 PM
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by eckace1 View Post
Terry you might want to look at Tom franks post on the key fobs as some sd cards aren't compatible with them.
Interesting that Flypoppa's # 18 cam doesn't work with a class 10 card. Unless it isn't a high def camera it should have worked.
I used a class 4 and 6 card with my low def # 8 camera but went to a class 10 for my # 16 which does a really nice job.
You have to be careful that you actually got the camera you want. I purchased what I thought was a # 11 but got a # 14 which was a piece of junk.
Eagle202 is online now Find More Posts by Eagle202
Old Feb 09, 2013, 10:17 PM
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
There is no benefit of using a faster write speed card with a camera then is required for the unit. He also probably got a bum camera. The fact that he is older and uglier then me also worked against him .
2500GENE is offline Find More Posts by 2500GENE
Old Feb 10, 2013, 03:46 AM
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Oooh the insults that come out of this fat pot belly friend of mine.
As for the camera that I used on the Easystar. (On topic). There are a few cases where a class 10 worked. It depends on the make it seems.
I first used the class10 as I already had it.
The class 4 is the recommended one to use. Also a 4 gig is sufficient as with the on board battery only lasts about 1 hour.
With my class 4 and 4 gig I got 56 minutes on a static test. The battery was flat, and I still had a few meg left on the card.
Flypoppa is offline Find More Posts by Flypoppa
Old Feb 10, 2013, 11:49 AM
Eagle202's Avatar
Joined Aug 2011
Flypoppa
Just ignore my happy and rotund friend from Southern Florida. It's the sun that makes him say those nasty things. (like he did last month to me. )
Looks like you found a good combination for your camera. Whatever works is the right path. My # 16 works good with a class 10 and # 8 with a class 4.
I did forget to tell you that the video of your EZ was pretty nice to watch. You have a really nice area to fly as long as you don't try to make a goal during a landing.
Old Feb 10, 2013, 04:47 PM
mike_o's Avatar
Denmark, Capital Region of Denmark, Charlottenlund
Joined Jan 2012
I did some 20 kilometers of EZ FPV flying today. Mostly over water:
Very power efficient: 18:20 min and 9.4km on 550mAh
Second flight was even longer, but the mAh meter got an off-set as I switched on the OSD before the ESC (leaving the current meter floating freely). Also had to use more power to fight heavy gusts of wind on return flight.
Visiting Sweden:
Long way home:
Kronborg castle
Very pleased with the set-up.
mike_o is offline Find More Posts by mike_o
Old Feb 11, 2013, 07:18 PM
Gravity? No, the Earth sucks
scottdearinger's Avatar
United States, IA, Des Moines
Joined Apr 2011
Visiting Sweden:
Long way home:
Kronborg castle
so pleased you painted out your Altitude-lol good show !
scottdearinger is offline Find More Posts by scottdearinger
Old Feb 11, 2013, 08:11 PM
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
20k very impressive.
Also from the sceen shots it looks like a very nice place to fly.
Did you pixilate the alt as not to make someone mad? LOL
eckace1 is offline Find More Posts by eckace1
Old Feb 12, 2013, 09:08 AM
mike_o's Avatar
Joined Jan 2012
ekace1, scott,
thank you - Yes, I have decided to try not to offend anybody. Video link available on request.
I'm really pleased with the ES performance, It cuises happily along at 3-4 amps, and will do 60km/h at 6-7A if need be. I believe the key is a good motor/prop combo and reasonable aerodynamics. I should be able to get 40-60 minutes FPV flight time on my current 2300mAh pack
Old Feb 12, 2013, 02:16 PM
Martin7182
Martin.'s Avatar
Bussum, Netherlands
Joined Oct 2009
3s lipo I assume? So 3-4 amps means about 40W. Nice!
Martin
Martin. is offline Find More Posts by Martin.
Old Feb 13, 2013, 09:12 AM
Lapino's Avatar
Deutschland, NDS, Braunschweig
Joined Mar 2011
ekace1, scott,
Hi mike_o,
can you tell me something about you setup?
I'm searching for a good motor-prop combo for my new Easystar 2.
I'll be flying fpv with a gopro...just to keep that extra weigth in mind
Any other suggestions are welcome
thanks in advance
Lapino is offline Find More Posts by Lapino
Old Feb 13, 2013, 09:39 AM
mike_o's Avatar
Joined Jan 2012
Originally Posted by Lapino View Post
Hi mike_o,
thanks in advance
Lapino,
for the ES2, I find the stock folding prop hard to beat. In my ES2, I use a fairly cheap 2826mm 1000kv outrunner, which is a bit smaller and less powerful than the MPX recommendation (2830mm 1200kv, i think). Still, I get 45 degree climb with my setup, and the benefit of a smaller motor is improved efficiency. I don't think your GoPro will make a major impact on performance, if you mount it as flush as possible.
Keep us posted on your progress!
Old Feb 13, 2013, 09:55 AM
mike_o's Avatar
Joined Jan 2012
touch'n'snow
Superb weather today: I fitted my EasyTwin with smaller 5x4.5x3 props (for better ground/snow clearance) and took her for a low and slow LOS flight.
After many fine touch'n'goes, I got carried away / over confident
But miraculously the Easy emerged from the snowcloud in level flight
A short video:
EasyStar with camera. Aileron and twin mod. Touch'n'snow... (1 min 11 sec)
A longer, unedited video, note clipping the rushes at 2:00
EasyTwin low 'n'snow (0 min 0 sec)
This is what the plane looks like:
EasyTwin (0 min 0 sec)
I promise, I will get that video editing SW now, and make some nice short videos. Any recommendations? I used AVS, which worked fine, but the license ran out, and I refuse paying an annual fee for basic SW
Old Feb 13, 2013, 11:35 AM
Lapino's Avatar
Joined Mar 2011
Thank you for your answer
Very good looking easytwin
I was thinking of a motor mount to use 9x5 props ...
Did anyone try the stock bl motors with 9x5 props?
Old Feb 13, 2013, 04:08 PM
Martin7182
Martin.'s Avatar
Bussum, Netherlands
Joined Oct 2009
A short video:
http://youtu.be/7Z0lsbwtCm8
http://youtu.be/54dCqX_4K8E
http://youtu.be/wIN_jqE-4dc
Thanks! All three very worth watching, just beautiful! What props are you using, are they 3-blades? I always wonder if it would be economical to have two large props instead of one small prop at the back. It costs extra weight for ESCs and motors but on the other side it could be more efficient.
About video editing, I like Kdenlive a lot and it's for free! It's not for Windows though.
Martin
For Sale NIP proline tires with foams and ultra foams 48chebbie Cars - Trucks and Parts (FS/W) 0 Dec 09, 2011 03:47 PM
For Sale 1.9 Dark Soul wheels with Cobra tires and memory foams ATCH Cars - Trucks and Parts (FS/W) 0 Nov 14, 2011 05:14 PM
Discussion Different foams south.tx.dead.I Foamies (Scratchbuilt) 2 Sep 27, 2011 02:40 PM
Discussion Foams Guz Composites Fabrication 10 Apr 09, 2011 07:25 AM
Discussion Depron/Wall Foams highdesert Indoor and Micro Models 21 Mar 19, 2011 09:57 PM
