Old Dec 07, 2012, 07:57 PM
l.aluffi is offline
Find More Posts by l.aluffi
Italy, Piedmont, Asti
Joined Jun 2012
Originally Posted by scottdearinger View Post
here is a crash video using gopros and hk wing cam- for your comparison .. also funny... was a bad day for easystars- but a good day for crash video--from mid summer
http://www.youtube.com/watch?v=qoBo-Ktd6NE
Nice video. Why the wing ripped apart?
l.aluffi is offline Find More Posts by l.aluffi
Old Dec 07, 2012, 08:09 PM
eckace1 is online now
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
It was a glue joint from a previous crash.
Don't use ca. If I had to do it again I would use 3m-90.
eckace1 is online now Find More Posts by eckace1
Old Dec 07, 2012, 08:15 PM
l.aluffi is offline
Joined Jun 2012
Originally Posted by Gabek View Post
Hi,
I have a ES2 that is leaning to the left if no throttle, and to the right if i aply throttle.
Do you have any idea?
Thx,
Gábor
Mine started to do the same (but with inverted sides) after a crash. Before it was like on rails.
Wings was little cripped near the joint, in the back side. I've stretched them back in the original shape with hot water, then I've put two small magnet to keep them tight. Now it flies straight.
Another things was that, during crash, the motor nacelle has been ripped away. I've had glued it back as good as possible but not as before. Maybe there's a fraction of degree of difference and this generates the anomaly.
Old Dec 07, 2012, 08:16 PM
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Originally Posted by kov16 View Post
I looked at some videos taken with the hobbyking wing cam and the way the camera changes for different light conditions is horrible. You can actually see it refreshing when it's adjusting the contrast and brightness. I looks like the #16 808 cam is much better in this area.
I might agree during low sun level but unless you compare the same flight with both cams you wouldn't know.
I have and they are about the same.
There are other things to consider though and the hk wins hands down.
Now there is a hkv2 that we are testing and it looks like it will be vastly superior to even the #16 and hk1 but it comes with a price.
Old Dec 08, 2012, 05:33 AM
Colonel Blink is online now
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Mine isn't - it's terrible. And it vignettes.....
My #16 takes great film in bright light conditions; but even under an overcast (normal for the UK) it's performance leaves summat to be desired.
Colonel Blink is online now Find More Posts by Colonel Blink
Old Dec 08, 2012, 07:17 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Oh! I am not happy what you are saying...
I have just received my HK cam. 3 days from UK warehouse. No instructions.
What's that thing on the front next to the lens that turns round. I recon I need to make a case for it.
Is there a link for instructions for this thing?
Flypoppa is offline Find More Posts by Flypoppa
Old Dec 08, 2012, 08:06 AM
Martin7182 is offline
Find More Posts by Martin7182
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
Flypoppa,
Look under the files tab of the international (not UK) HK wing cam:
http://www.hobbyking.com/hobbyking/s..._5MP_CMOS.html
There's a bunch of manuals there.
Martin
Martin7182 is offline Find More Posts by Martin7182
Old Dec 08, 2012, 08:20 AM
scottdearinger is offline
Find More Posts by scottdearinger
Gravity? No, the Earth sucks
scottdearinger's Avatar
United States, IA, Des Moines
Joined Apr 2011
its not that bad- we face ours downward a bit and edit out the sky shots to some degree- every 40 dollar cam has some short falls...
scottdearinger is offline Find More Posts by scottdearinger
Joined Apr 2011
merry Christmas !
http://www.jibjab.com/view/wrZoqJnDT...urce=Facebook&
Old Dec 08, 2012, 08:26 AM
Joined Apr 2011
that is a vibrator - it shakes when you turn it on and start or stop a video--
push and hold rear button(furthest from lens) until a light comes on- then push middle button briefly- a second light will flash and continue to flash while it records- hit middle button again to stop recording- and rear button hold down to turn it off
Old Dec 08, 2012, 08:43 AM
Joined Apr 2011
heres a link to HK cam info
http://www.youtube.com/watch?NR=1&v=...ture=endscreen
This camera is awesome for the budget. Very easy to use after you got the buttons order.
1) Press the button far from the lens for 2 seconds to turn it on (blue led). In a few seconds the vibrating motor will confirm that the camera is ready to go.
1.5) added by scott- if you are going to record video- skip #2 as it comes up ready for video-go straight to #3
2) Select the mode using the same button:
Blue - record video
Red - photo.
Blue / Yellow - record video automatic with any camera move.
Red / Yellow - the same, but for photos.
3) Press the middle button to start/stop recording or to take a photo.
4) To turn it off press the button far from the lens again for 2 seconds. If you forget the camera on it will turn off after 3 minutes.
The camera was design to record with the buttons up, so it´*s better to use it on the top of the plane. (put your Velcro strip on the battery)
Well, after recording you could watch the movies (avi) on your TV or computer. The computer is the only way to erase and copy the videos and you just need to connect via USB. It works very well on a PC or MAC.
Using a TV
Connect the camera cable to any Video Input on your TV. The default setting is for NTSC video, so no problem. You could change this and many other settings using the "camera´*s tv menu".
1) The button closer to the lens is a menu selector. Press it for 2 seconds and you bring the menu up.
2) Use this button and the middle one to select options. (including set date/time stamp or eliminate it)
i copy and pasted this info for you guys-- seems accurate..
Old Dec 08, 2012, 10:02 AM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Thanks Scott. Most of that is good to go. But how do I get to the menu? In the UK our TVs are PAL. I have tried to hook up to my TVs but none of then see the cam. (Unless some one in the UK know better).
Is there a way I can access the camera menu via a computer?
Is there a programe some place that will allow me to do that.
I expect I am not seeing the obvious.
Old Dec 08, 2012, 10:49 AM
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
http://www.hobbyking.com/hobbyking/s...X494985X38.pdf
This might help
Old Dec 08, 2012, 11:00 AM
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Scott is also testing the hk wingcam2 and from the first few flights with it it looks like a winner.
We need to do more flights in better light and compare it to the hk1,and gopro .
We flew it the first time in heavy fog but it preformed great.
Old Dec 08, 2012, 11:58 AM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Flypoppa has been in a heavy fog for years.....even when the suns out.
2500GENE is offline Find More Posts by 2500GENE
For Sale NIP proline tires with foams and ultra foams 48chebbie Cars - Trucks and Parts (FS/W) 0 Dec 09, 2011 03:47 PM
For Sale 1.9 Dark Soul wheels with Cobra tires and memory foams ATCH Cars - Trucks and Parts (FS/W) 0 Nov 14, 2011 05:14 PM
Discussion Different foams south.tx.dead.I Foamies (Scratchbuilt) 2 Sep 27, 2011 02:40 PM
Discussion Foams Guz Composites Fabrication 10 Apr 09, 2011 07:25 AM
Discussion Depron/Wall Foams highdesert Scratchbuilt Indoor and Micro Models 21 Mar 19, 2011 09:57 PM
