Old Dec 02, 2012, 04:58 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by 2500GENE View Post
Hello all.
It's December and getting close to the near year. This is the time of year we generally vote in a new thread starter and that poor smuck has to create a new thread for 2013, copy over all the links from page one (most are out dated) and I close this one.
The way I see it there are 3 things that can happen.
1. Vote in a new thread starter and let him create and maintain the 2013 thread and I close this one on December 31, 2012.
or..
2. Leave this one as is and let it go on another year.
or..
3. The world will end on December 21, 2012 and all this will be irreverent to most of you. Of course I will survive as I have survived 35 years of marriage with my wife so something as mundane as a direct asteroid strike on my house would be nothing more then a minor inconvenience for a few days.
So let me know what Ya'll wanna do...(southern talk)
All opinions are welcome
Gene
I vote # 2 to let this go on for another year or until Gene declares the end of the world has arrived and his responsibilities for this thread are over.
Of course we could then all get drunk and vote someone to start a new thread as long as we can brow beat him like we did the present thread starter.
Eagle202 is offline Find More Posts by Eagle202
Old Dec 02, 2012, 07:37 PM
travellinjack is offline
Find More Posts by travellinjack
Chicago, USA
Joined Dec 2010
rudder servo fail hs-81; why?
Hello all,
So I got about 15 hoursof flying time on my recently built easystar, and today the rudder servo failed . Luckily, I got the plane down without any damage, but I don't know why the servo failed.
plane specs:
stock 400 brushed motor
greatplanes electrify C-25 ESC
2cell 2450 mah lipo 30C
servos Hitec HS-81
The servo is basically frozen, and does not move at all or react in any manner when the control stick is moved.
I opened the servo casing, and noticed a strong 'electrical' smell (not necessarily burnt but 'electrical smell '(sorry, I don't know how to explain this odor) from the servo. The internal wires seem to be connected and not damaged.
I have not had any rough landings or crashes to date(not including todays fail), so the servos have not been abused from crashes.
I am not happy with the control rods for both the rudder and elevator on this plane, as I feel the design puts more stress on the servos than is necessary. (ie the foam itself being the hinge) But I showed my plane to other pilots at the field today and they felt that the rudder did not seem to bind enough to cause problems with the servo.
BTW, the servo does not appear to be stripped, as other pilots have advised me that the plastic geared hs-81 has that problem sometimes
These are cheap servos (costing $13-18) and I don't mind replacing it, but I really don't want a servo to fail again. I got lucky today that the plane was not lost or damaged badly . I need to find out why the servo failed.
I bought the servos and esc from rcplanet.com
My questions are:
1. Has anyone had a HS-81 servo fail like this (only 15-20 hours of use)?
2. Can the ESC be at fault here? It is a quality ESC, but who knows?
3. Any thoughts on why it failed?
4. Should I consider other servos for this plane?
BTW, my plane flies beautifully. I got the CG per manual just right, and have been hunting thermals for the last few weeks. The plane has enough power with this stock motor, and I've been getting 45min-60min flying time on my battery pack (lots of time with the motor shut off). Prior to todays mishap, I have been very, very happy with my EZ(1).
thanks in advance for any advice you can offer on my servo problem
travellinjack is offline Find More Posts by travellinjack
Old Dec 02, 2012, 09:54 PM
NightRunner417 is offline
Find More Posts by NightRunner417
Fly Like A Thing Posessed!
NightRunner417's Avatar
USA, FL, Fort Myers
Joined Nov 2010
Hi Travellinjack,
I wouldn't think it would be anything to do with the ESC unless the other servo and/or the receiver were blown as well. It sounds to me like you just got a bad one in the pair. Perhaps the gears bound up and caused the motor to fry, or something blew on the controller board inside the servo. I'm pretty sure that the Hitec HS-81s have a good reputation, but not every servo out of a mass production mound of them is going to be a good performer and long lived. Sometimes you just get unlucky.
I would test the outputs of the receiver by switching the remaining good servo onto the other channels and seeing if it still works properly. If that test goes well, then you know:
1) Your ESC is fine, because if it wasn't, you'd have a lot more trouble than one dead servo.
2) Your receiver is fine, because it works...
3) Your remaining servo is fine, also because it still works...
and...
4) You got a bad servo, because it's the only part that failed.
Finally, replace it with your servo of choice, and be glad that you got the random part failure out of the way for who knows how long, and also be glad that your plane and other parts are fine. Do be sure to check your linkages, especially the rudder linkage, for any binding, and fix it if needed, and then just move on and fly your plane knowing you dodged a bit of a bullet.
I crashed my very first EasyStar after only a couple of weeks because I forgot the horn screw in the rudder servo, and talk about a mess... It worked its way apart and she spiraled 50' down to nose into hard packed sandy dirt and took a lot of damage. I was very new back then and didn't really know what to do in those last seconds, so I probably made it way worse than it needed to be. You got off easy! ;-)
Oh, and about other servos. I've used both HXT900s and 939MGs on my EZ*s and have had exactly one of each fail on me, though with the HXT900 it stripped due to a crash and with the 939MG it stripped because I was experimenting with it on an application way too harsh for it. I think they are both great servos for EasyStar control surfaces, plus they are insanely cheap. I am presently using an HXT900 for the rudder, and 939MGs for the elevator and ailerons. I'd be going 939s all the way around but I was one short, lol.
Rick NR417
NightRunner417 is offline Find More Posts by NightRunner417
Old Dec 03, 2012, 04:24 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Travelinjack. It is just one of these things that happen with these things. You were lucky that your EZ* survived.
I have my EZ*s (got 3 all1s) that are trimmed to go into circles if anything fails. So they should not fly off too far.
You mention the 'foam hinge'. Is it stiff? Then work it up and down a bit to loosen the foam. The control rods are normaly good and run smooth. Again check them for free running.
I must admit that most of my servos are cheap ones and had very few problems.
Flypoppa is offline Find More Posts by Flypoppa
Old Dec 03, 2012, 07:06 AM
USA, FL, Fort Myers
Joined Nov 2010
Wanna get this in before Gene does anything bizarre to the thread...
Yes, very long... almost 40 minutes in total so this is kind of my "grand finale" for the year, you could say. I wanted to capture the nuances of the extensive testing for the day, and also wanted to have some fun with a well flying plane, so there it is. I neglected to mention in the video that I was also testing the idea of placing the entire VRX and its antenna up on my usual PVC pipe mast, so actually there was more testing going on than just the changes to the plane. She flew just SO well, I was really thrilled. Wind wasn't as strong as I wanted for the testing, but I still had basically a few mph worth with a little ground turbulence. Next time out, I want it to be wild and crazy so I can see how my changes pay off in rough conditions. Based on what I got from these two flights, however, I am already impressed.
Anyway, off we go. Watch for the digger! ;-)
PhoenixStar Flying Day 11-26-12: Intensive Testing At C Field, Part One (18 min 20 sec)
PhoenixStar Flying Day 11-26-12: Intensive Testing At C Field, Part Two (19 min 12 sec)
Stats:
1st Flight: 15 mins, max ground speed 95kph / 59mph, max LOS distance 919m / 3015', max altitude 112m / 367'. Estimated average current consumption: 10.8A based on flight time vs. pack recharging results.
2nd Flight: 18 mins, max ground speed 107kph / 67mph, max LOS distance 547m / 1794', max altitude 214m / 702'. Estimated average current current consumption: 9A based on flight time vs. pack recharging results. The lower amount of average current consumption is due to extra time spent gently climbing and then soaring back down unpowered. I'm a bit surprised that my power runs didn't overwhelm this factor.
No data this time regarding round trip distances because of the OSD being reverted to factory settings. In defaults, it doesn't log the GPS points!
Also: Just a general shout out to anyone with videos going that they'd like to see in post #6 of this thread. Shoot me a PM and give me your link, and I'll add you to the pile. Please restrict yourselves to videos shot within 2012, or if you have a time machine, 2013 is ok too.
Rick NR417
Old Dec 03, 2012, 03:43 PM
Drone Minds is offline
Find More Posts by Drone Minds
@saradroneminds
Drone Minds's Avatar
United Kingdom, York
Joined Apr 2011
Originally Posted by Terry Rigden View Post
Very nice video and some smooth flying good choice of music too. I wish my videos came out that smooth I think the wide angel lens helps. I'll bear your flying site in mind next time I'm in York. I know its being picky but you might want to slow down the panning.
Terry
Cheers, I'm glad you like the music, I made it myself. I had the panning on a switch, but will move it to a dial I think to it's smoother. Let me know if you come to York so we can meet up if you like.
Originally Posted by mike_o View Post
RCFlyingUK,
very nice indeed, the air seems silky smooth - thanks for sharing!
Did you get any adverse effects / comments on flying over too close to urban areas? (Not that I think you do, or that the weight of an EasyStar poses a real threat to anything larger than a hedgehog).
Hope the water is reseding!
I didn't really fly over anything urban. Most of it was over water or fields. I did see it drifting towards houses on the left at one point and deliberately steered away over the other side ofthe river. It's not a regular flying sport for me though, I was only interested in filming the flood water.
Drone Minds is offline Find More Posts by Drone Minds
Latest blog entry: DJI Phantom 4 Slow Motion Test
Old Dec 03, 2012, 07:31 PM
scottdearinger is offline
Find More Posts by scottdearinger
Gravity? No, the Earth sucks
scottdearinger's Avatar
United States, IA, Des Moines
Joined Apr 2011
Hello all.
or..
or..
Gene
Does any one else want Gene's job? I don't... so I say leave him to it- if we can't think of anything worse to do to him- make him run the thread another year...my two cents worth
scottdearinger is offline Find More Posts by scottdearinger
Old Dec 03, 2012, 07:32 PM
Joined Apr 2011
I got to do it again- sorry- but I like you guys and so want to share with you-
OFF TOPIC- but great flight by our Eckace...
Amazingly High RC Radian video 2900 ft over Waukee, Iowa (5 min 5 sec)
Old Dec 03, 2012, 08:09 PM
G550Ted is offline
Find More Posts by G550Ted
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
I don't own an EZ* and only watch this thread so that I can harass Gene. That said, he deserves/should be sentenced to another year as the thread starter just for general principals. After all, he hasn't done diddly this year. No videos of him flying his EZ*, no build reports, no new mods that he invented...nuttin' as they say in Joisey! Just pictures of him and his dogs swillin' brew at the pool in his new home in Flahridah. Time to get back to work ole buddy and make the new year special!
Ted
G550Ted is offline Find More Posts by G550Ted
Old Dec 03, 2012, 08:32 PM
Joined Apr 2011
rick- sending a pm to you regarding your awesome FPV skills
Old Dec 03, 2012, 08:36 PM
heymak is offline
Find More Posts by heymak
Long time newbie
USA, TX, Katy
Joined Nov 2006
Hello all.
or..
or..
Gene
2. Just let it roll, we don't needed no supervision. No need to start a new one.
heymak is offline Find More Posts by heymak
Old Dec 04, 2012, 02:52 AM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
http://www.youtube.com/watch?v=GVt3WIDyRDM
Obvious question. What indication do you have that you acquired that record height?
Old Dec 04, 2012, 08:40 AM
Joined Apr 2011
we are Not claiming any records other than personal-
We are flying 2 separate Eagle tree altimeters - awesome device for under 40 bucks- are pretty darn accurate- we have one on each plane and they almost always agree - they zero to ground level barometric pressure and start recording as soon as you get 60 feet AGL- just plug into any unused rx channel...
here is a link- we love them
http://www.eagletreesystems.com/Stan...standalone.htm
Old Dec 04, 2012, 08:43 AM
Joined Apr 2011
We are starting a new Easy-type build- I am soliciting Ricks advice and this may be my first attempt at FPV....Money of course is a factor- but I feel the need ...
Old Dec 04, 2012, 08:58 AM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Ah right. I use a Zlog that records the data and then I can download to the PC and shows a graph of the flight. It also on the LCD shows details of the last flight. Zlog stopped making them, but a search it seems that they are making them again but different to what I have.
http://www.hexpertsystems.com/zlog/
For Sale NIP proline tires with foams and ultra foams 48chebbie Cars - Trucks and Parts (FS/W) 0 Dec 09, 2011 03:47 PM
For Sale 1.9 Dark Soul wheels with Cobra tires and memory foams ATCH Cars - Trucks and Parts (FS/W) 0 Nov 14, 2011 05:14 PM
Discussion Different foams south.tx.dead.I Foamies (Scratchbuilt) 2 Sep 27, 2011 02:40 PM
Discussion Foams Guz Composites Fabrication 10 Apr 09, 2011 07:25 AM
Discussion Depron/Wall Foams highdesert Scratchbuilt Indoor and Micro Models 21 Mar 19, 2011 09:57 PM
