Old Apr 11, 2012, 03:59 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Originally Posted by Jurgen Heilig View Post
If this is the case, you should be able to provide a link and a CE certificate of conformity.
Jürgen
I can't be bothered. So what now? Your move.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Eflite Gee Bee Racing
Old Apr 11, 2012, 04:09 AM
AshtonFlyer is offline
Find More Posts by AshtonFlyer
AshtonFlyer's Avatar
United Kingdom, England, Bristol
Joined Dec 2011
AshtonFlyer is offline Find More Posts by AshtonFlyer
Old Apr 11, 2012, 04:11 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Was that a chess game or what?
Flypoppa is offline Find More Posts by Flypoppa
Old Apr 11, 2012, 04:20 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
No idea. Running a rather "dirty", unsyncronised telemetry tx near your RC rx is never a good idea. Good thing is, the telemetry tx transmits only 4 times per second. Even if the RC rx can't hear the RC tx signal during that period, you won't notice it that much in a model like the EasyStar.
While 99% of users may never have a problem with the Quanum set, I worry about the remaining 1%. Running a system which does not comply with CE standards can get you in a lot of trouble when there is an accident.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Apr 11, 2012, 08:11 AM
jbeckett is offline
Find More Posts by jbeckett
More Pixels!
jbeckett's Avatar
Collegedale TN
Joined Jan 2006
Jürgen
Click on the fourth picture at http://www.hobbyking.com/hobbyking/s...mp_mAh_V2.html
jbeckett is offline Find More Posts by jbeckett
Old Apr 11, 2012, 08:33 AM
Joined Sep 2000
Originally Posted by jbeckett View Post
Well, a picture is no substitute for a legal document, i.e. a certificate of conformity for the appropriate country, signed by the responsible person for the product in this country.
Tx output: 20dbm<100mW is too high for a DSSS sytem in Europe. Only FHSS systems are allowed to use 100mW. For DSSS the limit is usually 10mW.
Jürgen
Old Apr 11, 2012, 12:41 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Jürgen
I've asked the UK importer if they have the certification document. Doubt they will, going by what you say, in which case they will have some explaining to do.
Old Apr 11, 2012, 12:45 PM
rcjim11 is offline
Find More Posts by rcjim11
rcflyer
UK
Joined Jun 2010
Hi,
I am thinking of purchasing a EZ* for FPV use. Do you recommend the heavier (92g) 2835 2700kv motor or a lighter 36g 2600kv out runner? Are there any major mods needed to use brushless options mentioned?
I assume that I can use a larger battery for longer flight times if I opt for the heavier motor?
Cheers
Jim
rcjim11 is offline Find More Posts by rcjim11
Old Apr 11, 2012, 01:05 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Originally Posted by rcjim11 View Post
Hi,
Cheers
Jim
Jim, this might help: http://www.rcgroups.com/forums/showp...postcount=2440
Old Apr 11, 2012, 01:09 PM
Doubledog is offline
Find More Posts by Doubledog
To build or fly today?
Doubledog's Avatar
United States, AL, Gulf Shores
Joined Feb 2008
Well, I'm in the process of assembling mine and contructive feedback is appreciated.
Not really a fan of going with a 2200kv & 6x4. Would much rather use a 1900 or even 1400kv & a 7x5 to get that extra thrust at slower speeds.
First things first:
Here is the mount I created today on the lathe. Was a little difficult to get the end due to the size of the dowel so I'll either use a pill bottle cap or can mill out an aluminum cap (probably do the later tomorrow). Size should remain the same.
Question - is this enough clearance for a 7x5 or is it suggested to extend it out a tad further?
Thoughts are to leave it as is and cut down a few SF 8x5's to around 6.5" diameter. Anything to get that extra thrust. Is it worth the effort?
Lastly - how do you secure the dowel to the fuselage? I can wrap it in double back tape but would rather not make it permanent. Is thrust alone enough to keep it secure (pushing foward)?
Thanks for the feedback, -Jr.
Doubledog is offline Find More Posts by Doubledog
Old Apr 11, 2012, 01:25 PM
Mike_Then is offline
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
I'm using a lower kV motor in mine and a 7x5 prop. Plenty of power at low amps. I'm using sotog's custom aluminum motor mount so there's plenty of clearance, even if I needed an 8" prop. I glued the motor mount into the fuselage so it's semi-permanent but the mount is adjustable. I would glue the dowel/pill bottle in and not trust the forward thrust and/or the friction of the mount to be enough to hold it into place. But that's just me.
Mike_Then is offline Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old Apr 11, 2012, 01:28 PM
mixer421 is offline
Find More Posts by mixer421
Agricultural flyer
mixer421's Avatar
United Kingdom, England, Kent
Joined Aug 2007
First things first:
Perhaps drilling down through the nacelle and dowel and about1" into the fuselage to take a 3/16 or 1/4" dowel pin held in place with tape over the top of the nacelle. If the dowel mount isn't fixed it could rotate.
mixer421 is offline Find More Posts by mixer421
Old Apr 11, 2012, 02:07 PM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
Hi,
Cheers
Jim
Generally I prefer to keep the weight down as much as possible it depends on how many watts you want to push through the motor. Have a look at http://www.peakeff.com/Default.aspx and enter your motor details and see if you are overloading it
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Apr 11, 2012, 02:11 PM
Doubledog's Avatar
Joined Feb 2008
Super ideas and I'll consider them in a day or two as that process nears.
Just came back from the shop. In the process of milling out an aluminum cap to fit over the dowel. It will be large enough to allow at least a 1/4" of vertical mount for the motor to get the 7x5 prop on there.
Only concern now is the thrust line as it will be just that (1/4") off if going upwards with the motor. Any ill effects in doing such? Having read through a lot of the 160+ pages, it doesn't seem like an issue.
Old Apr 11, 2012, 02:44 PM
Joined Dec 2011
I ended up going with an 1130kv on my EZII (which can take a 7" prop as stock) and loved it - hence I am going the same way with my Bixler, which is an EZI clone.
I have done something similar, and have bumped the motor mount up about 1", which I've been assured won't affect the thrust line. When I get my finger outta my.. ..ear, I will either wrap the internal mount bulk in masking tape before spot gluing or use double-sided tape.
My mount core is the 'stock' Bixler fake plywood pieces (could be cork!) with added kebab sticks and gorilla glue. The height adjustment plate was a trimmed piece of 6mm marine ply, screwed and GG'd - then the entire lot was brushed with CA to soak in. Pic in my profile if interested (pretty sure I posted it here a few pages back)
For Sale NIP proline tires with foams and ultra foams 48chebbie Cars - Trucks and Parts (FS/W) 0 Dec 09, 2011 03:47 PM
For Sale 1.9 Dark Soul wheels with Cobra tires and memory foams ATCH Cars - Trucks and Parts (FS/W) 0 Nov 14, 2011 05:14 PM
Discussion Different foams south.tx.dead.I Foamies (Scratchbuilt) 2 Sep 27, 2011 02:40 PM
Discussion Foams Guz Composites Fabrication 10 Apr 09, 2011 07:25 AM
Discussion Depron/Wall Foams highdesert Scratchbuilt Indoor and Micro Models 21 Mar 19, 2011 09:57 PM
