I got My EZ flying again today- had a couple decent flights on it- glued my rudder control rod to Horiz stab where it was flexing and replaced my control horn that was broke on my elevator-- also went from 6x4 prop to 6x5.5- everything seems to work and the plane turns both directions again. No real big difference noticed with prop switch- 2200kv motor.
Poticelli- Bummer on your wiring dude... |
http://www.castlecreations.com/produ...nderbirds.html |
I understand your train of thought. According to the standards of DC voltage Red is always positive and Black is always negative unless someone who did the wiring assembly did not pay attention and mixed it up. ![]() I have seen incorrect wiring practices numerous times. I thought maybe someone made a mistake this time. The issue was probably a loose connection which arced and fed back into the ESC. Which is too bad for Pocitelli |
Sorry Vince - that pic came direct from the CC website - I think I see what you mean though.
Still working on the ground-up restoration of son's HS - ye gods, the epoxy is a slow dryer! (but strong as an ox when it gets there )With a few evenings of care, it might even be airworthy again ![]() Had some time to work on the theory of Universal Landing Gear MkII last night.. Steel and CF tube are out - they really don't mix well. I've picked up a set of the landing gear axle-holder thingies from LHS and am going to try Inanimate Carbon Rod (3mm, to be exact) - just need a few circlips now. Should be ready for testing by Easter weekend - weather not looking good though
Joined Aug 2010
That stuff comes under the general heading of "tarp tape" at my local farm and industrial supply dealer. May also be available at stores catering to campers. Used for repairing, reinforcing or joining plastic tarps. 4 or 5 colours available, has some stretch but not heat shrinkable like many of the filament packing tapes commonly used on our foamies.
I don't crash as much now and mostly need it to protect the foam from cosmetic damage more than structural deformation, but, sooner or later I will test that too. |
Italy, Lazio, Albano Laziale
Joined Oct 2008
Hello, greatings to everybody here. Nice huge (series) thread.
I purchased an EZstar MK1. It was in sale and come up for a nice price, so it's time to join the group of EZ flyers. I want to equip it for FPV so I have a couple of questions before starting building it. I've read a lot of posts, very helpful but at least a couple of answers were unanswered. 1- First the motor. There is a little clearance for the prop and I have understood that the max usable (without cutting a slot) is a 6". I have several motors to use, including a Suppo like 2212-06 2200Kv, an EMAX 2212 1600Kv and others with lower Kv. My doubt is that the Suppo is by far too powerful and mabe the 2212 fits better. The real doubt is that with a so little propo the efficiency will be low. What would be the max flying time with a 3s 2200mAh? Is it there a better solution? 2- I've read that many people use to cut the two sections below the wing to have more sace to fit things. Do this weakens the fuselage? I think yes and will be less crash resistant. Your experience? I'm thinking of not gluing the fuselage for the first flights until I'll have a better idea of the best config and weight distribution. At first I'd like to mount it using some fibre tape. It should be strong enough to keep the fuse on even it will add some weight. Correct? Thanks for your support. Al |
2. The key here is whether the weakness you've introduced is significant. Cutting anything does reduce its strength somewhat. You can often cut things in the middle of a structure so long as the outer edges are intact. That's why trusses work, and why electricians cut holes for wires in the middle of studs instead of toward the edges. 3. The RR version comes taped instead of glued. That's how I would do it. |
| Thread Tools | |
| For Sale NIP proline tires with foams and ultra foams | 48chebbie | Cars - Trucks and Parts (FS/W) | 0 | Dec 09, 2011 03:47 PM |
| For Sale 1.9 Dark Soul wheels with Cobra tires and memory foams | ATCH | Cars - Trucks and Parts (FS/W) | 0 | Nov 14, 2011 05:14 PM |
| Discussion Different foams | south.tx.dead.I | Foamies (Scratchbuilt) | 2 | Sep 27, 2011 02:40 PM |
| Discussion Foams | Guz | Composites Fabrication | 10 | Apr 09, 2011 07:25 AM |
| Discussion Depron/Wall Foams | highdesert | Indoor and Micro Models | 21 | Mar 19, 2011 09:57 PM |
