Old Mar 31, 2012, 09:44 AM
Martin7182 is offline
Find More Posts by Martin7182
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
Originally Posted by Jurgen Heilig View Post
Hi Martin,
these motors don't have the torque to spin a decent sized prop. They were meant for ducted fans or geared applications.
Offered now at $8.-, you may want to get some more for "crazy projects".
http://www.aircraft-world.com/shopexd.asp?id=6076
Jürgen
Thanks Jürgen,
I've ordered them there indeed for $8 each. "We have just discovered a cache of the X22 series motors during an inventory here at Air Craft". That was months ago, must be a big cache or unpopular motor . Their size and shaft are like the permax 400, so I'll try the original Graupner prop and check whether they don't run too hot. Otherwise it's time for the EZJet project .
Martin
Martin7182 is offline Find More Posts by Martin7182
Old Mar 31, 2012, 10:55 AM
eckace1 is offline
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Originally Posted by RC Novice View Post
its permanently off , good idea , let know how it went
Also if your using 2.4 gear you don't need the tube that is on the belly.
You could replace that with a carbon fiber tube.
Just a thought.
eckace1 is offline Find More Posts by eckace1
Old Mar 31, 2012, 11:06 AM
eckace1 is offline
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Originally Posted by scottdearinger View Post
actually I will take some more eggs- they were good-
Looking forward to our RC truck jumping over a Slowstick in flight tomorrow- I hope they collide-
On topic- we are filming it from an easystar..
Gunna be a fun video to make.....
Ya its going to be fun!!!
I will have the Easy Star flying over the attempt for aerial vid from above.
Old Mar 31, 2012, 12:01 PM
AshtonFlyer is offline
Find More Posts by AshtonFlyer
AshtonFlyer's Avatar
United Kingdom, England, Bristol
Joined Dec 2011
With regard to "Bent Conk Syndrome" in EZs (collapsed fuse walls below cockpit), as suffered by a few posters, I've found the following works amazingly well whilst rebuilding my son's HS that had got to the 'final straw' point after a few nosedives and rushed repairs:
Usual soak in off-the-boil water to re-fluff the beads. This did okay, but it still left lots of creases and warped fuse walls that were anything but rigid.
I went out shopping, mainly to top up my CF tube supplies from the LHS (his narrower tubes are good value) - I popped into The Range (discount shop) to get some 5min epoxy and found these 'lolly sticks' for a quid - Bargain!
I clamped a couple against the fuse walls as shown (layer of sticks on top helping the clamps), and both sides are now dead straight, and very strong. I know it's been suggested before, but I wasn't prepared for how good the fix really is
I plan on finishing off the outer surface with a brushing of wood glue mixed with a bit of talc (spackle/polyfilla effect), and will add 2 more sticks to the inner fuse floor as extra strength/battery tray (extra weight maybe, but I took out the nose weight during all of this)
Just tidying up his stock wiring now while it all sets - 12" of cabling from battery to esc
AshtonFlyer is offline Find More Posts by AshtonFlyer
Old Mar 31, 2012, 12:15 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Using those flat sticks to strengthen the cockpit area is an interesting idea. About how thick are they?
I like your work space but man all that food within reach would be hard not to eat.
Eagle202 is offline Find More Posts by Eagle202
Old Mar 31, 2012, 12:18 PM
Joined Dec 2011
They're about 1.5mm.. roughly the same as proper lollipop sticks, but a bit longer and twice the width. I doubled them up for the weakest section nearest the cockpit opening (more epoxy).
I've been allowed to use the table on the promise that the kitchen becomes sparkling clean afterwards and I do all the cooking tonight
Old Mar 31, 2012, 12:32 PM
Bill0 is offline
Find More Posts by Bill0
Bill0's Avatar
United States, CA, Oceanside
Joined Aug 2010
Called tongue depressors on this side of the pond. Also known as AHHHH sticks.
Bill0 is offline Find More Posts by Bill0
Old Mar 31, 2012, 01:13 PM
EZCanuck is offline
Find More Posts by EZCanuck
Closed Account
Joined Aug 2010
EZCanuck is offline Find More Posts by EZCanuck
Old Mar 31, 2012, 02:16 PM
Joined Dec 2011
Originally Posted by EZCanuck View Post
they don't have CF rods or tube though
I found very cheap rods at a kite store.. half the price of LHS, but possibly half the quality too
Old Mar 31, 2012, 02:44 PM
Colonel Blink is online now
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
They are cheap, cheap cheap... check the craft aisle at Dollar Store or Dollar Tree in U.S. and Canada.
Or be like me and be married to a nurse. I got two boxes for nowt*....
Thanks for the hint Ash.... I'll bang some in in a few days!
*Yorkshire's favourite price
Colonel Blink is online now Find More Posts by Colonel Blink
Old Mar 31, 2012, 03:03 PM
EZCanuck is offline
Closed Account
Joined Aug 2010
Old Mar 31, 2012, 03:08 PM
Joined Dec 2011
Thanks for that tip... I fly stunt kites when it is too windy for the Radian or Easy Star and I can't believe I didn't think of that. I was going to check out some local hunting outfitters ( like Cabela in N.A. ) who have CF arrows to compare to the LHS. In this case the LHS may be the cheapest if the others don't have the sizes I want as shipping charges for one or two from a specialty CF supply would put the unit cost out of sight.
BTW, here is a retrofit of an EZ to reinforce the nose using a piece to hard foam. I think it is called Depron - no markings on it, quite firm, gloss surface, hot glues great. Afterward I just use a thin piece of soft packing foam found in lots of stuff I order from HK to hold the battery in place, slide fore and aft to adjust C'oG.
https://skydrive.live.com/?cid=DBDE7...5DDCB92%211004
Great idea! I have a bag full of it I think - taken from an HP server packing case (I think the packing was better value than the server )
I was curious to see if I could hotwire a pod out of it for my flying wing - never thought of using it as extra internal support for the other planes
I've also got a few bags of EPP, gathered in the same way - saves a fortune on buying it in 'neat' sheets
PS: what's that white tape I can see? Looks very useful
Old Apr 01, 2012, 09:18 AM
mnegrete is offline
Find More Posts by mnegrete
mnegrete's Avatar
Sacramento
Originally Posted by pdiddyg40 View Post
That is AWESOME! Great build and paint job! You've surpassed any construction that I've ever done with an EasyStar. I hope that you get many uneventful flights with that plane, it'd be such a shame to mess up that paint.
Thx pdiddyg40. That's my hope, too, but stuff happens, right? There's bound to be some landings that are rougher than others...
That was a very cool build log! What paint where you using there?!
Ashton Flyer, it's water based acrylic paint I bougth from a local craft store for $1 a bottle. I followed the general procedure outlined in some other threads on rcgroups (wish I could remember the user to give him credit). After sanding the mold marks off I sprayed the plane with a coat of water based polyurethane (WBPU). Then I sprayed the paint, thinned with windex (equal parts windex and paint). After a few coats of paint I applied three coates of the WBPU to protect the water based paint.
I had a gws e-starter that I painted with the water based craft paints and did not apply the WBPU. The paint did not hold up very well, and if any water got on the plane, the paint would run.
mnegrete is offline Find More Posts by mnegrete
Old Apr 01, 2012, 12:58 PM
Pocitelli is offline
Find More Posts by Pocitelli
Hi, I'm an RC Plane addict
Pocitelli's Avatar
United States, CA, Carlsbad
Joined Jan 2012
Need help....
I'm putting together my second EasyStar and last night when checking all my wiring/connections, I plugged in the esc to the battery and got this weird clicking sound. Power was going to the receiver (new Spectrum), but it wasn't blinking like it should for me to bind my transmitter to.
I couldn't tell where the clicking was coming from, it was either the ESC or the batter to esc connection. I had just finished soldering a new ec3 connector to the esc to plug into the batter, double checked my polarity which was correct, etc.
After 3 or 4 times of unplugging and replugging in the battery, the connection at the ec3 smoked and my battery got really hot. I'm suspecting the polarity on the esc might actually be wrong. Black wire is usually negative and red is positive and I had it all right, but now I'm wondering if the Thunder 18 Castle Creations esc's wiring was reversed.
Any ideas - my lipo is probably toast and I suspect the esc too.... What's weird is the light on the receiver was going on, so it was definitely getting power through the system.
Stumped....
Pocitelli is offline Find More Posts by Pocitelli
Old Apr 01, 2012, 01:16 PM
Joined Dec 2011
Red lead as shown here, or other way up? Silly question maybe, but was it a 3s LiPo?
For Sale NIP proline tires with foams and ultra foams 48chebbie Cars - Trucks and Parts (FS/W) 0 Dec 09, 2011 03:47 PM
For Sale 1.9 Dark Soul wheels with Cobra tires and memory foams ATCH Cars - Trucks and Parts (FS/W) 0 Nov 14, 2011 05:14 PM
Discussion Different foams south.tx.dead.I Foamies (Scratchbuilt) 2 Sep 27, 2011 02:40 PM
Discussion Foams Guz Composites Fabrication 10 Apr 09, 2011 07:25 AM
Discussion Depron/Wall Foams highdesert Scratchbuilt Indoor and Micro Models 21 Mar 19, 2011 09:57 PM
