This thread is privately moderated by DLGjunkyard, who may elect to delete unwanted replies.
Old Dec 30, 2011, 05:44 AM
DLGjunkyard is online now
Find More Posts by DLGjunkyard
DLGjunkyard's Avatar
Canada, ON, Morriston
Joined Apr 2010
Mini-HowTo
4 pin TWO servo wiring diagram
One example which can be purchased http://www.amazon.com/dp/B0015H2UR8/...SIN=B0015H2UR8
Inside the plastic cover there is a a small PCB with 2 male servo connector that shares + - and signal!
What I do is to remove the plastic cover and cut the PCB signal layer on the PCB. Then I solder a new signal Cable with a female servo uni plug. And there you have a good functional harness for the fuselage!
The diagram below is just to show the basic principal of a shared system V V V V V V V
DLGjunkyard is online now Find More Posts by DLGjunkyard
Help! Quad Receiver Wiring Diagram uberdisco Multirotor Talk 10 Nov 16, 2011 04:28 PM
Discussion Wiring diagram for old Ignition engines dankar04 Engines 4 Oct 18, 2011 10:03 PM
Discussion Wiring Diagram for 6 servo E-Sailplane AZ_Astro Electric Sailplanes 7 Mar 13, 2010 12:24 PM
Need 9-pin D connector wiring diagram Brian Courtice Slope 9 Nov 07, 2005 06:01 PM
Wiring a 4 servo wing with 6 pin deans connector Hostage-46 Modeling Science 2 Jul 26, 2003 08:50 AM
