Old Jan 04, 2013, 05:37 PM
sebior is offline
Find More Posts by sebior
Czech Republic
Joined Aug 2012
We can control Super Simple Gimbal with Rabbit?
sebior is offline Find More Posts by sebior
Old Jan 05, 2013, 01:03 AM
patricklupo is offline
Find More Posts by patricklupo
Joined Jul 2009
I would think so using a v-tail mixer but note that cheap mixers (like hobbywing and from hobbyking) are only 200 steps and really jittery. Unless elevon\v-tail mixing was added to Rabbit camera stabilization in future firmware, I'd recommend a decent 4000+ step mixer from Digimix or Dionysus Design.
patricklupo is offline Find More Posts by patricklupo
Old Jan 06, 2013, 04:22 PM
Kenpilot is offline
Find More Posts by Kenpilot
Kenpilot's Avatar
Joined May 2006
Hex6X completed
Hello. It has been a while since I've posted in this thread. My Ifly4 with Rabbit has been flying well, although since I've been flying the F450 with NAza and GPS, it has not seen as much flight time lately.
However, I just today completed a F550 frame Hex build using the Rabbit controller and GPS, A20-22L motors, Maytech 20A esc's and some odd 10x4.5 props I had laying around-balanced and good.
Had to re-read some info here on the forum, but happy to report that initial hovering tests have been completed successfully.
Question about the new GUI (December-12 version) and GPS. My longitude indicates correct, but the latitude indicates .090...... which is clearly wrong. Not sure if this will create a problem, or if there is something I need to adjust. - I'm in New Jersey.
The LED's indicate 4 or more even when Im hovering in my backyard so I am receiving a good number of satellites and the red LED on the GPS chip is glowing red.
I like the latest GUI. Quite an improvement! I still love this board!
Kenpilot is offline Find More Posts by Kenpilot
Old Jan 07, 2013, 02:30 PM
Kenpilot is offline
Kenpilot's Avatar
Joined May 2006
Anyone else flying a Hex with this board?
Ok, after 5 flights today at the field, I could use some advice. Anyone else flying the F550 frame or similar Hexacopter that can recommend some settings? This thing was a squirrel all day, twitchy and not very stable.
I calibrated the compass several times before a few of the flights. Gps hold forget it right now .... It would hold heading and altitude below two meters. Above was very squirrely... Need to do the foam over the baro routine...
And some general tweaking.
Anyone with a good settings list? I'm using the latest software and GUI . Thanks
Old Jan 07, 2013, 03:14 PM
ua6jhm is offline
Find More Posts by ua6jhm
North Ossetia - Alania
ua6jhm's Avatar
Joined Apr 2012
Изображение 046 (2 min 17 sec)
Small test position holding, return home and auto landing.
ua6jhm is offline Find More Posts by ua6jhm
Old Jan 07, 2013, 03:20 PM
ua6jhm is offline
ua6jhm's Avatar
Joined Apr 2012
Main why bad rabbit flying that influence power wires on the compass! Lift the rabbit up the wires that go to the regulators. I advise at least 7-8 inches.
Old Jan 07, 2013, 03:25 PM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
The default settings for you size copter should work well as 550 is right in the middle.
nebstress is offline Find More Posts by nebstress
Old Jan 07, 2013, 03:38 PM
maximal is offline
Find More Posts by maximal
AutoQuad OS developer
maximal's Avatar
near Ithaca, NY, US
Joined Aug 2004
Hi Ken, check the "health" value in the Rabbit GUI for vibration levels (with motors+props running at least at hover speed). The best part about the Rabbit is how well it (typically) flies on stock settings, so I would suspect something else going on with your setup.
Foam over baro is absolutely required. Even if using a dome, direct sunlight can affect the sensor dramatically.
-Max
maximal is offline Find More Posts by maximal
Old Jan 07, 2013, 05:14 PM
Kenpilot is offline
Kenpilot's Avatar
Joined May 2006
-Max
Thanks Max. What is an acceptable health number, low or high number better?
Old Jan 07, 2013, 05:17 PM
Formosa is online now
Find More Posts by Formosa
Joined Aug 2004
Hi
Are you saying that you did not cover the baro with foam?
You need to cover it with foam and better add a cover to block the light as well.
Formosa.
Formosa is online now Find More Posts by Formosa
Old Jan 07, 2013, 11:14 PM
maximal is offline
maximal's Avatar
near Ithaca, NY, US
Joined Aug 2004
Lower is better. Last time I checked (a couple versions ago), mine was under 10 (8 IIRC) and it flew great.
-Max
Old Jan 08, 2013, 08:47 AM
JiGe is offline
Find More Posts by JiGe
JiGe's Avatar
France, Midi-Pyrénées, Mauvezin
Joined Sep 2004
Hi all
How do you reverse the gimbal nick or roll with the latest firmware (1.23)? I can't enter negative numbers....
JiGe is offline Find More Posts by JiGe
Old Jan 08, 2013, 11:57 AM
Kenpilot is offline
Kenpilot's Avatar
Joined May 2006
-Max
Geez, mine says 58. I'm looking for documentation on the health number,what does it look at?
Old Jan 08, 2013, 12:06 PM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Vibration.
Old Jan 08, 2013, 01:32 PM
Kenpilot is offline
Kenpilot's Avatar
Joined May 2006
Originally Posted by nebstress View Post
Vibration.
I made the wrong motor choice. With props off and motors running, it goes over 100 into the 20's. I guess ya gets what ya pay for.
Looking for 6 good motors.
Discussion Multicopter Flight Controller Comparison Chart mbsteed Multirotor Talk 27 Jun 13, 2015 09:41 AM
Discussion Free Flight FF Auto Balance Controller with 3D Acceleration Sensor For QuadCopter C team MOD Multirotor Electronics 5803 Jun 26, 2014 05:40 PM
Discussion New quadcopter frame only (compatible with KK/MK MultiCopter Controller ) udoor Multirotor Talk 23 Aug 07, 2011 12:05 PM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
