Old Dec 14, 2012, 06:04 PM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
Originally Posted by CapBlack View Post
nebstress If you look at the PDOP parameter NEO-6M, never falls of 1.6 this means 19.2 meters precision
but tomorrow, I'll try again.
I use the CRIUS CN-06 GPS modules which are also NEO-6M & in real flight I get about 1 to 3 meters accuracy with PH & 2 to 4 meters with RTH (both depending on wind).
Setting Declination helps as well as good Mag setup & calibration along with taking time to acquire good GPS lock before flying.
nebstress is offline Find More Posts by nebstress
Old Dec 14, 2012, 09:41 PM
patricklupo is offline
Find More Posts by patricklupo
Joined Jul 2009
Originally Posted by Ican View Post
...would you please send it to the site: http://www.youku.com,then send the address to me .
Thank you!!
Hi Ican,
I have posted the video at the link below.
http://v.youku.com/v_show/id_XNDg4MzI3NTI0.html
Since then I have tried more GUI settings that were recommended but with the same result; Go Home flies very fast and erratic when enabled.
I also discovered that the GPS coordinates in Rabbit GUI were are off by a digit. In the photo below it shows my location as -12.995006 / 37.411746 but my correct location was actually -121.995006 / 37.411746. I'm not certain if this would cause Go Home not to work correctly. I could install 1.211 firmware (Go Home works fine in it) and compare the GPS location but I don't think it has GPS coordinates in the GUI.
In any case, Nebstress has said that the RCTimer UBlox GPS worked well for him so I've ordered one. Lets wait and see if it fixes the issue. I'll let you know once I receive it in a couple weeks.
patricklupo is offline Find More Posts by patricklupo
Old Dec 15, 2012, 12:18 AM
Ican is offline
Find More Posts by Ican
China, Shanghai
Joined Apr 2012
Originally Posted by patricklupo View Post
Hi Ican,
Thank you for your video &picture
we will study it as fast as possiable!
Ican is offline Find More Posts by Ican
Old Dec 15, 2012, 01:06 AM
CapBlack is online now
Find More Posts by CapBlack
Joined Jul 2012
yes but then is filtered and an average is taken "corrected by software"
CapBlack is online now Find More Posts by CapBlack
Old Dec 15, 2012, 04:55 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Hi Patricklupo,
Yes the RCTimer CRIUS CN-06 GPS module works well, I find it gets a lock & the Rabbit passes 'self check' much quicker than the stock LF GPS.
You will just have to swap over the TX & RX pins in the plug that connects to the Rabbit, very easy to do just have to lift the little tabs with something small (I use a micro screwdriver) & pull the wire/pin out, they just clip back in again.
Old Dec 15, 2012, 07:16 AM
Joined Jul 2012
Hi Patricklupo,
If u get NEO-6P GPS module for Precise Point Positioning ,can be better
Old Dec 15, 2012, 07:40 AM
rkenosha is offline
Find More Posts by rkenosha
Joined Jan 2012
I use the Rctimer n6 Version 2 also. I find that it locks quicker and is a bit more accurate. I also like the fact that the cable come ready to plug into the rabbit. As said, you do have to reverese the tx rx wires. rkenosha
rkenosha is offline Find More Posts by rkenosha
Old Dec 15, 2012, 07:48 AM
Elo WW is offline
Find More Posts by Elo WW
Deutschland, RP, Hillscheid
Joined Nov 2010
Is this http://www.rctimer.com/index.php?gOo...3&productname= the Receiver you are talking about?
Are other changes than reverse rx-tx needed?
Is there no need of changing baud rate?
Michael
Elo WW is offline Find More Posts by Elo WW
Old Dec 15, 2012, 07:50 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Michael
Yes it is & no you don't
Old Dec 15, 2012, 08:26 AM
EricBx is offline
Find More Posts by EricBx
EricBx's Avatar
France, Aquitaine, Prignac-et-Marcamps
Joined May 2012
Who dared to switch off the Radio to test the Failsafe ?
EricBx is offline Find More Posts by EricBx
Old Dec 16, 2012, 05:47 AM
Ican is offline
China, Shanghai
Joined Apr 2012
there are many fans of Rabbit test it ,and it is oK,
you can test it !
Old Dec 16, 2012, 12:29 PM
tacitapproval is offline
Find More Posts by tacitapproval
Joined Mar 2012
The failsafe works as advertised in my tests.
tacitapproval is offline Find More Posts by tacitapproval
Old Dec 16, 2012, 05:50 PM
rizalbautista is offline
Find More Posts by rizalbautista
Philippines, CALABARZON, Cavite City
Joined May 2012
I Did, but there was a slight problem. its not the rabbits faults but the Fail safe design of my tx (aurora 9) seem like there is a second delay before FS engages when i turn off my tx and that 1 sec delay makes my quad fall with a dead motor for a second before doing the rabbit FS.. so there a short free fall drop before it goes to FS sequence.
my advice is do not turn off your aurora 9 tx for rabbit fs when you are in a very low altitute....
just sharing
rizalbautista is offline Find More Posts by rizalbautista
Old Dec 16, 2012, 08:47 PM
Formosa is offline
Find More Posts by Formosa
Joined Aug 2004
Hi Ican
I have one suggestion or feature request.
I mainly use the Rabbit for FPV and I have two now and I will assemble one more for aerial video around Chinese new year.
My 1st FPV quad is designed for close range and the 2nd is designed for mid range, 15 minute flight time, I hope.
Recently I ran into a few occasions was that the battery pack's voltage drop suddenly before the usual flight duration, it was due to one cell not healthy. leading to a few emergency landings, luckily, no major damage.
The Rabbit have cell voltage detection and low voltage alarm, but it would not be useful for more than 100 meters away.
Can Rabbit provide a voltage output, through one of the existing terminal, the voltage of the highest cell and the lowest cell in alternating manner.
Then I can feed this voltage through the OSD so that I can detect cell imbalance through the OSD, it would be very useful for medium range missions.
If you do this, this could be a unique feature that the Rabbit firstly implemented.
Looking forward to hear good news form you.
Formosa
Formosa is offline Find More Posts by Formosa
Old Dec 17, 2012, 08:16 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Originally Posted by Formosa View Post
Hi Ican
Formosa
If you are using an OSD already it would make much more sense, be more accurate & allot easier just to add a current sensor to it or get an OSD with a current sensor, you could then use it for short, medium & long range.
It would be far better for LF to spend any time working on improving the quality & reliability of existing features, plus we all know what happens when new features are implemented!
It would be great to see the Rabbit become rock solid & 100% reliable for 'all' users, then it could really give the NAZA a run for its money
Discussion Multicopter Flight Controller Comparison Chart mbsteed Multirotor Talk 27 Jun 13, 2015 09:41 AM
Discussion Free Flight FF Auto Balance Controller with 3D Acceleration Sensor For QuadCopter C team MOD Multirotor Electronics 5803 Jun 26, 2014 05:40 PM
Discussion New quadcopter frame only (compatible with KK/MK MultiCopter Controller ) udoor Multirotor Talk 23 Aug 07, 2011 12:05 PM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
