Old May 06, 2012, 03:44 AM
OzDragonFlyer is offline
Find More Posts by OzDragonFlyer
Model Bender
OzDragonFlyer's Avatar
Australia, NSW, Newcastle
Joined Jun 2004
I'm having a strange problem.. when switching to autostability (no other boxes ticked) the quad wants to noticeably accelerate forward.
Have tried calibrating and setting the quad perfectly level when powering up.
Once the throttle is set, the quad will almost hover hands free with autostability and all other sensors turned off.
Any ideas?
OzDragonFlyer is offline Find More Posts by OzDragonFlyer
Old May 06, 2012, 04:09 AM
Manolo_B is offline
Find More Posts by Manolo_B
Master on breaking props
Manolo_B's Avatar
Espaņa, Comunidad de Madrid, Madrid
Joined Nov 2011
Any ideas?
Accelerometers work with autostability "on". They "level to ground" the quad. Autostability off-> You are the "accelerometer".
Accelerometer chip->board->motorīs plane-> ground levels not always are perfectly "leveled" one to others.
Try calibrate again in same location introducing a slice of something (carboard, etc) to tilt the quad "backwards" a little.
Itīs a "trial and error" process.
Manolo_B is offline Find More Posts by Manolo_B
Old May 06, 2012, 05:21 AM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
I agree with Manolo_B.
I use a"Bulls Eye Bubble Level" While my Multirotor is on a pillow or something soft & adjust until perfect then run Horizontal Calibration.
nebstress is offline Find More Posts by nebstress
Old May 06, 2012, 06:04 AM
rkenosha is offline
Find More Posts by rkenosha
Joined Jan 2012
Indicaton that switch works?
Is there anyway in the GUI to tell if the switch is working? rkenosha
rkenosha is offline Find More Posts by rkenosha
Old May 06, 2012, 06:25 AM
Elo WW is online now
Find More Posts by Elo WW
Deutschland, RP, Hillscheid
Joined Nov 2010
If you have Display Data active in the Gui on channel 5 and 6 you should see different Numbers, eg 1000, 1500, 2000 depending on switch position.
Elo WW is online now Find More Posts by Elo WW
Old May 06, 2012, 06:34 AM
rkenosha is offline
Joined Jan 2012
Question about camera gimbal.
Thanks again everyone for the responses. Sometimes I have a hard time translating the english in the manual to readable and understandable. Would I connect the servos for roll and pitch on the camera gimbal to the last sets of pins, 7 and 8? Or would they go to 5 and 6, right after the first four populated channels. Thanks Roman
Old May 06, 2012, 06:43 AM
almtmd is offline
Find More Posts by almtmd
almtmd's Avatar
Singapore
Joined Nov 2004
From Manual
16.PTZ connection and adjustment: if the motor channel is less than or equal to 6, then the channel 7 and channel 8 would be automatically converted to 2 axis PTZ stability output,the channel 7 ( M6 ) connect to pitch servo, the channel 8 ( M7 ) connect to the rolling servo,
almtmd is offline Find More Posts by almtmd
Old May 06, 2012, 09:32 AM
cmpang is offline
Find More Posts by cmpang
香港
Joined Sep 2004
Originally Posted by nebstress View Post
No! M0 is the first pin or motor 1, I don't know why the numbered them that way it can be confusing.
M0=first pin/motor, M1= second pin/motor, M2= third pin/motor, M3= fourth pin/motor.
I hope that makes sense.
It is history. As far as I can recall, the manual and markings on the fc board for motor outputs are numbered starting from 0 upto 7 while the Channel inputs from the receiver are starting from 1 upto 8. Apparently there are two different numbering conventions and so some time later they want to get it standardised by changing the motor outputs from 1 to 8.
Hence the confusion you just mentioned..
cmPang
cmpang is offline Find More Posts by cmpang
Old May 06, 2012, 09:45 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
cmPang
That would be good, 1 to 8 makes more sense & will make it simple for people to understand.
Old May 06, 2012, 09:49 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Any new Firmware?
Hi cmpang,
Do you know if there are any new firmware releases in the pipeline?
There hasn't been a new one for a little while now, they did seem to release quite a few in a short period of time.
Old May 06, 2012, 11:24 AM
KnimRod is offline
Find More Posts by KnimRod
Gravity Tester
KnimRod's Avatar
Central Michigan
Joined May 2003
Hi cmpang,
I hope he answers you... My last two requests for this information have gone unanswered.
Originally Posted by mustbemad View Post
Well I hope they are working on all the features they claim to have and I paid for and I am sure they are.
If I did not want these features I would have purchased a Naza.
No problem. It is just a matter of priority... the Rabbit team I know is a group of hard working people and responsible and respective about their products...
Although you might not appreciated it.. the frequent fw update do show that they care about their product..
cmPang
cmPang, Where are their priorities currently? Sorry to lay all this on you but since you are our only line of communication to/from the developers, there's not many options for gleaning up-to-date information... Is there a Chinese forum for Rabbit development we can monitor for progress? Also, it appears to me that there are a lot of people here who would be willing to help with testing and implementation if resources are an issue. I know I'm one of them.
KnimRod is offline Find More Posts by KnimRod
Old May 06, 2012, 11:30 AM
apejovic is offline
Find More Posts by apejovic
Spain, CN
Joined Dec 2011
cmPang
Mr Pang. Thatīs correct. Very first versions of rabbit boards and manuals used the 0-7 numbering. But quite a few months ago both the board numberings and the manuals refer to them as 1-8 which in my opinion is much more logical.
I think only the very first boards were labeled with 0-7, as my first one bought in december 2011 already came with the 1-8 convention.
apejovic is offline Find More Posts by apejovic
Old May 06, 2012, 11:38 AM
apejovic is offline
Spain, CN
Joined Dec 2011
Some RAW footage
Me and the Rabbit equipped ConHexo were busy last month. Most of the days it was quite windy here in the Canary islands, and we were also limited by the quality of the Gopro 2 I used, but we ended getting some shots that after some post processing could do the job. This is some RAW footage:
Conhexo 950 Hexacopter April 2012 (2 min 51 sec)
Old May 06, 2012, 11:40 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Hey KnimRod,
Haven't you been reading this thread
Love Flight have placed post's under (guess what) "Love Flight"
I have contacted them a couple times & got responses, I don't think they've got good English though, I only got very short responses.
I think there last post was on page 225. Post 3363.
I think they even put there Email address in a post somewhere back in this thread!?
Old May 06, 2012, 11:44 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
http://youtu.be/lXRlOL9ky1Q
Hi apejovic
that's great!
I'd seen your video on Youtube earlier today & had wondered what camera you used, GoPro, I'm very impressed!
Discussion Multicopter Flight Controller Comparison Chart mbsteed Multirotor Talk 27 Jun 13, 2015 09:41 AM
Discussion Free Flight FF Auto Balance Controller with 3D Acceleration Sensor For QuadCopter C team MOD Multirotor Electronics 5803 Jun 26, 2014 05:40 PM
Discussion New quadcopter frame only (compatible with KK/MK MultiCopter Controller ) udoor Multirotor Talk 23 Aug 07, 2011 12:05 PM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
