Old Apr 02, 2012, 10:31 AM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
Originally Posted by vewdew View Post
Well I could care less about his sarcasm or what he thinks.
All i can say is "Its said when one thinks he knows it all"
But hey I have better news my GPS shipped from goodluckbuy
Did you have to wait the 25 days or did it ship sooner. It seems to me that it was not 25 days.
robone is offline Find More Posts by robone
Old Apr 02, 2012, 10:33 AM
vewdew is offline
Find More Posts by vewdew
Joined Jan 2012
Originally Posted by cmpang View Post
May I suggest, for safety's sake, please remove all the props while doing the upgrade..
cmPang
Talking about blades, yes it is very important that you remove them while upgrading or even just testing and here is the reason why, I was lucky it was rotating slow and only got a few scrapes.
vewdew is offline Find More Posts by vewdew
Old Apr 02, 2012, 10:35 AM
vewdew is offline
Joined Jan 2012
No I only waited 2 weeks for them to ship, I paid for it on March 15th and they shipped March 31.
Old Apr 02, 2012, 10:38 AM
cmpang is offline
Find More Posts by cmpang
香港
Joined Sep 2004
and give up some performance by not using APC.. they act like blades...
I recall the fixed wing days while changing an APC prop, it is not until I have done all the prop installation that I discover my fingers are being scraped... the prop is so sharp that I didn't aware at the time it hurts me...
cmPang
cmpang is offline Find More Posts by cmpang
Old Apr 02, 2012, 10:53 AM
cmpang is offline
香港
Joined Sep 2004
Originally Posted by Melnic View Post
.. when do you look at the LEDs?
...BTW, I flew in 15mph winds this morning. ..
...If I do not have GPS, does auto landing work? .
we look at the LED while in the self test phase...especially when (for some reason) the test cannot get passed, then we could refer to the LED to find out which one is bad...
It is not recommended to use CF or Direction hold while in vigorous manuver.. so it should apply well under strong wind condition..
auto-landing depends on height lock... not GPS.. and it is good to know that AL works fine in the latest FW.. at least as I have tested it today...
cmPang
Old Apr 02, 2012, 11:58 AM
lacras is offline
Find More Posts by lacras
Russia, Moscow, g. Moskva
Joined Dec 2011
Hello,
I've got a problem with my Rabbit. I connected it to the PC and tried updating it with the latest firmware. The process went up to 51% and stopped. There was a message in Chinese that I didn't understand. I pressed OK but nothing happened. I waited for about five minutes but there was no luck. then I disconnected the Rabbit from the PC. Now when I connect the battery all lights turn on and the motors beep. When I connect it to the PC the Rabbit can be seen in it's program but I can't upload the firmware. Have I totally bricked it or is there a way to bring it back to life again?
lacras is offline Find More Posts by lacras
Old Apr 02, 2012, 12:17 PM
KnimRod is offline
Find More Posts by KnimRod
Gravity Tester
KnimRod's Avatar
Central Michigan
Joined May 2003
Originally Posted by lacras View Post
Hello,
there is a way to reset the board... see the attachment,
1. power off
2. use a piece of wire to short the two pins marked red,
3.plug USB cable onto the board
4. start up the GUI and do the firmware upgrade again
5. good luck..
cmPang
KnimRod is offline Find More Posts by KnimRod
Old Apr 02, 2012, 12:35 PM
lacras is offline
Joined Dec 2011
Originally Posted by KnimRod View Post
Thanks a million! You've just saved my day! It all works fine now
Old Apr 02, 2012, 01:42 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
V,
Sorry about your accident. Please repost your photo and how it happened story here to help others be safe: --Multicopter Safety thread with accident and injury photos: http://www.rcgroups.com/forums/showthread.php?t=1144377
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Apr 02, 2012, 01:49 PM
Marco67 is offline
Find More Posts by Marco67
APM Copter Developer
Marco67's Avatar
Italy, Emilia-Romagna, Ferrara
Joined Apr 2009
I'm very sorry for this, but there's a know rule in the "quad world": do not upgrade the firmware with the main lipo plugged!
This rule is applied to all the platform, also with ArduCopter.
It's normal that when updating the pwm signal to the esc can vary, because it is software that works to keep the engine rpm to zero, and if you are upgrading is obvious that the software is not running, so it can maintain a stable pwm signal to zero.
Of course, the authors of the Rabbit manual forgot to write it (I think).
Now for upgrade the Rabbit use only the usb power.
Marco67 is offline Find More Posts by Marco67
Old Apr 02, 2012, 02:11 PM
vewdew is offline
Joined Jan 2012
Well it was my fault really, I was testing the Naza and everything was hot, I was looking for a spefic prob I been having with one motor being faster than the other 3.
And when I started motors again I did not pay attention and my arm was to close to the blades and i got clipped. that goes to show you, always pay attention to what you do and dont be careless about what you are doing, good thing is when you start the naza blades are only turning at 10% power and I was fast enough to move out of the way so not much harm done accept a few scrapes.
Old Apr 02, 2012, 03:15 PM
my64 is offline
Find More Posts by my64
Joined Feb 2011
hi,
I tested today the height lock with fw 1.205. The ultrasonic works pretty well. It sometimes react strangely to throttle movement but overall is ok. However I still can't get the barometer alti to work. The barometer value vary well in the GUI, so the sofware should have the value to handle. Also, the barometer is isolated from direct air pressure.
But when flying, I can't get a proper lock. I am trying to not touch at all the throttle but roll is on the same stick so diffcult not to move a little and I have no gps. In fact the barometer alti control seems to amplify throttle movement and every little throttle move make the kopter go up or down quicly but no altitude lock.
Note that to hover my quad, trottle stick is not at the exact middle.
Any idea why ?
my64 is offline Find More Posts by my64
Old Apr 02, 2012, 05:35 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
I ordered the GPS module from GLB when it first came out a couple weeks ago. They are shipping cause I ordered DHL delivery and it just came to me today.
Melnic is offline Find More Posts by Melnic
Old Apr 02, 2012, 06:33 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Do we have a GPS 101 post here?
Does the TX on the board go to the TX or RX of the GPS?
How do I know the GPS is talking and aquired satellites?
my GPS LED turns RED on power up.
Old Apr 02, 2012, 06:48 PM
mustbemad is offline
Find More Posts by mustbemad
United Kingdom, England, Plymouth
Joined Nov 2011
Do you have the Rabbit gps manual if not search google it.
mustbemad is offline Find More Posts by mustbemad
Discussion Multicopter Flight Controller Comparison Chart mbsteed Multirotor Talk 27 Jun 13, 2015 09:41 AM
Discussion Free Flight FF Auto Balance Controller with 3D Acceleration Sensor For QuadCopter C team MOD Multirotor Electronics 5803 Jun 26, 2014 05:40 PM
Discussion New quadcopter frame only (compatible with KK/MK MultiCopter Controller ) udoor Multirotor Talk 23 Aug 07, 2011 12:05 PM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
