Old Mar 31, 2012, 02:09 AM
cmpang is offline
Find More Posts by cmpang
香港
Joined Sep 2004
very nice video...
cmpang is offline Find More Posts by cmpang
Old Mar 31, 2012, 03:16 AM
Airpac is offline
Find More Posts by Airpac
I'll be watching you ...
Airpac's Avatar
Germany, Berlin
Joined Mar 2012
Hi,
cmpang mentioned some postings before that all aux values are I terms.
So the height lock should work as show in the added graphic.
Nice if some guys could confirm that the function of the carefree graphic
is right.
Airpac is offline Find More Posts by Airpac
Old Mar 31, 2012, 07:54 AM
richkphoto is offline
Find More Posts by richkphoto
United States, MN, St Cloud
Joined Jan 2012
I'm getting a slight front to back wobble,does anyone know which slider I need to cut back on
richkphoto is offline Find More Posts by richkphoto
Old Mar 31, 2012, 08:48 AM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
that should be your first top 3 sliders. Start with the top one. I had to move mine down some. I think case my quad is a 525 and heavy. Thus it can't handle that much gain with the momentum.
Melnic is offline Find More Posts by Melnic
Old Mar 31, 2012, 08:52 AM
Joined Jan 2012
Thanx I thought that it would be the middle 3 sliders ,but I'll give the top 3 a try. My hex is really heavy about 4.5 pounds with one battery
Old Mar 31, 2012, 09:15 AM
Joined Jan 2012
How windy is to windy
I've flown my hex on days with wind gust up to 30 mph and it was a real challenge and you have to be on your toes because things can change very quickly. My quad I feel that 10 to 15mph is about the most I'd want to do
Old Mar 31, 2012, 11:06 AM
mustbemad is offline
Find More Posts by mustbemad
United Kingdom, England, Plymouth
Joined Nov 2011
Puzzled by esc calibration. This would normaly be done by by taking a reading of the throttle stick at high and low, but with the rabbit it's done with the tx switched off. Anybody explain ?.
mustbemad is offline Find More Posts by mustbemad
Old Mar 31, 2012, 02:43 PM
KnimRod is offline
Find More Posts by KnimRod
Gravity Tester
KnimRod's Avatar
Central Michigan
Joined May 2003
Because in this case, the only throttle signals the speed controls see, are generated by the Rabbit.
KnimRod is offline Find More Posts by KnimRod
Old Mar 31, 2012, 03:51 PM
Marco67 is offline
Find More Posts by Marco67
APM Copter Developer
Marco67's Avatar
Italy, Emilia-Romagna, Ferrara
Joined Apr 2009
Rabbit and Mediatek GPS - GPS /Altitude Hold
I started to play again with the Rabbit, i'm not very happy with the results I had obtained earlier.
I think I have achieved good results in the "position / altitude hold" using the Mediatek GPS.
Unfortunately, he feels the lack of dedicated PID to stabilize the corrections in gps hold, I hope the team will soon implement a separate PID for this function, already implemented in ArduCopter with good results, with an interface that is more pleasant and intuitive.
The modifiable parameters are now far too few, and this allows a good tuning depending on your configuration.
Furthermore it is necessary a section for save the parameters that stores also the level and the compass calibration.
Here a short video of my tests, after a good PID tuning.
Bests,
Marco Robustini - (ArduCopter Dev Team)
Rabbit Flight Controller - Testing "GPS/Altitude Hold" with Mediatek GPS (2 min 44 sec)
Marco67 is offline Find More Posts by Marco67
Old Mar 31, 2012, 05:04 PM
Joined Nov 2011
Nice video Marco, gives me hope. A screen shot of your settings would be realy nice. Thanks
Old Mar 31, 2012, 05:14 PM
titeuf007 is offline
Find More Posts by titeuf007
Joined Jun 2006
stable!!!!!!
titeuf007 is offline Find More Posts by titeuf007
Old Mar 31, 2012, 06:32 PM
tony3di is offline
Find More Posts by tony3di
It started with a red biplane
tony3di's Avatar
Joined Nov 2011
I canīt wait to get my hands on GPS . I wanna play fetch with my rabbit
tony3di is offline Find More Posts by tony3di
Old Mar 31, 2012, 08:16 PM
Gor.Alone is offline
Find More Posts by Gor.Alone
Ukraine, Kiev City, Kiev
Joined Mar 2011
Please tell me, if original Rabbit GPS works with a refresh rate of 5Hz, but I use MediaTec GPS and set refresh rate to 10Hz - this will result to a buffer overflow Rabbit serial port?
Gor.Alone is offline Find More Posts by Gor.Alone
Old Mar 31, 2012, 08:17 PM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
*cough*. multiwii works with 10hz GPS without problems. seeing how the same code is stolen, there is no reason for it not to work with 10hz.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Mar 31, 2012, 08:31 PM
Joined Mar 2011
Thank you!
Discussion Multicopter Flight Controller Comparison Chart mbsteed Multirotor Talk 27 Jun 13, 2015 09:41 AM
Discussion Free Flight FF Auto Balance Controller with 3D Acceleration Sensor For QuadCopter C team MOD Multirotor Electronics 5803 Jun 26, 2014 05:40 PM
Discussion New quadcopter frame only (compatible with KK/MK MultiCopter Controller ) udoor Multirotor Talk 23 Aug 07, 2011 12:05 PM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
