Old Aug 10, 2012, 04:14 PM
That's a funny word
NE Ohio
Joined Apr 2003
I'm even having trouble figuring out if my Cox plane are "solo Pro" or "solo" or what. I thought that's what this thread was about. Not the 9x per say , but that IS the TX I want to use. Maybe I can grab module from my stock Cox TX and use it somehow?
gulio is offline Find More Posts by gulio
Old Aug 11, 2012, 10:33 AM
hungary
Joined Jan 2011
Your planes are neither Solo nor SoloPro. They have a different chip and different protocol. You can use the module, but that would need analyzing the protocol and makinga new circuit...
kile is offline Find More Posts by kile
Old Aug 11, 2012, 10:35 AM
That's a funny word
NE Ohio
Joined Apr 2003
Ok, thanks. I will have to go another route then.
Old Oct 29, 2012, 11:46 AM
partly crasher
United States, OH, Cleveland
Joined Oct 2011
Originally Posted by kile View Post
Thanks!
I am using the module with my Turnigy 9x, so I'm sure they pair well. PPM timings and channel mapping have to be changed a little depending on whether you have the stock 9x firmware or one of the er9x firmwares.
As far as I know, the new Nine Eagles helis don't use the the nRF24L01+ chip, so this module will not work with the helis released last year.
are you saying you made a module that works with the sp260????
tonytester is offline Find More Posts by tonytester
Old Oct 29, 2012, 12:46 PM
Joined Sep 2011
If sp260 = solo pro, yes it will work.
I am using one in my jr pcm 9x II, and it works flawlessly.
very nice piece of hardware/software.
Catseyes is offline Find More Posts by Catseyes
Old Oct 29, 2012, 07:19 PM
partly crasher
Joined Oct 2011
yess solo pro 260 I have the new turnigy 9x v2 what part do I need
thanks tonytester
Old Oct 30, 2012, 12:28 PM
flying beam
blackmoon's Avatar
through the Looking Glass
Joined Apr 2008
You could contact kile, last time I read, he had some boards left.
Unfortunately, he said, he was quitting the hobby.
Who knows shoot him a PM, maybe he'll get back to you (he's a very nice guy).
You could also use the files (first page) to etch a board and put the hex file on it.
And last resort, if none of the above works for you, I could sell you one of the two modules I bought from kile (at the price I bought them + shipping).
Shoot me a PM in case kile don't contact you.
blackmoon is offline Find More Posts by blackmoon
Old Dec 08, 2012, 05:43 AM
Joined Oct 2012
I have read with great intrested all threads.
I would also like to build a module but for a SoloPro 180 3d.
Is there someone who has already done such a thing?
I read that using the J6 Pro other chips.
At the end I would like to fly my SoloPro with a MC20.
Grüße MM.
Mark1RS is offline Find More Posts by Mark1RS
Old Dec 08, 2012, 07:26 AM
flying beam
blackmoon's Avatar
Joined Apr 2008
The J6 proto was reverse engineered by the Deviation team.
www.deviationtx.com
In the sources of the project, you will find all the necesseary (if you are a programer) to adapt Kiles' software to talk to the CYRF6936 the chip that do the communication in the SoloPro 180.
Obviously you should source a CYRF6936 module to replace the Nordic nRF24L01+ that is used to talk to the SoloPro receiver.
Deviation project on Bitbucket : https://bitbucket.org/PhracturedBlue/deviation
Direct source link : https://bitbucket.org/PhracturedBlue...386649741b.zip
It would be cool if a programer was interested in this, since deviation supports not only J6 proto, but dsm2, Walkera proto 2x0x, as well the new Devo protocol from walkera.
Kile's module (don't know if the atmega168 on it as enough memory to support all these protos) could support all or some of these protocols, just with the CYRF6936 transceiver module.
Old Dec 10, 2012, 01:32 PM
Joined Oct 2012
Thanks for the info and the links.
I'm trying to find a source for the CYRF6936, but that was far unsuccessfully. Any idea where I could buy one?
Old Dec 10, 2012, 01:37 PM
Joined May 2011
Why not just buy the complete module with power amplifier and antenne connection?
http://www.hobby-wing.com/devo8s-radio-module.html
http://www.ehirobo.com/shop/Transmit...duct_info.html
http://www.helipal.com/devo-telemete...rade-chip.html
FDR_ is offline Find More Posts by FDR_
Old Dec 10, 2012, 02:32 PM
Joined Oct 2012
Mhh.. yes you are right. This is what i am looking for.
Thanks.
Old Feb 13, 2013, 01:18 PM
Switzerland
Joined Sep 2008
I opened my tx before that I found that post.
I was thinking that it was easy like the frsky module.
I was hoping that I can remove the small pcb and take out the signal from the trainer port of my futaba....but after reading I am not sure anymore...
Can somebody confirm or not? I do not care if I destroy the tx.
Cid156 is online now Find More Posts by Cid156
Old Feb 14, 2013, 10:38 AM
Daryoon's Avatar
San Diego, CA
Joined Dec 2010
It doesn't take a ppm signal directly. That's the reason for this project.
Daryoon is online now Find More Posts by Daryoon
Latest blog entry: Syma S105 Battery Mod
Old Feb 14, 2013, 12:22 PM
hungary
Joined Jan 2011
As Daryoon wrote, you will not be able to just rewire the nRF module and have it work. You need a PPM to SoloPro converter inbetween, and that's what the circuit does. As far as I can remember, the neTX firmware and circuit should work for Futaba too, but it probably won't fit the Futaba case.
I was going through my drawers the other day and I found two more blank neTX PCBs. I also have all the components at home, so if anyone still needs these, I can build, program and test one (or two) during the weekend.
I also have a few nRF24L01+ modules with the PCB antenna.
New Product Nine Eagles Solo Pro 328 (Nine Eagles' answer to the Blade 120 SR?) SoloProFan Micro Helis 1666 Jun 14, 2013 08:42 AM
Sold COX/Nine Eagles Micro 2.4 Radio system RX, TX & Motor ShokWaveRider Aircraft - Electric - Micro & Indoor Airplanes 1 Nov 16, 2011 08:27 PM
Wanted Nine Eagles Tx Michaelpilon Aircraft - General - Radio Equipment (FS/W) 2 Oct 16, 2011 06:19 PM
Sold Nine Eagles / Cox Extra 300 (minus Tx) dhaizli Aircraft - Electric - Airplanes (FS/W) 4 May 01, 2011 07:36 PM
For Sale Nine Eagles 210A TX, Flybar & Battery Klippie Aircraft - General - Radio Equipment (FS/W) 0 Mar 23, 2011 05:04 PM
