Old Jan 01, 2012, 11:25 PM
Rudderman98's Avatar
United States, WA, Sumner
Joined Oct 2000
Originally Posted by mountainman2442 View Post
Hey Perry! Just noticed your thread and am signing up.
Nice model. It does fit right in with your love of the obscure. Planning on towing something with it?
Well HI there mountainman! Long time no chat since our Beverly days eh?
Haven't decided if I want to tow with this kit yet. I'll do some inflight evaluation and decide later if she's up for the task.
Good to hear from you!
Rudderman98 is offline Find More Posts by Rudderman98
Old Jan 02, 2012, 12:01 AM
CaptAhab's Avatar
USA, TX, Crosby
Joined Sep 2007
100 cc anyone ?
http://www.flyinggiants.com/forums/s...ad.php?t=69826
CaptAhab is offline Find More Posts by CaptAhab
Old Jan 03, 2012, 12:21 AM
Joined Oct 2000
On Her Legs
Shes on her legs now.
Tailwheel installation came out nice. Instead of going by the directions and using just the nichrome wire through the tailwheel tiller for turning, I opted to use DuBro 4-40 ball links. I put them in the most inner hole.
Also on the advice of CaptAhab, I fabricated an aluminum support bar for the main gear legs to support any flexing and high loads during not so perfect landings.
The maingear cover plate was easy. Just trim to fit and drill small holes along the perimeter of the main gears, add a drop of thin CA in the holes, then close her up.
Now to complete the motor mounting and wing servos
We're getting close!
Old Jan 03, 2012, 12:56 AM
Sluf7's Avatar
Joined Feb 1999
Nice work Bro looks really nice.
Have some pic's of the ole Wilga I have taken in me travels somewheres have to see if I can find the suckers
Keep at it lad
Sluf7 is offline Find More Posts by Sluf7
Old Jan 03, 2012, 01:12 AM
tinkrerpilot's Avatar
Puyallup, WA
Joined Nov 2001
You really are making quick work of this one. Guess I'll have to get a glider ready, just in case.
tinkrerpilot is offline Find More Posts by tinkrerpilot
Old Jan 03, 2012, 01:23 AM
Joined Oct 2000
Keep at it lad
Thanks Sluf.
Old Jan 03, 2012, 01:24 AM
Joined Oct 2000
Well you do have a room full of gliders in your house to choose from.
How about that SHK??
Old Jan 03, 2012, 01:58 AM
Joined Oct 2000
I was alerted by the esteemed CaptAhab that I assembled my ball links incorrectly on the tailwheel assembly.
Here is the correct way.
Thanks for watching my back El Capitain!
Old Jan 03, 2012, 02:34 AM
Puyallup, WA
Joined Nov 2001
SHK and a Mini. Hmmm which one to go with. Would be a good test with the SHK.
Old Jan 03, 2012, 06:22 PM
Joined Oct 2000
Motor Mounting
Got my Electrifly motor mount today.
Found out the bolt hole pattern for the Bigfoot motor wouldn't work so some fabricating was in order. Took the"X" mount and transfered it's mounting holes to the forward section of the mount and drilled four 4mm holes.
Then made two 1/8 inch aluminum plates, one forward and one aft to support the new motor. Everything buttoned up nicely but for added strength, I might run it by my buddies weld shop and have him tig weld the plates in place.
The scale Wilga's motor protrudes out a bit so I used the TLAR method (That Looks About Right) to set the distance. Come to find out it's perfect.
Now to epoxy a 1/4 ply bulkhead on the inside of the firewall for added strength for the outrunner. The stock ply firewall seems just a bit thin for my tastes.
Old Jan 03, 2012, 10:36 PM
Joined Oct 2000
Power ON!
All ready for a test run!
ESC mounted with four screws to the firewall but before I did that, some 3M VHB double back tape was added to reduce vibrations and cushion the esc. I use this tape on my scale helis and it works wonders to reduce vibration to the gyro.
Motor installation complete.
Old Jan 03, 2012, 11:29 PM
Joined Oct 2000
Callie got the graphics done.
I had her make extras thus the extra quantity shown on the files. I also had her modify the name on the side of the fuselage and the engine graphics shown on PDF 2.
Contact her if you would like a set.
Old Jan 03, 2012, 11:31 PM
L = (1/2) d v2 s CL
WAGliderGuy's Avatar
United States, WA, Seattle
Joined Feb 2010
Very cool!! I remember seeing one of these things fly - on floats. It got off faster then the Beavers and the engine sounded great (and loud)! Keep up the great work! Where do you fly at?
WAGliderGuy is offline Find More Posts by WAGliderGuy
Old Jan 03, 2012, 11:37 PM
Joined Oct 2000
Hi WAGliderGuy,
Sumner and Orting or anywhere there is an open field. I used to belong to the RAMS until their membership costs went through the roof!
I see you've built a Piltus Porter. Very nice and I enjoyed your video. Keep up the great work!
Old Jan 04, 2012, 11:50 AM
CaptAhab's Avatar
USA, TX, Crosby
Joined Sep 2007
Well Rudderman, there'll be another Wilga cruising Texas skies soon...
Delivered in good condition, but the slat section over the cockpit has some pretty noticeable dents.
Anyone have suggestions for getting them out ? One other minor problem is they drilled one of the gear shock mounts too large so I'll have to re-drill and go next size for the mount bolt. All I see for now.
Thanks rudderman for helping with the power system, I'm using the same setup as his and should have it all in the next few days.
Build Log PZL 104 Wilga 35 - KIT from Fricsh Modellbau Collapse Giant Scale Airplanes 20 Feb 20, 2012 01:15 PM
Sold E*Star PZL-104 Wilga Kit Wing&aPrayer Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2011 05:30 PM
PZL Wilga..I musta been crazy! oforberg Indoor and Micro Models 9 Feb 18, 2004 08:10 AM
FS: Hobby Club PZL Wilga Scale Rudderman98 Aircraft - Electric - Airplanes (FS/W) 7 May 01, 2002 01:44 PM
