Old Oct 29, 2001, 04:54 PM
San Jose, CA
Joined Sep 2001
Axis for Gyro on an Eco 8
I just got my Gyro and I'm wondering on what axis should I set it up on? The Main shaft (up/down) or the tail boom (front to back)? I know that I should mount it behind the main shaft, I just don't know if it should be lined up with the axis of the main rotor shaft or not.
Thanks in advance for you help
Haro is offline Find More Posts by Haro
Old Oct 29, 2001, 05:30 PM
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
The closer to being in line with the main shaft the better. Up or down makes no diff. unless you are doing 3D.
Even if you mount it on the nose, or tail though, it will pivot and do its job.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Oct 30, 2001, 02:42 PM
GWRIGHT's Avatar
United States
Joined May 2000
Actually... the ONLY thing that's important about the location you mount the gyro is to place it in an area of lowest vibration. The gyro senses yaw,.. and the entire helicopter yaws at the same rate (unless it's made of rubber ). You could place it behind the mast, in front of the mast, up in the nose, on the end of the tailboom, on a skid,..etc. and it would work equally as well as long as the viration levels were all the same.Height doesn't matter either. The gyro can be low or high in the heli. Just make sure it's in the lowest vibration area. Whenever I get a new machine (new design), I play with the gyro in every nook and cranny,.. giving it a few flights each, and see where the gain can be the highest,..as this is a psuedo-indicator of vibration levels.
GWRIGHT is offline Find More Posts by GWRIGHT
wider blades on an eco-8? (cut-down 550's) helifrek Electric Heli Talk 31 Oct 05, 2005 07:55 PM
Question Fusion Motor On An Eco 8 Superman217 Electric Heli Talk 9 Apr 03, 2004 11:25 PM
What is a Throttle Curve and Why Would I Use it on an Eco 8? wannabe Electric Heli Talk 7 Mar 31, 2004 06:08 PM
Berg5DSP with Azzar on an Eco 8? cactus Electric Heli Talk 5 Dec 12, 2003 12:25 AM
Anyone ever make or use a carbon fiber mainshaft on an eco 8? jtthebiggafigga Electric Heli Talk 1 Dec 02, 2001 03:58 AM
