Old Dec 29, 2011, 08:55 AM
littleimp is offline
Find More Posts by littleimp
Joined Dec 2011
Can you confirm 'c' charge rate please.
New to electric flight and have been reading about 'c' lipo charge rates.
I have a 3s 1600mah turnigy nano tech. Am I right in thinking that a 1C charge would be at 1.6A? The battery is rated at 5C charge which would be 8A?
My 150w ECO8 charger is rated at 7A so obviously not good enough for 5C but I would like to charge at 2C which seems to be quite a common rate for these batteries @ 3.2A
Are these figures correct?
Is it best to charge as normal or in balance mode (which is what I've been using)
thankyou.
littleimp is offline Find More Posts by littleimp
Old Dec 29, 2011, 09:05 AM
cliffh is offline
Find More Posts by cliffh
Gustavus, OH
Joined Oct 2007
thankyou.
Yes, your numbers are correct. 1C = 1.6A. Charging at 2C would be 3.2Amps.
You don't NEED to balance every charge, but you asked if it is best. Yes, it is best to balance every charge. Depending on your charger, and how well your pack stays balanced, charging may take just a little longer to balance charge, but it isn't much time at all.
Have fun flying!
Cliff
cliffh is offline Find More Posts by cliffh
Old Dec 29, 2011, 09:17 AM
Joined Dec 2011
Ok, thankyou for that. I have a pair of hobbyking ECO8 chargers 150W/7A running off a 100ah caravan battery for my field chargers. I'm going 100% electric with a mixture of foamies & balsa conversions. It's so much easier & cleaner.
Here's what inspired me to go 100% electric, a fly-in at a local club. Check out his electric spitfire with sound in the other RADMAC vid too!!
JOHN RANSOME FLYING HIS HEINKEL HE111 WITH V1 DOODLE BUG PARASITE ! - RADMAC 2002 (2 min 24 sec)
Amazing electric HE-111 with sound.
Here's the spit
JOHN RANSOME - RADMAC - SCALE DAY - 2008 - SPIT , 109 , B17 , RC PLANES (11 min 33 sec)
Old Dec 29, 2011, 09:42 AM
cliffh is offline
Gustavus, OH
Joined Oct 2007
Wow, that is a beautiful airplane. I really love scale aircraft.
Your charging setup is very neat. I really should make something along those lines, but I still end up with a bit of a tangle of wires during charging.
Cliff
Old Dec 29, 2011, 10:03 AM
steveclv is offline
Find More Posts by steveclv
Lake Havasu, AZ
Joined Jan 2011
With todays cheaper LiPos you really should be balance charging every time.
A few years ago and also today if you can afford them, you could buy 'matched cell' LiPos that were truly matched in terms of their Internal Resistance. That is the measure of how much heat is generated in the cell and ultimately how much current it can deliver and is the reason why cells become unbalanced during use.
I don't think you can even purchase a LiPo charger that doesn't balance charge these days and because of the poorer quality of the cell matching in modern packs, it's always best to balance charge every time.
Although there are fast charge LiPo packs out there, charging at 1C-2C is still the best way for pack longevity. Charging at 5C is going to shorten the usable life of a pack eventually regardless of what is claimed on the plastic wrapper.
steveclv is offline Find More Posts by steveclv
Discussion Max Charge Rate (C) RoboSerg Batteries and Chargers 3 Dec 23, 2011 05:36 PM
Question can the battery C-rating effect my charge rate? 1C is getting boring!!! SmoothCruizer2 Batteries and Chargers 10 Feb 12, 2009 08:48 AM
Help! Lama V3 - can somone please confirm? Issue Fixed - bad Tx. G Zed Coaxial Helicopters 15 Oct 06, 2008 06:34 PM
Can a charger with a 2000mah charge rate charge a Gp3300? butserflyer Batteries and Chargers 7 Jun 02, 2004 07:43 AM
Can some one explain the C in charge rate? And what do you charge your He-cell at? rspiegel Batteries and Chargers 10 Jan 08, 2003 09:50 AM
