Old Feb 03, 2013, 10:33 PM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
To get rid of shakes balance the props, that's the best thing I've experienced. You gain significantly in precision as well, just search the thread for all the different methods.
airpower is offline Find More Posts by airpower
Old Feb 03, 2013, 11:14 PM
ChrisJ800 is offline
Find More Posts by ChrisJ800
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
Originally Posted by antslake View Post
I just got a MQX 3 days ago. I had no idea how much I would like quadcopters. I am so hooked now. I enjoy it way more than flying a heli. We held an indoor funfly this weekend, and I strapped a #11 keychain cam to it.
Towards the end of the video I collided with a plane doing 3D, and then I flew it up through the beams twice.
I had the camera mounted with velcro on the bottom, but the video was kind of shakey, if anyone could offer a suggestion for mounting to get rid of the shakes, I wouldn't mind.
http://www.youtube.com/watch?v=McvA8c7Bdgc
Dont use velcro as its too wobbly. I use a small bit of gyro mounting tape but a bit of thin padded double sided tape would do, and a velcro strap tightened to the frame so it doesnt move around. I put a pic and vid earlier in this thread.
ChrisJ800 is offline Find More Posts by ChrisJ800
Old Feb 04, 2013, 02:07 PM
G-Man is offline
Find More Posts by G-Man
I've reached my critical AoA
G-Man's Avatar
United States, VA, Winchester
Joined Dec 2005
So to date, what is the best battery for me to get for this? I just ordered the MQx and should have it in a few days. I tried going back through the threads, but it would take days to look, and searching also gave a lot of posts not related to what battery to get. Hope you understand. PM me if you do not want to waste threads...
G-Man is offline Find More Posts by G-Man
Old Feb 04, 2013, 02:10 PM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
IMHO:
These
unfortunately status BK
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Feb 04, 2013, 02:21 PM
Greg Head is offline
Find More Posts by Greg Head
Joined Aug 2012
I have a couple of those batts, never hit lvc with a 6 min timer. work good, just cut off battery holder and use velcro for cog.
Greg Head is offline Find More Posts by Greg Head
Old Feb 04, 2013, 02:36 PM
jgestner is offline
Find More Posts by jgestner
United States, WI, Merrill
Joined Jun 2011
If by cog you mean center of gravity, I don't think in most cases that you should have much of an issue because one of the things that the AS3X stabilization does is keep the mQX level. If you aren't over weight, the AS3X should be able to take care of center of gravity issues for you.
John in Merrill
The E-flite bats are fine, as are the hyperion and the turnigy nano-techs. For availability it's E-flite, for price it's Turnigy Nano-tech.
jgestner is offline Find More Posts by jgestner
Old Feb 04, 2013, 02:42 PM
Joined Aug 2012
John in Merrill
It would probably have been fine but without cutting off the holder and centering them battery it sticks way off to one side because it is so much bigger. I have no idea if it matters, just what someone else recommended and I figured I would put it in there so the guy asking would know what to do when the larger batteries came and didn't fit in the holder. I have a lot of faith in as3x, I like the tap a corner test while hovering and watching it correct. If it can do that I am sure it could correct for a weird battery placement.
Old Feb 04, 2013, 02:45 PM
G-Man is offline
G-Man's Avatar
Joined Dec 2005
Originally Posted by mikefromgermany View Post
IMHO:
These
-mike-
CRAP!, Back-ordered in US.
Old Feb 04, 2013, 05:24 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
The Hyperion 550s provide a 25% increase in available power over the stock batts, and they're usually good for around 300 cycles at 5c charge before they start to fade away. Plus, they're only $6 USD. Definitely the best performance & by far the longest lifespan of the bunch.
Joel
turboparker is offline Find More Posts by turboparker
Old Feb 04, 2013, 05:57 PM
G-Man is offline
G-Man's Avatar
Joined Dec 2005
Originally Posted by turboparker View Post
The Hyperoin 550s provide a 25% increase in available power over the stock batts, and they're usually good for around 300 cycles at 5c charge before they start to fade away. Plus, they're only $6 USD. Definitely the best performance & by far the longest lifespan of the bunch.
Joel
Perfect! Just ordered a few.
Old Feb 05, 2013, 09:39 AM
ColSonders is offline
Find More Posts by ColSonders
United Kingdom, England, Consett
Joined Feb 2012
Those turnigy batteries are good for about 12 minutes of hovering or about 9 minutes of what I would consider normal flying (forward flight circuits). I've got an 8 minute timer on my MQX and the batteries have around 3.8v left afterwards so always figured that was safe.
As for the balancing issues...well it's not really issue as it's a quad with a microprocessor specifically designed to balance the whole system. I also use those batteries in a Blade 120SR though and it is important to remember to get your CoG right. if you can manually centre the gravity on a quad though it leaves more capacity in the motors for manouvers so it's still worth doing in my opinion.
ColSonders is offline Find More Posts by ColSonders
Old Feb 05, 2013, 02:45 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Balance will not affect the flight performance up to a point, but if you have an off balance condition, it will cause uneven wear on the motors, which may be leading to some of the failures we're seeing.
jasmine2501 is offline Find More Posts by jasmine2501
Old Feb 05, 2013, 10:26 PM
G-Man is offline
G-Man's Avatar
Joined Dec 2005
Got my mQX today, what a blast! Now I need to get a better Key-chain Camera, mine's pretty old.
Old Feb 05, 2013, 11:16 PM
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
808 #16 or #18 seem to be the best and there are dedicated threads on them here if you search.
Old Feb 06, 2013, 06:27 AM
jgestner is offline
Joined Jun 2011
There is a new US source for the cameras. An RC Groups member has started an online storefront at massiverc.com. He's a great guy and into the RC sport, not just a salesman. Good prices on quads and parts, with quick inexpensive shipping from the US. He is carrying mostly mini quads, but has 3 different lensed versions of the #16 cam.
John
http://www.massiverc.com/PrestaShop/en/
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
