Old Dec 25, 2012, 09:57 PM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
Originally Posted by Firepower View Post
I just bought a MQX and a WL 949 and the WL 949 seems to be fully stabilized with accelerometers.
But the MQX does not seem to be fully stabilized and you really need to counter any tilts or it just slides down into the ground. I am using a Futaba 9C with a spektrum module.
Is this how the MQX is suppose to work or have I missed something?
I think the MQX is very stable and I don't have the problem that you have...I can hover mine forever without it sliding to the ground....
Jake8131 is offline Find More Posts by Jake8131
Old Dec 25, 2012, 11:38 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
The mQX is neutrally-stable - just like a CP heli or purpose-built aerobatic plane. It simply goes where you point it & keeps on doing that until you tell it to do something else. Put it in a hover in calm air, drop the sticks, and it will hover hands-off, then slowly drift away. Put it into a bank & it will hold that bank-angle until you level it out. It's a gyro-based system, so it has no way of sensing which way is 'up'.
Originally Posted by Aphro View Post
So order the sealed bearings without grease and then what is recommended to use for lubrication?
I use TriFlow on my mQX & all of my helis.
Joel
turboparker is online now Find More Posts by turboparker
Old Dec 26, 2012, 03:08 PM
Aphro is offline
Find More Posts by Aphro
ChuckTseeker Super Fan
Aphro's Avatar
Joined Jan 2012
Thanks for you help Joel
My TriFlow is on the way along with Boca main shaft bearings for my mcpx and nano (2x6x3 and 2x5x2). Curious to see if they make any difference in performance... I ordered them without grease, so just soak them in the TriFlow and wipe down before install?
For the MQX I picked up the MH Aluminum motor mount kt for $69.99. Lighter than stock and I am hoping they will take some of they play out that the stock ones have.
I will also be trying the TriFlow out on my bike chain this Spring
Aphro is offline Find More Posts by Aphro
Old Dec 26, 2012, 05:25 PM
RICH S is offline
Find More Posts by RICH S
Joined May 2000
I have an MQX and like it, however it does feel "sloppy" compared to the little direct drive units like the ladybird and QR-1. If you apply a little throttle and move them around in your hand, you can tell the diference. If you keep the QR1 level, and move it side to side (level), you can hear the motors working. On the MQX the system only kicks in when it is tilted. The little QR 1 feels like it is on rails, where as to me, the MQX feels like a 3D slowflyer or fixed pitch heli, totally different handling systems.
RICH S is offline Find More Posts by RICH S
Old Dec 26, 2012, 05:27 PM
Joined Jul 2009
Aphro,
You're welcome! The only times I've noticed a performance boost from using Bocas on my helis is when the stock grip bearings or tail-shaft bearings were sloppy. I have never noticed an increase in performance by using them on the mainshaft alone - but then I'm not an insane headspeed guy. However, they usually last a lot longer than the cheapie bearings that are typically used in RTF & BNF birds. I have yet to try them in my mQX. However - given the differences in drag between rotors & the general crappiness of the stock bearings, the Bocas might provide a noticeable improvement.
Regarding lube - yeah, just soak them in TriFlow. It carries Teflon & penetrates like crazy.
Joel
Old Dec 26, 2012, 08:08 PM
jdre is offline
Find More Posts by jdre
Joined Mar 2010
MQX problems with DX8
I have a very strange issue with my new MQX. With my DX8, displaying DSMX and Telemetry bars:
1. Right rear motor does not run.
2. If throttle on even at slowest speed, the other 3 motors rev up gradually to high speed, uncommanded by me.
With my old RTF DSM2 Tx from my Champ, MQX works correctly. My DX8 is working correctly with my DSM2 fleet (Beast,Sbach, Mcpx,Msr) and my AR6115 DSMx in my old CP.
I made sure I used a fresh model memory, and reset it besides and tried again, same results. Any ideas what might be wrong? I think its the MQX DSMx decoding of signals. I will probably have to exchange it..
jdre is offline Find More Posts by jdre
Old Dec 26, 2012, 09:39 PM
Aphro is offline
Aphro's Avatar
Joined Jan 2012
Do you have it set up as plane or heli in your DX8?
Old Dec 26, 2012, 09:42 PM
jdre is offline
Joined Mar 2010
Plane, because no swashplates.
Old Dec 26, 2012, 10:01 PM
ChrisJ800 is offline
Find More Posts by ChrisJ800
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
I believe I read that DSMX wont work with some DSM2 rx's, such as Orange. Can you change the DX8 to operate in DSM2 for the MQX? If I get a new TX or module it will need to operate in DSMX or DSM2 mode so I can use my fleet of Orange RX's.
ChrisJ800 is offline Find More Posts by ChrisJ800
Old Dec 26, 2012, 10:11 PM
Gary Hoorn is online now
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
Chris,
We have 2 club members flying with DX8 transmitters and using orange receivers. The DX8 will switch from DSMX to DSM2 as necessary. I have both types of receivers in my fleet.
Gary
Gary Hoorn is online now Find More Posts by Gary Hoorn
Old Dec 26, 2012, 10:16 PM
Aphro is offline
Aphro's Avatar
Joined Jan 2012
How old is your DX8? It is not one of these is it? Click on link and then the product bulletin...
http://www.horizonhobby.com/products...servos-SPM8800
Old Dec 26, 2012, 10:25 PM
Aphro is offline
Aphro's Avatar
Joined Jan 2012
I have my MQX set-up as heli in my DX8 and it works perfectly...
Old Dec 26, 2012, 10:45 PM
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
ah yes found the product buletin. So if you have a PID beginning with one of the following prefixes: HS, HH, HT, HE, HA, HO, HM, HR then that could be the problem but strange it works Ok with your other BNF fleet.
Old Dec 27, 2012, 02:21 AM
jdre is offline
Joined Mar 2010
Mine is HC, not recalled yet. I also emailed Horizon. My problem is so unusual it is not on the internet as far as I can search. I need to borrow another DSMX Dx6/8 Tx maybe at the retailer,and try it with the MQX.
Old Dec 27, 2012, 08:26 AM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
Originally Posted by airpower View Post
Plus mode is a lot easier, try it!!!
Yep thats what i did and it is a lot easier! Thanks!
electricrc68 is offline Find More Posts by electricrc68
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
