Old Dec 09, 2012, 04:20 AM
Eric the Red is offline
Find More Posts by Eric the Red
United Kingdom, Southend-on-Sea
Joined Jan 2012
Originally Posted by jdr00ejr View Post
I guess my primary concern is can a bad motor harm the board? If a motor burns out or goes bad can it cause the board to have issues? And if the motor fails in midflight and I crash again what's the chances I'm going to break the new board?
Glad you asked! I had a burning smell and the front left kept running at throttle down. In England, there is a man who repairs MQX boards - I sent it to him, and he returned it with a note to replace the FL motor otherwise the board would burn out again. I never told him which motor was running on - he just sussed that from the board!
Eric the Red is offline Find More Posts by Eric the Red
Old Dec 09, 2012, 09:12 AM
ChopperJack is offline
Find More Posts by ChopperJack
Moving Parts
ChopperJack's Avatar
United States, AR, Texarkana
Joined May 2011
Circuit Board Guided Tour
The three axis controller (AS3X) gets input from sensing devices and pilot input from the receiver then translates all that into a "signal" which is sent via a couple of driver transistors per motor to adjust the voltage of each motor. If a motor were to short out, that would overload the final driver transistor and most likely burn it out. I seriously doubt the designers built output protection into the motor drive circuit which could be something as simple as a fuse.
Take a look at each of the motor connectors on your circuit board. You will notice the larger final transistor with its center contact attached to one pin of the connector. Then follow that back a bit and notice the little bit smaller pre driver transistor which interfaces with the controller which is the big integrated circuit in the middle of the board.
Now, take a look at the IC in the corner next to the antenna. That is the receiver circuit. You will also notice a smaller shiny square thing. That is the crystal which is required by the receiver. A radio receiver requires an oscillator in order to work (unlike me, I just require money to work - lol). Most oscillators require a crystal. Crystals are fragile. If you crack the oscillator crystal due to extreme shock, the receiver will either stop working and/or work erratically. Or it may keep working and just be an accident waiting to happen.
The controller also requires some sort of oscillator but may not be a crystal. If that component is damaged, obviously, the controller will loose its mind so to speak.
ChopperJack is offline Find More Posts by ChopperJack
Last edited by ChopperJack; Dec 11, 2012 at 06:17 PM. Reason: Modification of terminology
Old Dec 09, 2012, 10:33 AM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by ChopperJack View Post
The controller gets input from accelerometers.....
FYI - the mQX controller uses a 3-axis gyro only. It doesn't have accelerometers.
Joel
turboparker is offline Find More Posts by turboparker
Old Dec 09, 2012, 08:55 PM
Moving Parts
Joined May 2011
Joel
"It’s sleek. It’s high-tech. It’s an RC flying experience unlike any other. It’s the exciting Blade mQX—the world’s first quad-copter equipped with the advanced AS3X (Artificial Stabilization 3-aXis) System. The sense of precise control this system gives an mQX pilot rivals that of bigger quad-copters that cost a whole lot more."
http://www.horizonhobby.com/products...qx-bnf-BLH7580
More about AS3X:
http://www.rcgroups.com/forums/showthread.php?t=1525268
More about sensing devices:
https://www.sparkfun.com/pages/accel_gyro_guide
Introduction to nanotechnology:
http://nanogloss.com/mems/what-is-a-...#axzz2En7pKLSF
Old Dec 09, 2012, 09:07 PM
Joined Jul 2009
Ok, obviously I don't know exactly what the controller is using for position information. But neither do you. Here is how Blade describes it, "Its sleek. Its high-tech. Its an RC flying experience unlike any other. Its the exciting Blade mQXthe worlds first quad-copter equipped with the advanced AS3X (Artificial Stabilization 3-aXis) System. The sense of precise control this system gives an mQX pilot rivals that of bigger quad-copters that cost a whole lot more."
Blade doesn't use the term "gyro" or "accelerometer." It's an exciting "artificial stabilization system." If you or anyone else want to call it a gyro then I don't really have a problem with that.
I know exactly what it uses, as so do most of us who have been flying AS3X-equipped aircraft since the beginning. It uses a 3-axis mems gyro, as do all AS3X-equipped aircraft. No accelerometers. There is a very big difference between the two. Just doing my part to combat misinformation.
Joel
Old Dec 09, 2012, 09:13 PM
Moving Parts
Joined May 2011
Joel
Thank you sir! Point taken.
Old Dec 10, 2012, 12:59 PM
llbr22 is offline
Find More Posts by llbr22
llbr22's Avatar
USA, CA, Oakland
Joined Nov 2009
I taught my kid how to fly
llbr22 is offline Find More Posts by llbr22
Old Dec 10, 2012, 07:22 PM
iTz Nicholas72 is offline
Find More Posts by iTz Nicholas72
Joined Nov 2010
How realistic is Phoenix V4 when it comes to doing flips with the MQX?
Playing with ours at the shop makes it seem too easy to do flips. Have the simple setting slider to 100% and 27% expo on elevator and aileron. Rolls and flips require a decent amount of altitude but doing a flip toward one of the rotors only needs about 3-4 feet total.
iTz Nicholas72 is offline Find More Posts by iTz Nicholas72
Old Dec 10, 2012, 07:38 PM
jdr00ejr is offline
Find More Posts by jdr00ejr
United States, IN, Indianapolis
Joined Oct 2012
I did it on Phoenix multiple times over the course of 2 days - then got up the guts to try it in real life. Got high enough - WAY UP THERE THE FIRST TIME - and let her rip! I've not turned back. It's an insane rush the first time and very cool there after. I should add - I'd never flown a Quad before. Got the Quad, flew it around a bit. Less than 10 times and started trying to flip it on Phoenix, all over the course of 3 days. It was day 4 of ownership when I flipped it the first time.
If you can do it in Phoenix, and if you can recover from fast flight, give your self plenty of altitude and go for it on the real deal!
jdr00ejr is offline Find More Posts by jdr00ejr
Old Dec 10, 2012, 08:23 PM
Joined Nov 2010
I've been flying out demo MQX along with the simulator when its slow too. Getting pretty good at flying around as long as I keep the front away from me. I can hover nose in but only if I'm stable prior to spinning. Maybe if its calm tomorrow I'll fly the MQX in front of the store. Grab attention for the store and maybe even try to flip it...
Old Dec 10, 2012, 08:42 PM
jdr00ejr is offline
Joined Oct 2012
For me, a corner flip is easier, more stable, and takes less vertical space. That's the one I did first.
Old Dec 10, 2012, 10:25 PM
FutureVRPilot is offline
Find More Posts by FutureVRPilot
FutureVRPilot's Avatar
Sonoma
Joined Jul 2009
Here is my Video, Did the recording over the weekend and at the same time my DAD had a stroke on Friday night and Sunday morning he past away. I made this video in his memory, Hope you like it
Quad night flight in HD (4 min 35 sec)
FutureVRPilot is offline Find More Posts by FutureVRPilot
Old Dec 11, 2012, 07:24 AM
Joined Jul 2009
FutureVRPilot,
That was a very nice tribute to your Dad! Sorry to hear about your loss. Alzheimer's got my Dad just over a decade ago, but I will always remember the good times we shared. My thoughts are with you & your family.
Joel
Old Dec 11, 2012, 06:53 PM
RICH S is offline
Find More Posts by RICH S
Joined May 2000
New MQX Owner
Had the QR 1 first, the QX seems like a lightly wing loaded slowflyer airplane, and is nice. The little QR 1 stabilization system seems a lot more locked in. These are fun
RICH S is offline Find More Posts by RICH S
Old Dec 11, 2012, 06:58 PM
jdr00ejr is offline
Joined Oct 2012
Been looking at the little QR-1, but don't have the funds yet. I love my MQX and am not sure I'd mess with the QR-1 enough. I guess I could fly it inside maybe when I can't fly the MQX outside. Can't imagine keeping track of that QR-1 outside, I have a hard enough time keeping orientation on the MQX.
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
