Old Dec 07, 2012, 05:09 PM
ChopperJack is offline
Find More Posts by ChopperJack
Moving Parts
ChopperJack's Avatar
United States, AR, Texarkana
Joined May 2011
Originally Posted by airpower View Post
The solution for motor problems for me was,
Wasnt it the ccw motors that keep failing? Its the one with two cooling holes.
I took two CW/or four cooling hole motors, mounted them and plugged them in backwards.
Yes yes i know youre not suppossed to run a brushed motor in the wrong direction, but in the 6 months since i have done this i have not had one motor failure. The four cooling hole motors just have an amazing longevity even going backwards!
Brilliant!! This is a perfect example of why I like to hang out here.
ChopperJack is offline Find More Posts by ChopperJack
Old Dec 07, 2012, 05:52 PM
Darsh is offline
Find More Posts by Darsh
Tinkerer of makeshift failures
Darsh's Avatar
Joined Jun 2012
Does this guy look familiar?
Darsh is offline Find More Posts by Darsh
Old Dec 07, 2012, 05:59 PM
jdr00ejr is offline
Find More Posts by jdr00ejr
United States, IN, Indianapolis
Joined Oct 2012
Yes indeed it does. Selfishly - could I make a request if you are modeling that one? I'd love to see it in Carbon Fiber but with a bright color (like Red or something) up front and a different color (maybe the Blue) across the back. I took one of your CF TDR Canopies and made the eyes Red, and the wrap under red, and made the back flap Blue - and that helps me immensely with orientation.
I've gotten somewhat proficient (albeit insanely slow) with recoloring your templates in MS Paint, but can't figure out how to do the carbon fiber look.
EDIT TO ADD: And while I'm asking things of you - do you have any "instructions" for how to fold the fighter body? I love it - but I'm struggling greatly with wear to fold it so it looks right.
BTW....I should have started with THANK YOU VERY MUCH FOR ALL YOU DO!
jdr00ejr is offline Find More Posts by jdr00ejr
Old Dec 07, 2012, 06:57 PM
Darsh is offline
Darsh's Avatar
Joined Jun 2012
I'll have to build and test one - then it will come the time for custom colors
Props to you for the patience! Using ms paint to do that must be quite a chore. I'd suggest using something a little more advanced, but i do understand that not everyone wants to invest time/money/patience for graphic editing.
As per folding instructions for the fighter, you're not the first one to ask for them, so i prepared this:
I hope it helps.
Old Dec 07, 2012, 07:04 PM
jdr00ejr is offline
Joined Oct 2012
Thank you Darsh. Found your blog and found the red/blue fighter. Now I'm even more determined to figure this out. Thank you very much for the diagram!
PS: downloaded gimpshop but haven't had time to learn it. Wish I could afford one I the nicer ones.
Old Dec 07, 2012, 07:35 PM
TomQ is offline
Find More Posts by TomQ
Joined Mar 2012
Well....I'm getting no love at all from the Board - so I ordered one from the Bay - $27. Now the hard part - waiting. Once the new board arrives, and the new motors/blades arrive, I may just overhaul it all at once. I ordered the v929 motors so need the old motor plugs to make them work. Don't know how to tell which motors are okay and which ones aren't without just replacing them. Any ideas?
Chopper Jack - what kind of paint did you use?
I suggest you try just replacing the board, it should resolve your issues. Save the parts that you ordered for future needs. If you see one corner of your quad is not performing up to the others than it may be due to the motor.
I have done a bit of painting of parts and found the ACE Hardware Fluorescent paint to perform better than Rust-Oleum. When painting over dark parts I found it best to start with a white primer. For white I used only the white primer and found it lasted through hundreds of crashes well.
TomQ is offline Find More Posts by TomQ
Old Dec 07, 2012, 07:54 PM
jdr00ejr is offline
Joined Oct 2012
I guess my primary concern is can a bad motor harm the board? If a motor burns out or goes bad can it cause the board to have issues? And if the motor fails in midflight and I crash again what's the chances I'm going to break the new board?
Old Dec 07, 2012, 07:55 PM
iTz Nicholas72 is offline
Find More Posts by iTz Nicholas72
Joined Nov 2010
I'd be surprised if a motor going bad would kill the board. Unless it shorts and the board doesn't have any type of protection and you keep giving it power after noticing it not working I think you'll be fine.
iTz Nicholas72 is offline Find More Posts by iTz Nicholas72
Old Dec 07, 2012, 07:58 PM
TomQ is offline
Joined Mar 2012
I replace alot of motors. More than 30 in total. I have replaced at least 18 CW and 12CCW. At least two of those CCW motors were run backwards as CW motors. None of the backward running motors lasted more than 25-30 flights when I average more than 100 flights per motor usually when run in the correct orientation.
Our results are far from statistically significant individually, that they disagree in results makes it even less likely that we have either found a trend worthy of note. And I believe it is a moot point because I have not had out-of-the-ordinary problems with mQX motors recently. My first two mQX's had CW motors that failed within a short time, my last two have not, that seems to be my experience overall with motors.
Old Dec 07, 2012, 08:04 PM
TomQ is offline
Joined Mar 2012
I do believe there is some very small chance that a bad motor could hurt a board. I have not seen it or heard of it happening. I have replaced 7 boards and at least 30 motors. I do not have the concern that you do.
Old Dec 07, 2012, 09:05 PM
jdr00ejr is offline
Joined Oct 2012
Thanks guys. Okay, I think I'll try the new board with existing motors and see what happens.
Old Dec 07, 2012, 09:21 PM
Jake8131 is online now
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
Short flight in my living room with a paper canopy...easy to see...
BLADEMQX OOP (1 min 30 sec)
Jake8131 is online now Find More Posts by Jake8131
Old Dec 08, 2012, 06:21 PM
Darsh is offline
Darsh's Avatar
Joined Jun 2012
Here we go... attached some pictures of the test fitting, and some variations on the canopies... you know the rules
Will post some more as soon as i'm done working on them.
Old Dec 08, 2012, 07:57 PM
jdr00ejr is offline
Joined Oct 2012
Awesome Darsh! Thanks for all you do.
Old Dec 08, 2012, 09:01 PM
Thetis is offline
Find More Posts by Thetis
Always, against the wind
Thetis's Avatar
United States, IL
Joined Oct 2011
Thanks Darsh, you are Da man
Thetis is offline Find More Posts by Thetis
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
