Old Nov 10, 2012, 04:58 AM
kenbad is offline
Find More Posts by kenbad
kenbad's Avatar
Joined Dec 2011
Originally Posted by turboparker View Post
Thanks, guys!
I simply mounted the cam to the square plate below the battery with a piece of Velcro. I used a strip of masking tape for backup. The reason for the low vibration level is that I carefully balanced each rotor.
Regarding sources for the #16 cam - be careful, as there are some fakes out there. (BTW - the #16 has the best 720p video of all the 808 cams.) Here is the source for accurate information on all things keychain-cam related: http://www.chucklohr.com/808/index.shtml
Joel
Thanks thats how I do it and still a little vibes, what method do you use for balancing these props?
I orders one of the 808 #16V2 cams used the recommended seller from that site you posted the link to, thanks again
kenbad is offline Find More Posts by kenbad
Old Nov 10, 2012, 09:05 AM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
I dynamically balanced each rotating assembly, using clear tape. I simply played with the bird in my hand for a minute to determine four orientations that would each leave a different rotor running & stop the other three. I spooled her up in my hand, checked each rotor for vibration, and then applied tape to the lightest blade, as needed.
Joel
turboparker is online now Find More Posts by turboparker
Old Nov 10, 2012, 11:00 AM
Jake8131 is online now
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
My MQX just started doing this..it wants to got to the right and aft....which motor could cause this.....?
Jake8131 is online now Find More Posts by Jake8131
Old Nov 10, 2012, 12:26 PM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
A worn out right rear prop.
airpower is offline Find More Posts by airpower
Old Nov 10, 2012, 01:33 PM
Jake8131's Avatar
Joined Dec 2010
It looks brand new. but I will change it out and get back to ya!
Old Nov 10, 2012, 02:03 PM
airpower is offline
Have fun
airpower's Avatar
Joined May 2007
Run it up in your hand, look at the blade tracking, if theres a ghost it should be replaced. Also, check to see if there's vibration in that arm.
Old Nov 10, 2012, 02:08 PM
Jake8131's Avatar
Joined Dec 2010
That was it......it was the left rear blade...hmmmm....replaced it and now it flys great!
THANK YOU VERY MUCH
Old Nov 11, 2012, 04:51 AM
kenbad is offline
kenbad's Avatar
Joined Dec 2011
Joel
Ok cool, how do you determine the heavy blade?? Trial and error?
Old Nov 11, 2012, 08:17 AM
Joined Jul 2009
Yup. Put a piece of tape on one blade & spool-up. If the vibes are worse, move it to the other blade. If there is less vibration, add more tape. Rinse & repeat as needed. I can usually get it right within 3-4 iterations. I've been using this method for balancing heli tail rotors & props that are too small for my magnetic balancer for years. It's quick and easy once you get the hang of it.
Joel
Old Nov 11, 2012, 11:14 AM
kenbad is offline
kenbad's Avatar
Joined Dec 2011
Joel
Cool I found a youtube video balancing a motor likes this, looks effective. I also found several Android apps that sense vibes using my phones accelerometers Think I can put the two together and get it really smooth ...Thanks so much for all the direction
Old Nov 11, 2012, 11:24 AM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
The mqx comes built with a blade balancer installed. The double bearing.
Just disengage the gear a little. Then hold so the shaft is horizontal to the ground. You will find the heavier side of the blade. Very easy to check balance.
Daryoon is offline Find More Posts by Daryoon
Old Nov 11, 2012, 12:56 PM
Joined Jul 2009
I tried that method first. Unfortunately, beat-frequency vibrations associated with differential rotor-speed flight-control were still visible in the video until I dynamically balanced each rotor. There must have been just enough drag on at least a couple of rotors to make that method not quite sensitive enough for carrying the cam. But then mine had a few hours on the clock by the time I got around to balancing it for on-board video - including a bit of 'cartwheel practice' while flying fast & low circuits at extreme bank-angles.
Joel
Old Nov 11, 2012, 01:10 PM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Ah. Good to know.
Old Nov 11, 2012, 01:31 PM
ColSonders is offline
Find More Posts by ColSonders
United Kingdom, England, Consett
Joined Feb 2012
Ha, i'm glad it's not just me that's done that!
My MQX is currently out of action as I went to try it yesterday to find one of the blades not spinning up right,on further inspection there were several tiny balls stuck magnetically onto the motor....one of my bearings had spilt it's balls.
ColSonders is offline Find More Posts by ColSonders
Old Nov 11, 2012, 01:35 PM
RoboHeli is offline
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
Originally Posted by ColSonders View Post
My MQX has dreadful stability issues when descending, even with nothing attached, even without a canopy.
I'm not convinced it's normal behaviour and believe it's related to imbalance in either the props or the power levels of the motors or a combination of those things.
Adding extra weight magnifies this issue!
Originally Posted by Darsh View Post
I think that the instability in MQX while losing height rapidly has to do with vortex ring state, a condition commonly found in rotary wing vehicles (AKA "Settling with power").
http://en.wikipedia.org/wiki/Vortex_ring_state
Yes, it's not just your mQX ColSonders. My WLToys V929 quad exhibits exactly the same instability when descending quickly. I've learned to do kind of a spiral-looping thing with the cyclic control that lets me descend in a tight-ish column without it going unstable.
I first discovered the vortex ring state when I was carrying a #808 on my V929. The extra weight REALLY increased the effect and my first few flight videos always ended up in a pretty spectacular crash...lol Good thing I was flying over grass!
RoboHeli is offline Find More Posts by RoboHeli
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
