Old Nov 06, 2012, 08:22 PM
United States, WI, Merrill
Joined Jun 2011
Originally Posted by overmyhead View Post
So I have been having loads of fun learning quads with the MQX but recently it has developed a problem where the motors stop in mid air after hearing a brief squeal noise and it always flips over sharply and crashes and the motors stop. It will then fly for a variable amount of time and while flying just randomly does it again even when simply hovering in place.
The squeal noise always happens immediately prior and I don't know what the sound is.
Luckily it's tough and nothing breaks so far except a carbon boom but I need to fix this bug.
Any help appreciated,
You should have 2 spare motors ready at all times, one of each rotation, (clockwise/counterclockwise). Time to try them in each respective motor pod to troubleshoot which one is really giving you the problems.
jgestner is offline Find More Posts by jgestner
Old Nov 06, 2012, 11:09 PM
nforbesrc99's Avatar
United States, GA
Joined Jul 2012
Can it hold a #16 keychain camera with the wide angle lens?
nforbesrc99 is offline Find More Posts by nforbesrc99
Old Nov 07, 2012, 02:47 AM
United Kingdom, England, Consett
Joined Feb 2012
My first port of call would be checking the gears can't slip off the pinion, that could be what the squeal noise may be and it should be a simple fix...just push the gear further onto the carbon rod so it can't slip.
ColSonders is offline Find More Posts by ColSonders
Old Nov 07, 2012, 05:39 AM
New Castle, PA
Joined Oct 2006
I would say it could definitely lift it and fly around without much aerobatics. Even without the wide angle lense my mQX suffers stability while decending really bad.
markarch is offline Find More Posts by markarch
Old Nov 07, 2012, 05:43 AM
Joined Feb 2012
My MQX has dreadful stability issues when descending, even with nothing attached, even without a canopy.
I'm not convinced it's normal behaviour and believe it's related to imbalance in either the props or the power levels of the motors or a combination of those things.
Adding extra weight magnifies this issue!
As long as you take it easy though there should be no problem, I'm gonna have another go at sticking a tiny camera on mine for FPV flying now that i've got a ground station setup ready. Just waiting for a calm day so I don't have wind to contend with.
Old Nov 07, 2012, 06:59 AM
Tinkerer of makeshift failures
Darsh's Avatar
Joined Jun 2012
I think that the instability in MQX while losing height rapidly has to do with vortex ring state, a condition commonly found in rotary wing vehicles (AKA "Settling with power").
http://en.wikipedia.org/wiki/Vortex_ring_state
Darsh is offline Find More Posts by Darsh
Old Nov 07, 2012, 07:37 AM
Did you commit aviation today?
turboparker's Avatar
East Bethel, MN USA
Joined Jul 2009
The mQX is rated for carrying a 1 oz payload. It carries my regular #16 cam just fine, but I haven't tried the wide-angle lens.
Regarding stability issues during descent - as Darsh mentioned, it's the rotorcraft phenomenon known as vortex ring-state, and it can be a problem for full-scale helis as well. Once you're in it, the best way to get out is to get the bird moving forward ASAP & fly out of it. To prevent the problem, either keep the bird moving at a couple MPH or so during the descent, or make slow vertical descents.
Here's some on-board footage from my #16 cam. It's mounted under the belly at the CG. Just flying around my yard to see how the mQX handles the cam. I get into a bit of vortex ring-state @ 2:55 & again at 3:10. Notice that the problem doesn't happen during slow vertical descents or when the bird is moving horizontally during the descent.
Eflite mQX on-board video - 808 #16 cam (4 min 55 sec)
Joel
turboparker is online now Find More Posts by turboparker
Old Nov 07, 2012, 12:46 PM
If It Works, I'll Break It
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
Very nice flying..I envy your large flying area.............
Jake8131 is offline Find More Posts by Jake8131
Old Nov 07, 2012, 01:19 PM
kenbad's Avatar
Joined Dec 2011
Joel
oul
How do you mount your cam?? I see you have almost no vibrations, I have an 808 and used it on my mcpx and never got rid of the the vibes, I know using the quad should naturaly improve vibes but you seem to have none
kenbad is offline Find More Posts by kenbad
Old Nov 07, 2012, 03:12 PM
kenbad's Avatar
Joined Dec 2011
Mine arrived today!!!!! Already in love, can't wait to put my ketchain cam on it!!!!! what a joy to fly, instant gratification!
Old Nov 09, 2012, 12:20 PM
Philippians 4:13
Seward, NE
Joined Nov 2006
Where do you all get your #808 cameras? I had one a few years ago but it quit working...
I want one for my MQX
ty_horn is offline Find More Posts by ty_horn
Old Nov 09, 2012, 01:18 PM
kenbad's Avatar
Joined Dec 2011
i got from ebay
Old Nov 09, 2012, 04:20 PM
Jake8131's Avatar
Joined Dec 2010
Picked up one of these yesterday....very impressive...Heli-Max 1SQ:
Weighs a little over an ounce!
And, with a $25 add on box and cable, you can bind it to your DX6i.
Old Nov 09, 2012, 04:31 PM
East Bethel, MN USA
Joined Jul 2009
Thanks, guys!
I simply mounted the cam to the square plate below the battery with a piece of Velcro. I used a strip of masking tape for backup. The reason for the low vibration level is that I carefully balanced each rotor.
Regarding sources for the #16 cam - be careful, as there are some fakes out there. (BTW - the #16 has the best 720p video of all the 808 cams.) Here is the source for accurate information on all things keychain-cam related: http://www.chucklohr.com/808/index.shtml
Joel
Old Nov 09, 2012, 05:26 PM
Joined Jan 2012
Has it's own thread here : http://www.rcgroups.com/forums/showthread.php?t=1739348
mystman is offline Find More Posts by mystman
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
