Old Oct 24, 2012, 03:19 PM
ty_horn is offline
Find More Posts by ty_horn
Philippians 4:13
Seward, NE
Joined Nov 2006
one of the large gears on mine was slipping off of the shaft once so that caused that particular motor to take a little longer to reach speed because it had to spin then lift then engage with the smaller gear before it caught up with the other blades. Check your gears...
ty_horn is offline Find More Posts by ty_horn
Old Oct 24, 2012, 03:20 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Originally Posted by ColSonders View Post
If I understand the physics correctly that shouldn't happen
It should however make the tip occur in a different direction, eliminating the board and the other pair of motors as the problem.
Will start with that thanks.
Correct.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Eflite Gee Bee Racing
Old Oct 24, 2012, 04:22 PM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
Finally a nice flight in my small living room with a new Nano-Tech 600mah battery installed.
http://youtu.be/qX8gy7US1_w?hd=1
Jake8131 is offline Find More Posts by Jake8131
Old Oct 25, 2012, 12:00 AM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Originally Posted by ty_horn View Post
battery question:
Is there a favorite (cheap but quality) battery that you all like for your MQX? I need to order one or two. Thanks
I use these....
Old Oct 25, 2012, 09:33 AM
ty_horn is offline
Philippians 4:13
Seward, NE
Joined Nov 2006
Thanks Jake,
I might want to try those too. I wonder if the higher capacity and discharge rate would make a difference over the ones that I just ordered...
Are nanotecs only available from the other side of the ocean?
Old Oct 25, 2012, 09:47 AM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
Nano-Techs are Hobby King's inhouse brand. However you can find them on Ebay as well. With a markup of course.
Daryoon is offline Find More Posts by Daryoon
Old Oct 25, 2012, 10:52 AM
ty_horn is offline
Philippians 4:13
Seward, NE
Joined Nov 2006
That is what I thought... I just wondered if they were sold anywhere else that I wasn't aware of.
THanks
Old Oct 26, 2012, 11:39 AM
ty_horn is offline
Philippians 4:13
Seward, NE
Joined Nov 2006
Has anyone tried these props on their mqx? They have been using them on the 929 I guess. I wouldn't mind trying them when I need to order some props...
http://www.goodluckbuy.com/gws-gw-ep...r-2-pair-.html
Old Oct 26, 2012, 12:43 PM
jlcamp7 is offline
Find More Posts by jlcamp7
RC Logger Support
jlcamp7's Avatar
United States, WV, Hurricane
Joined Jan 2010
yep a discussion started here:
gws props for mqx
jlcamp7 is offline Find More Posts by jlcamp7
Old Oct 26, 2012, 04:28 PM
ty_horn is offline
Philippians 4:13
Seward, NE
Joined Nov 2006
Thanks.
Hey, I have to tell you guys every time a company impresses me with product support I feel like it is my duty to thank them on the forums so you all can see.
No matter what I do with my throttle trim I still am unable to bind sometimes. I just got done plugging, and unplugging my battery to try to make a connection 9 times and I simply couldn't not bind.
I called and told HH. The guy said that he would ship me a new board out on Monday and he simply said to throw away the defective one. Great support from Horizon Hobby every time!.
Old Oct 26, 2012, 11:11 PM
RD6000S is offline
Find More Posts by RD6000S
MotoGP
RD6000S's Avatar
United States, NY, Port Washington
Joined Aug 2006
Hey guy's,
Just checking to see if this quad is worth buying as I am very interested in it, my main concern is the motors how are they holding up?
The look like the tail motors from my SR120 and the do fail.....
Thank you
RD6000S is offline Find More Posts by RD6000S
Old Oct 26, 2012, 11:14 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Thanks.
What Tx?
Old Oct 27, 2012, 11:51 AM
ty_horn is offline
Philippians 4:13
Seward, NE
Joined Nov 2006
dx7 and dx5e
Old Oct 27, 2012, 12:00 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
dx7 and dx5e
Ok, so if it's happening on both, then 99.9% must be the mQx board.
Old Oct 27, 2012, 12:21 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
dx7 and dx5e
Try this.....plug in the battery....wait for blue lite to flash....
Stand back about 2 feet from the MQX.
Turn on the transmitter (either one), holding the binding switch towards you.
Let go of the trainter(bind) switch and move the rudder stick to the left immediatley and hold it to the left until the MQX binds.
Then, unplug the MQX and then shut off the transmitter.
Now turn on the Transmitter and then the MQX and see if it works!!!
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
