Old Oct 23, 2012, 06:01 PM
desertdweller is offline
Find More Posts by desertdweller
LOOK MOM! TEN THUMBS!
desertdweller's Avatar
USA, AZ, Mesa
Joined Aug 2009
Originally Posted by Gerry__ View Post
Which is why they say to calibrate with the tim all the way down.
Yup.
Originally Posted by jasmine2501 View Post
The actual numbers that the radio is sending are integers in the range 0-1024 or 0-2048 for high end radios. Those numbers are mapped internally to percentages around center and the percentages go from -125 to +125. When you set the throttle to zero, it's really -100 and you could go 25 points lower than that.
Most aircraft speed controllers calibrate the zero point on startup, but it needs to be low enough, and some speed controllers just don't think zero is low enough.
And Yup.
Which is why Im pretty certain that Ty's problem with binding (and mine was) is because his trim is centered. I just put another 5 packs through this MQX. No more problems since I spotted my mistake.
desertdweller is offline Find More Posts by desertdweller
Old Oct 23, 2012, 07:30 PM
ty_horn is offline
Find More Posts by ty_horn
Philippians 4:13
Seward, NE
Joined Nov 2006
I suppose it is like when I set up a glow plane for my Dad, I set the throttle stick all the way down and trim in the center (which I would consider zero) then I would adjust the engine so that it was running. This way when I was flying the plane I could cut it to zero throttle on the stick but the plane would keep running enough so the engine wouldn't cut out. Then when I came in for a landing, I would actually have to pull the trim down all the way to cut the throttle fully enough for the engine to cut out. I get it.
ty_horn is offline Find More Posts by ty_horn
Old Oct 23, 2012, 07:32 PM
ty_horn is offline
Philippians 4:13
Seward, NE
Joined Nov 2006
battery question:
Is there a favorite (cheap but quality) battery that you all like for your MQX? I need to order one or two. Thanks
Old Oct 23, 2012, 07:58 PM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
I think the nano tech fits that description. Dirt cheap. Order several so if u get a couple failures it won't matter.
Originally Posted by ty_horn View Post
battery question:
shahram72 is offline Find More Posts by shahram72
Old Oct 23, 2012, 08:07 PM
USA, AZ, Mesa
Joined Aug 2009
Yup. Let us know when you get around to trying it out.
battery question:
Ya cant beat these Hyperion's!
http://www.allerc.com/hyperion-g3-cx...li-p-6265.html
Old Oct 23, 2012, 08:54 PM
ty_horn is offline
Philippians 4:13
Seward, NE
Joined Nov 2006
Thanks guys.
Here is another question foryou... I have 2 cellpro 4S chargers. Neither of them can charge 1 cell lipos. Well, I don't have an adapter that will allow it I guess. As far as I know, you can only charge lipos that have a balance plug with my cellpro chargers. Has anybody come across an adapter that will allow me to charge 1 cell? Thanks
Old Oct 23, 2012, 09:13 PM
zguy is online now
Find More Posts by zguy
Team SCHC
zguy's Avatar
SoCal
Joined Dec 2005
Thanks guys.
I charge 1S on my Cellpro 4S all the time. Just tap into the first and last wires and go to any single plug or parallel board.
zguy is online now Find More Posts by zguy
Old Oct 23, 2012, 09:15 PM
ty_horn is offline
Philippians 4:13
Seward, NE
Joined Nov 2006
oh sweet! Can you please show me a picture?
nevermind, found a solutuion :-)
Old Oct 23, 2012, 09:29 PM
ty_horn is offline
Philippians 4:13
Seward, NE
Joined Nov 2006
well, well, well... Look what I found in my pile of stuff that I didn't throw away but probably thought about it at one point. :-) This charge lead is for 2 cell lipos and it is for use with a non-balancing ParkZone charger. So, it will work perfect with the cellpro charger when plugged into a 2 cell port!
Sweet, no tapping required.
http://www.parkzone.com/Products/Def...ProdID=PKZ1053
Hey desertdweller,
do you know for sure that those hyperions fit?
Old Oct 24, 2012, 11:08 AM
USA, AZ, Mesa
Joined Aug 2009
Hey desertdweller,
Yup!
The only thing that you have to do is add a little tape to the Hyperions because they tend to be just a tad bit loose in the MQX battery holder. But it makes a convienient place to write the number/letter of the battery. I also cover all my batteries with a piece of clear packing tape because it irritates me when the labels keep getting pealed off by removing them from the aircraft. (thats the clear stuff you see sticking out the bottom of the batteries)
Edit: Also of note, you will notice a nice little improvement in performance from those Hyperions over the stock Eflite battery.
Last edited by desertdweller; Oct 24, 2012 at 11:12 AM. Reason: added a lil sumthin
Old Oct 24, 2012, 01:01 PM
ty_horn is offline
Philippians 4:13
Seward, NE
Joined Nov 2006
Cool! Thanks. I figured there would be some performance advantage if I went with those lipos. I am glad they are a little too small rather than a little too big.
Old Oct 24, 2012, 01:29 PM
ColSonders is offline
Find More Posts by ColSonders
United Kingdom, England, Consett
Joined Feb 2012
Can someone point me in the right direction with a little trouble shooting please.
When I put full right rudder on very rapidly my bird tips instead of simply spinning.
The same doesn't apply to whacking full left rudder on.
I'm fairly certain it's not a radio issue, though will check when I get a chance, so I basically know it's either one of the anti-clockwise motors/props or the clockwise motors/props.
At a glance the props look fine, tried holding the MQX and powering up and the blades all look to be in reasonable condition.
So if it's a problem when spinning right can anyone tell me if it's the clockwise or anti-clockwise bits that I need to start trouble shooting?
ColSonders is offline Find More Posts by ColSonders
Old Oct 24, 2012, 01:33 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Switch the motors and see if the problem migrates to left rudder.
Gerry__ is offline Find More Posts by Gerry__
Old Oct 24, 2012, 02:10 PM
jlcamp7 is offline
Find More Posts by jlcamp7
RC Logger Support
jlcamp7's Avatar
United States, WV, Hurricane
Joined Jan 2010
Hold it again and spool it up. Then begin rotating the quad in your hand at different angles. You'll feel the pull of the different motors as it speeds up and slows down to accommodate the direction. See what the motor does on that corner. If it doesn't pick back up in speed could be bad motor. However then to be sure do as Gerry suggested. If it runs fine on the other channel you probably have a bad channel on your board.
jlcamp7 is offline Find More Posts by jlcamp7
Old Oct 24, 2012, 03:18 PM
Joined Feb 2012
If I understand the physics correctly that shouldn't happen
It should however make the tip occur in a different direction, eliminating the board and the other pair of motors as the problem.
Will start with that thanks.
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
