Old Oct 08, 2012, 05:33 PM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
Originally Posted by shahram72 View Post
Thanks, will check that. Need to add DeOxit to my shopping list. Where can it be found?
The MQX motors are too expensive, I am going to order 2 A and 2 B motors for the 929 since they are supposed to be identical. I know they plug in under the covers and they probably won't match so I'll need to mod the MQX to take these new motors. What have you guys done?
Easiest way is to get a v929 BNF ($32 : http://www.banggood.com/Wholesale-Wl...o-p-46046.html ) and change the main board (and canopy as the mQX one looks better). So you only have to change the plugs on the main board which isn't a big deal.
mystman is offline Find More Posts by mystman
Old Oct 08, 2012, 05:50 PM
jlcamp7 is offline
Find More Posts by jlcamp7
RC Logger Support
jlcamp7's Avatar
United States, WV, Hurricane
Joined Jan 2010
You can find deoxit at most radio shacks and also at some larger music stores like Sam ash and guitar center.
jlcamp7 is offline Find More Posts by jlcamp7
Old Oct 09, 2012, 10:00 AM
N8LBV is offline
Find More Posts by N8LBV
United States, MI, Ann Arbor Charter Township
Joined Mar 2012
I'm having difficulty finding any replacement pinion gears.
Closest I've found aer wholesale lots of 3000 plastic gears with too large of a a bore (2mm).
I think the bore on these is <1mm .75mm to be exact.
Plastic/nylon with a tight fit would be ideal.
Rather than trying to get another brass part onto the used motors.
I have no idea how I'd get a new brass part on it without breaking the motor.
N8LBV is offline Find More Posts by N8LBV
Old Oct 09, 2012, 09:26 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Originally Posted by N8LBV View Post
And I completely 'ran out' of brass pinion this evening :-(
That blows.
The other 3 are soon to follow.
I'm not sure if there's a way to just change that gear.
I have seen reports of v929 motors' pinions wearing out in similar fashion.
Perhaps its from the same source or the nature of this pinion.
flying-llama is offline Find More Posts by flying-llama
Old Oct 10, 2012, 08:13 PM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
What is the range on these?? I swear I went about 200ft straight up....no lose of signal...flew around and then came down very slowly. Awesome!
Jake8131 is offline Find More Posts by Jake8131
Old Oct 10, 2012, 09:36 PM
jlcamp7 is offline
RC Logger Support
jlcamp7's Avatar
Joined Jan 2010
Are you using the rtf transmitter? If so 300 ft is about max range if using something like dx6i then the range is way way further than you'd ever want to fly it.
Old Oct 10, 2012, 09:59 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
I have a DX6i.
Old Oct 10, 2012, 10:48 PM
jlcamp7 is offline
RC Logger Support
jlcamp7's Avatar
Joined Jan 2010
At least 1000 ft. Range which would be just a speck at that distance.
Old Oct 11, 2012, 10:15 AM
N8LBV is offline
Joined Mar 2012
I think RTF TX has same range as a DX6i or similar range.
I'll check TX power next time I have access to an RTF TX.
It's probably going to be 50-100mW which will give you about the same range as the DX6i's 200mW on USA power setting.
Old Oct 11, 2012, 12:15 PM
jlcamp7 is offline
RC Logger Support
jlcamp7's Avatar
Joined Jan 2010
No that's not correct. Not trying to cause any arguments but it has been confirmed on many of HH's products that use the rtf controller that the max range is 300 feet. I know it's a correct fact as many of us using it while flying their micro plane line have had it drop out on us right at that range level. You can't even compare the rtf transmitter range with the dx6i range. It's not remotely even in the same category. I had my champ drop out many times at around a 300 feet or less range while using the rtf tx, but flew it many, many times so far and high in the sky that it was a spec and took a while to try and even get it back to a place where I could even figure out what direction it was going. It was easily way over 1000 feet and never had it drop out once.
Old Oct 11, 2012, 12:25 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
You are correct.
Gerry__ is offline Find More Posts by Gerry__
Old Oct 11, 2012, 12:38 PM
N8LBV is offline
Joined Mar 2012
Nope no arguments :-)
I don't have/own any RTF TX devices.
Just purely out of curiosity I'll test the RF output power next time somebody brings one over :-)
Father in law has an RTF mQX I'll test this when I have a chance, and also do a side by side range comparison with my DX6i (sounds like this has been done before).
You never know what you'll shake out, different hardware version different range etc.
The DSM2 chips themselves put out ~4mW of power without an amplifier.
The DX6i most certainly uses an amplifier to get this up to 200mW.
The RTF TXs might just pull it right off the chip @4mW :-)
Old Oct 11, 2012, 02:04 PM
jlcamp7 is offline
RC Logger Support
jlcamp7's Avatar
Joined Jan 2010
Would definitely like to hear your readings as it would be interesting to know. I just know what they say and what many of us have experienced, but even with that it would be cool to actually see the numbers and know the science behind it.
Old Oct 11, 2012, 08:10 PM
N8LBV is offline
Joined Mar 2012
I'm hoping they have a little more power than the bare 4mW..
I noticed people are tearing the RF modules out of RTF transmitters and putting them into Turnigy 9Xs to get DSM2 functionality out of the T9X.
based on all that effort I was expecting some higher level of performance.
Will let you know when I test.
Old Oct 12, 2012, 12:59 PM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
Let me clarify a little with what I know.
The developer got the mW mapped for the various module during the early development of the DSM2 mod. Including the startup 1's and 0's that set the bit for the power output to conform to each countries regulation if I recall correctly. So those smart fellers really covered a lot of the bases.
Putting a RTF module into a Turnigy radio will not magically make the range more. Without antenna mods, etc. What you gain is 2 additional channels and the programmability of it. In the end, it's still a parkflyer module. Remember, the RTF is MLP4DSM. Stands for Micro Low Power 4 channel DSM technology. It's considered a low power module and is great for the micro helis, micro quads that many of us fly.
Now, if you take the High Power modules from a HP6DSM, DX4e, DX5e...or even a DX6i...then you are going to have about the same range as those radios are rated for. HP6DSM stands for High Power 6ch DSM.
The module inside the HP6DSM is similar to the DX4e, DX5e and DX6i. With the newer revised version in those last three radio having DSMX capability. Which you also retain once inserted into the Turnigy 9x.
Putting a HP6DSM, DX4e or DX5e into the Turnigy makes sense because you gain the programmability and flexibility of the open source firmware. Plus many mCPX and nCPX owner already has the DX4e to hack up.
Daryoon is offline Find More Posts by Daryoon
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
