Old Oct 03, 2012, 10:26 PM
DaveChamplin is offline
Find More Posts by DaveChamplin
United States, CT, Preston
Joined Dec 2011
Originally Posted by Dax View Post
Hey guys,
Picked up an MQX on the weekend. Great little flier.
Wondering if there are any "must do" mods that I should be doing before I break anything?
So far I've noticed that the motors will pop out of the retaining clip after a hard crash. Not sure if I want to fix that as it could prevent breakage. However one of them popped out so far it ripped out a motor wire and I had to do some tricky soldering to fix it.
Also, I managed to mess up one of the white plastic gears in a crash and it doesn't mesh smoothly with the spur gear on the motor. It still flies, but it takes a second to spool up that one prop so I'm going to get a replacement. Not sure there is any real way to avoid that from occurring other than not crashing.
Finally, does anyone have a cheap source for the little JST to micro adapter wire that comes with this? I have a 4 port charger that came with my MSR that I would like to use to charge 4 of the MQX batteries at the same time but I need 3 more adapters. Can't seem to find them on HobbyKing but I'm sure they are out there somewhere.
Going to order some of these props and these batteries today.
http://www.quantumhobby.com/Blade-JS...-p/blh3126.htm
DaveChamplin is offline Find More Posts by DaveChamplin
Old Oct 04, 2012, 01:35 PM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
Found this online...doesn't look too bad...and was easy for me to make.
Jake8131 is offline Find More Posts by Jake8131
Old Oct 04, 2012, 02:13 PM
Darsh is offline
Find More Posts by Darsh
Tinkerer of makeshift failures
Darsh's Avatar
Joined Jun 2012
Battlestar Galactica... i see what you did there...
Darsh is offline Find More Posts by Darsh
Old Oct 05, 2012, 09:07 AM
RoboHeli is offline
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
This can be found on RCGroups user Pancari's blog:
http://www.rcgroups.com/forums/showthread.php?t=1718465
I've printed out and made the red one. They're pretty simple and good "first time" canopies to make if you've never done this sort of thing before.
RoboHeli is offline Find More Posts by RoboHeli
Old Oct 05, 2012, 09:34 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
The red one looks pretty cool. Didn't have any photo paper, so just make it from regular copy paper...came out ok.
Old Oct 06, 2012, 01:59 PM
leereyn is offline
Find More Posts by leereyn
1981 Z28 "The Wife"
leereyn's Avatar
Bainbridge, GA
Joined Feb 2002
MQX with custom canopy
This is a canopy I made with packaging that my waterproof Battery Tender came in. This was a fun project and I wish I had 10 more of these I could customize.
leereyn is offline Find More Posts by leereyn
Old Oct 06, 2012, 02:45 PM
N8LBV is offline
Find More Posts by N8LBV
United States, MI, Ann Arbor Charter Township
Joined Mar 2012
WLToys V929 parts on MQX?
I'd expect it's already covered here *somwhere*.
But I'm having difficulty finding it with searching.
Does anyone know if it's documented here if the WLToys V929 parts:
motors, landing pods, carbon shafts blades etc. are directly interchangeable with the mQX?
Especially the motors..
I need a new set and don't really want to spend $15ish each on 4 of them if I don't have to.
Thanks!!
N8LBV is offline Find More Posts by N8LBV
Old Oct 06, 2012, 02:48 PM
N8LBV is offline
Joined Mar 2012
Awesome looking canopy! Nice!
Any relation to an SR22? ;-)
Old Oct 06, 2012, 02:50 PM
N8LBV is offline
Joined Mar 2012
I think I'm going to go have some fun with glow paint and u/v LEDs.
At the moment stock canopy with some bright blue & white LEDs.
MQX-NightFlight (3 min 8 sec)
Old Oct 06, 2012, 03:00 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Getting better at flying indoors..longer flight with no crashes.
BladeMQX BC (2 min 1 sec)
Old Oct 06, 2012, 04:02 PM
N8LBV is offline
Joined Mar 2012
Forgot one credit: Flown by Jake ;-)
Old Oct 06, 2012, 08:18 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Being modest.
Old Oct 07, 2012, 02:08 AM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Thanks!!
Ive got both and the motors, gears, props seem identical.. the motor holder has a slightly different molding, but the parts and positioning looks identical..arms are the same, size and spacing.. it only looks like the hub molding and control board is where they significantly vary..
I bought the 929 to do my learning on, bash that one before bashing up the MQX.. however the 929 is very good out of the box, even with it being a cheepo, it flys and bounces very well...lol...
.. The MQX I bought because it links to my spectrum gear..it is also, very good as we all know.
ebay has the v929 motors at half the mqx price
davereap is offline Find More Posts by davereap
Old Oct 07, 2012, 11:51 AM
N8LBV is offline
Joined Mar 2012
Thank! & good to know.
They are $15 each from the LHS ($60+tax+gas) to drive out & get a set.
I'm sure you can get them a bit cheaper online..
I think I'll try one round of V929 motors and see how it goes.
I do indeed love the mQX and have put some miles on mine since getting it about 2 months ago.
Since I've had to replace one motor (Front CW black/whit wire) didn't last long.
I'm not sure if that is a defect or was due to my very hard flying and crashing.
I do work this thing to it's limits and fly it a lot.
All 4 motors are almost 'out' of brass pinion.. the teeth are worn almost all the way through.
It seems as though the nylon is outliving the brass (more surface area).
I am care ful to keep the gears clean and bearings cleaned/oiled.
Sometimes there is no avoiding getting dirt/dust into the items, but I keep them cleaned out flushed and re-oiled very often.
*my* other high fail item is the carbon fiber arms/booms whatever they're called..
In my crashing they split easily and become weak and very easy to twist lengthwise.
This causes unwanted twisting/fluttering in flight and oscillations with the motors and AS3X responding to the low frequency vibrations.
A complete set of new booms is around $20 from the LHS when/IF they have them in stock.
I'll make my own from now on.
I'm good/fast with solder heat gun & tiny shrink tubing :-)
The carbon square hollow rods (arms) material is hard to find.. (V929 arms might be compatible at ~$1.5 each) looks like they don't come prewired. Are they just as strong?
I ordered 4 feet of this: http://www.dragonplate.com/ecart/pro...D=3659&cID=103
For around $7
Old Oct 07, 2012, 12:00 PM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
You are right, they aren't pre-wired, but they are very strong. Stronger than the v929 stock arms
I'm using magnetwire for wiring.
mystman is offline Find More Posts by mystman
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
