Old Sep 26, 2012, 12:22 AM
jlcamp7 is online now
Find More Posts by jlcamp7
RC Logger Support
jlcamp7's Avatar
United States, WV, Hurricane
Joined Jan 2010
The only way to do that would to be buy just the spare parts and build your own using the board/with built in receiver if choice. But then you'd have to figure out how to mount the board/rx. It's an all in one unit. What transmitter are you wanting to link to?
jlcamp7 is online now Find More Posts by jlcamp7
Old Sep 26, 2012, 01:31 PM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
Originally Posted by swervo View Post
apologies if this has been covered already but 400 + pages .... can the mqx be purchased without receiver so the purchaser can use existing (non spektrum ) radio ?
You can purchase a full finction MQX, order a receiver for a v929 and use the Turnigy 9x...otherwise, no...
Jake8131 is offline Find More Posts by Jake8131
Old Sep 26, 2012, 01:41 PM
RC Logger Support
jlcamp7's Avatar
Joined Jan 2010
Yep yep. That's why I wondered what type of tx he's wanting to use. If its a 9x then just order a v929 and call it a day.
Old Sep 26, 2012, 11:05 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
I have both the v929 and the mQX..beings I no longer have the hand/eye coordination I used to, I fly the v929 outside for the neighborhood kids to aww and ooow when I flip and roll the v929.
Old Sep 27, 2012, 08:58 PM
rcflyer40plus1 is offline
Find More Posts by rcflyer40plus1
I'd rather be flying!
rcflyer40plus1's Avatar
Joined Jul 2010
Hey guys, I got some 600mAh batts for my mqx. They are a bit longer than stock 500 and have a bit of slide. Sorry, sure its been asked before, but any tips on balancing/securing?
rcflyer40plus1 is offline Find More Posts by rcflyer40plus1
Old Sep 27, 2012, 10:05 PM
RC Logger Support
jlcamp7's Avatar
Joined Jan 2010
You can add a piece of heat shrink to add thickness or also a different stopping point. Also I know some have cut off the battery cage and used Velcro instead.
Old Sep 28, 2012, 12:18 AM
BigGuyJT is online now
Find More Posts by BigGuyJT
BigGuyJT's Avatar
Fresno, California
Joined Mar 2007
A couple of strips of scotch tape will do the trick to tighten them up.
BigGuyJT is online now Find More Posts by BigGuyJT
Old Sep 28, 2012, 11:02 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi Jake,
Which one performs better for you? What Tx's are you using for each one?
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Sep 28, 2012, 01:39 PM
Joined Jul 2010
Thanks for the tips on securing batts - went with small bands of surgical tubing. Makes a good stop and the rubber holds tight against the underside of body.
Old Sep 29, 2012, 08:44 AM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Originally Posted by jesolins View Post
Hi Jake,
Cheers,
Jim
I am using the stock tx for the v929 and a DX6i for the mQX...I find the MQX a lot easier to controll..I feel the v929 is very quick,
Old Oct 01, 2012, 01:32 AM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Originally Posted by pgoelz View Post
The mQX can fly in any wind that an airplane can handle. Often more. Basically, it can handle wind velocities up to the maximum forward speed it is capable of. As long as you avoid getting close to full throttle, the stabilization system works great. Remember, though, that the stabilization system only holds attitude, not altitude or position. Those will change with the wind velocity.
I flew mine last weekend in winds of 12 gusting to 20+ (some reports had gusts to 30 that day). As an indication, the several flips I tried that day ended up 20 feet behind the flight line due to wind. Most airplanes (including my Super Cub 25e) were grounded by the higher gusts but my mQX handled them just fine, with a little pilot input. Note in the photo how my hair is being blown
I do have to say that there were a couple gusts that exceeded its forward speed capability. At that point, I had to tilt it so far forward that there wasn't enough lift to keep it up. But it was remarkable how well it handled the wind.
Paul
I had mine out this afternoon in 8mph winds and it handled great....my 120sr went backwards....I was flying the MQX all over the yard......awesome little machine...even took out the v929 and had a blast....a little more twitchy in the wind than the MQX, but just as much fun!
Old Oct 01, 2012, 08:02 AM
RC Logger Support
jlcamp7's Avatar
Joined Jan 2010
Good stuff Jake. Mine is down right now. Have a bad mesh on one of the gears so ordered a few ones and waiting on them to come in. I tried flying it on Saturday, but it just kept doing weird things because of the bad mesh, so I landed it and am now just trying to be patient.
Old Oct 01, 2012, 05:55 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Are you talking about the white gear that meshes with the motor? If so, it is the same gear used on an MSR/MSRX...got an old MSR/MSRX laying around?
Old Oct 01, 2012, 11:20 PM
RC Logger Support
jlcamp7's Avatar
Joined Jan 2010
Thanks. Didn't realize that. Unfortunately when I sold my msr I sent every extra part with it. . However now that I know that I can pick it up at the local hobby shop. For some reason they don't carry any of the mqx parts but always have msr/msrx parts on hand.
Old Oct 02, 2012, 12:07 AM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
I have 3 LHS and none of them carry any spare parts for the MQX...I really need a new canopy.
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
