Old Sep 16, 2012, 09:27 PM
N8LBV is offline
Find More Posts by N8LBV
United States, MI, Ann Arbor Charter Township
Joined Mar 2012
Cool thought! I take my mqx up to 200 feet or so regularly when it's not windy :-)
N8LBV is offline Find More Posts by N8LBV
Old Sep 17, 2012, 06:01 AM
Quandry is offline
Find More Posts by Quandry
Ireland, Co. Dublin, Dublin
Joined Feb 2012
Just got an mQx on the weekend and it's a fun little machine. I have heli experience so very easy to pickup from there, it's only slightly different.
One observation, when I bound it to my DX8 it came up with the telemetry icon on the LCD. Excitedly I scrolled through the telemetry screens to see if there was any read out but it only showed null values.
It's amazing how much technology they packed in to the mQx pcb but if they added telemetry also it would be super cool!
Anyone else seeing the same?
Quandry is offline Find More Posts by Quandry
Old Sep 17, 2012, 07:26 AM
philipa_240sx is offline
Find More Posts by philipa_240sx
philipa_240sx's Avatar
Canada, ON, Ayr
Joined Apr 2010
mQX gearbox protection
New mQX owner chiming in here.
Has anyone given thought to some sort of gearbox protection for winter flying outdoors? The mQX would be a great winter flying machine but I have concerns about ice & snow jamming the pinion gears.
I'm seriously considering making clear plastic (PET) covers that would slip on over the gearbox/landing feet. Perhaps make them a bit taller to increase the ground clearance a bit. It wouldn't take much, a simple mold and a few minutes on the vac former.
Comments?
philipa_240sx is offline Find More Posts by philipa_240sx
Old Sep 17, 2012, 07:32 AM
baddb1 is offline
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
Comments?
Excellent idea! Mine even jams up now with blades of grass! Please take pics of your covers and post them!
baddb1 is offline Find More Posts by baddb1
Old Sep 17, 2012, 07:34 AM
jlcamp7 is offline
Find More Posts by jlcamp7
RC Logger Support
jlcamp7's Avatar
United States, WV, Hurricane
Joined Jan 2010
As I was reading your post before I even got to the clear covers part that was immediately what was coming to my mind as well. Probably your best way to protect. The problem is how deep of snow are we dealing with and how packed is it? If it goes above the covers and just falls down in that won't help much either. Now if your just talking a few inches, then I think it might work. Also as long as your not crashing it then the Mia landing gear might work to give clearance. However I think the lg has effect on aerobatics.
jlcamp7 is offline Find More Posts by jlcamp7
Old Sep 17, 2012, 10:50 AM
Canada, ON, Ayr
Joined Apr 2010
Yes, I was thinking about that. Encasing the gearbox could actually make it worse as trapped snow has no place to go.
Adding side area to the motor pods could affect aerobatics. That's definitely a concern.
I'll think about this some more...
Old Sep 17, 2012, 10:57 AM
ColSonders is offline
Find More Posts by ColSonders
United Kingdom, England, Consett
Joined Feb 2012
I'd you're looking at a landing gear mod you may want to consider the zip tie mod. This will give extra clearance for very little added weight and gives your landings a touch of bounce.
Personally I'd rather just keep it in the air though
Not landing is a real option though, take off and 'land' using your hand instead of the ground.
ColSonders is offline Find More Posts by ColSonders
Old Sep 17, 2012, 11:43 AM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
DX6i Settings
Anyone care to share their DX6i settngs, please?
Jake8131 is offline Find More Posts by Jake8131
Old Sep 17, 2012, 11:45 AM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Set it on ACRO... done. Did you check the manual? Everything beyond turning the radio on is personal preference, you can set expo or dual rates or both or whatever you want to do, but the basic settings are... nothing.
jasmine2501 is offline Find More Posts by jasmine2501
Old Sep 17, 2012, 11:48 AM
jlcamp7 is offline
RC Logger Support
jlcamp7's Avatar
Joined Jan 2010
I along with many just have it set up in acro mode and just use standard dual rates on it. However I'm sure someone will chime in with heli settings if your interested. I don't have any knowledge on that.
Old Sep 17, 2012, 11:49 AM
jlcamp7 is offline
RC Logger Support
jlcamp7's Avatar
Joined Jan 2010
I give up in this thread! I swear every time I post someone beats me to it while I'm typing. Thanks a lot Jasmine!
Old Sep 17, 2012, 11:52 AM
baddb1 is offline
baddb1's Avatar
Joined Jan 2009
I set my dual rates on my DX7 at 70% and have about 25% expo. Of course when doing flips I set the d/r switch to 100%. These settings seem to work good for a quad beginner like myself. But as mentioned above, its a personal perference.
Old Sep 17, 2012, 12:23 PM
Canada, ON, Ayr
Joined Apr 2010
These are the settings I use on my DX8, they will work fine for the DX6i. The low rates are good for learning. I switch between both using the ELEV rate switch
Low Rate:
DX6i: D/R & Expo = 0
DX8: SW = ELEV, Position 0
Elevator: DR = 45% / Expo = +40%
Aileron: DR = 45% / Expo = +40%
Rudder: DR = 90% / Expo = +60%
High Rate:
DX6i: D/R & Expo = 1
DX8: SW = ELEV, Position 1
Elevator: DR = 100% / Expo = +60%
Aileron: DR = 100% / Expo = +60%
Rudder: DR = 100% / Expo = +60%
DX6i: Set D/R Combi to ELEV for easy low/high rate switching.
Old Sep 17, 2012, 01:21 PM
jlcamp7 is offline
RC Logger Support
jlcamp7's Avatar
Joined Jan 2010
Why in the world do they not sell the blades in packets of 1 cw and 1ccw? It doesn't make sense. When you buy it, it comes with one whole set to replace each blade, but in order to replace each blade after that you have to purchase four packs of blades. 1 set black cw, 1set black ccw, 1 set white cw and 1 set white ccw. I know when you do you also end up with another extra of each, but I just don't understand why they aren't selling them in the correct sets for x setup which is how it comes and what I believe probably 95% are running it in. weird.
Old Sep 17, 2012, 01:53 PM
pdwire is offline
Find More Posts by pdwire
Joined Jan 2011
+1- noticed the same thing when trying to pick up pair of orange blades.. now I have four orange blades.. only wanted two.. one CW and one CCW.
pdwire is offline Find More Posts by pdwire
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
