Old Aug 18, 2012, 07:49 PM
pgoelz is offline
Find More Posts by pgoelz
pgoelz's Avatar
United States, MI, Rochester Hills
Joined Oct 2000
Originally Posted by Endlesslag View Post
I think I'm going to limit my throttle endpoint to 85%...above that it gets too squirrely, and I have a habit of maxing the throttle out in a trouble situation, and of course that causes a crash if I'm down low, and a mad scramble to get back under control if I'm up high.
Today I suddenly had pretty much exactly your issue.... massive instability on full throttle punches and less than usual stability on rapid descents.
First of all, the issue is definitely NOT the control board. The issue is that the four props do not produce identical thrust for identical power input. Assuming that all four motor channels reach 100% throttle when you command full throttle, in still air the mQX should climb straight up from a standing start on the ground OR a full throttle stab from level flight. Mine used to but today it did not. It had a PRONOUNCED forward tilt at or near full throttle.
So I started to attempt to separate out the possible causes (wiring, motor, prop, excess friction).
What I found was:
1. Swapping motors front to rear had next to no effect. So it did not appear to be a motor issue per se.
2. Replacing the motor on the weakest corner (the one the mQX tilted towards at full throttle) with a new one had next to no effect. So it still did not look like a motor issue.
3. The gear mesh on the right front (the corner that seemed the weakest) was tight enough to bind. There was gunk in the gears which I cleaned. But the mesh was still tight. I tried rotating the motor in the housing, and this helped a bit. I left it in the loosest orientation (which seems pretty much OK), but this needs further diagnosis.
4. The right front motor frame was VERY loose on the boom. The problem was the boom, which had just been replaced... the old one was nice and tight. Cracked, but tight. This allowed the motor assembly to vibrate at full throttle. Fixed with a drop of hardened CA on the boom, but didn't fix the unbalanced thrust.
5. So assuming the motors were delivering the same power to all four shafts, that left it up to props. I don't have an optical tach to check the props in the air, but by hovering at eye level, I could sight across the front/rear pair of props and see by the interference pattern whether they were turning at the same RPM. They were NOT. Since all four props were developing the same thrust (the heli was hovering level), the fact that the front and rear props on each side were not at the same speed indicated that they were not the same pitch. The props can get bent, and due to their shape, when they get bent, this changes the pitch. Since the rear props were developing more thrust than the front props (remember, the mQX tilted forward on full throttle climbs), I gently bent each rear prop to de-pitch it. After several iterations, I got to a point where the mQX climbed nearly vertically AND the props were turning at the same RPM in a level hover.
Once this was done, outdoor flight verified that the mQX was once again stable.
So the bottom line is that all four props must generate the same thrust at full throttle or the mQX will be unstable. This applies to partial throttle operation as well, since the gyro makes corrections based on the assumption that all four props will generate the same thrust at the same power setting. If they do not, it unbalances the system and it is less stable after a perturbation from turbulence or maneuvers. And there are several issues that can cause unequal thrust.
Long winded, I know.... sorry. But necessary if the mQX is suddenly unstable.
Good luck!
Paul
pgoelz is offline Find More Posts by pgoelz
Old Aug 18, 2012, 08:09 PM
fred_dot_u is offline
Find More Posts by fred_dot_u
Joined Apr 2008
That's an impressive analysis and very thoroughly performed. It makes quite a bit of sense, as the motors may be more closely matched even after a few dozen flights, but any contact of a prop to a surface can easily change the pitch. It's also the least difficult item to "calibrate" in my opinion. Interesting idea to use an optical tach to balance rpm at full throttle, or perhaps even lower throttle settings if the pitch controls are kept neutral.
fred_dot_u is offline Find More Posts by fred_dot_u
Old Aug 18, 2012, 08:24 PM
pgoelz is offline
pgoelz's Avatar
Joined Oct 2000
Yeah, the real issue is that most of us (including me) do not have the equipment to actually measure the various variables. So we are left to poking at it until something gets better
I also fly helis, and an optical tach might be in my future. Or maybe something that I can run in my Android phone? I have a guitar tuner for it that also reads out in Hz.... in this case, Hz/2 would be the RPM if I hold the phone near the prop in question in level hover.... assuming it can hear pitches that low.
Paul
Old Aug 18, 2012, 08:51 PM
Joined Apr 2008
The variety of optical tachometers on the market is mind-boggling. I have a PowerLog 6s that has a tach built-in, but it's forty two bucks and change. I think it reads ambient light and counts blocking of the blade, which is convenient, but pricey. I found one on Amazon:
that requires a reflective mark (included in the package) which might be applied to the hub for reading purposes and it's astonishingly low priced. Low enough that I might consider to pick one up to make my Q fly more smoothly.
$11.01 plus shipping is pretty darn inexpensive and the range is 2.5 rpm to 100,000 (99,999) with an accuracy of 1 rpm over the 9,999 mark and 0.1 rpm below that level. If we can tune our Q blades to that level of precision, I'll be further astonished.
Old Aug 18, 2012, 09:09 PM
pgoelz is offline
pgoelz's Avatar
Joined Oct 2000
Actually, I just remembered that I have an optical tach for propellers. If I can hover over it outdoors and shoot through it, I can get a good readout. Might take one more hand than I have, though
Fine tuning the props is easy. KEEPING them fine tuned might be harder, since they are pretty soft. But it really does help with stability.
Paul
Old Aug 18, 2012, 10:58 PM
Jake8131 is online now
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
Motors Not Working
Had something interesting happen tonight. Was flying late this afternoon in front of my house......had the neighborhood kids watching...had a hard landing and two opposing blades refused to spin up...oh no....fudged 4n1? Motor shot already? Took canopy off and check everything...tried again, two motors dead. Took inside and really went over it...seems that the two motors got push up and were not meshing with the white gears....Pushed them back down and seems to be ok...put a little dab of elmers glue to hold them in place.....whew!
Jake8131 is online now Find More Posts by Jake8131
Old Aug 18, 2012, 11:34 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Flying my mQX today for a public demo... and it just suddenly nose dived into the dirt. Upon inspection I found that the upper bearing on one of the motors had come apart. So, I grabbed my ball link pliers and snapped it back together... a little Triflow and she was good to go. Flew two more flights with no issues until they turned on the lights on the field and I got blinded and dumped it. All in all a pretty good day though... I flew planes and helis for seven hours and the kids and everyone really loved it. The mQX seems pretty durable too. I never crashed it twice in one day before... but it still works fine
jasmine2501 is offline Find More Posts by jasmine2501
Old Aug 19, 2012, 05:20 AM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
You mean the upper motor mount bearing? Don't have too much slack between it and the prop. 1/3mm or so. Not too tight either or they can bind.
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Old Aug 19, 2012, 05:26 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
I think he's talking about the upper prop shaft bearing rather than the motor.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Eflte Gee Bee Racing
Old Aug 19, 2012, 10:46 AM
Joined Jun 2012
That's what I meant too. To hit it from all directions: The bearing at the top of the prop shaft in the top of the motor mount on the end of the leg.
I can't quite see how it can come apart and if it did, you'd have teeny, tiny little ball bearings to find and put back in it.
Old Aug 19, 2012, 12:01 PM
Rocket Programmer
Joined Jul 2007
Yes that. It came partly apart, none of the balls fell out. It was easy to snap it back together with ball link pliers. Not sure if the crash caused it or the other way around.
Old Aug 19, 2012, 07:05 PM
boxhead530 is offline
Find More Posts by boxhead530
AMA 965811, FAA FA3MTYYYCK
United States, CA, Chico
Joined Nov 2010
Those bearings look like newer mCPx bearings, older one I had untill I broke cf main shaft had ball cage (he he) sealed bearings might not spin easy so these are easy to see/clean/lube. Too lazy to measure...for now
boxhead530 is offline Find More Posts by boxhead530
Old Aug 19, 2012, 09:24 PM
TomQ is offline
Find More Posts by TomQ
Joined Mar 2012
Your anecdotal experience isn't evidence of good practice. You've just been lucky.
Consider landing upside down in a tree, bush on rocks/uneven ground. This is different to landing on grass, or even concrete. Would you rather a rock/branch went through the board, or hit the canopy? If you landed upside down on water, the standard canopy may even float.
Note that a non-standard canopy, 'landing' feet first in a swimming pool does not help it float, as I found out.
I have crashed more than 1,000 times without a canopy, in a wide variety of ways. I am still flying without a canopy.
I would not suggest something this radical without testing it well first.
At what point do you think my experience might be statistically significant?
TomQ is offline Find More Posts by TomQ
Old Aug 19, 2012, 09:50 PM
Hotrodhawk is offline
Find More Posts by Hotrodhawk
Roters up... Skids DOWN!
Hotrodhawk's Avatar
United States, UT, Kaysville
Joined Aug 2012
My first post...
Ive been flying the MQX for two weeks now and love it. Need to pick up a DX6i soon and ditch the RTR. I've been reading a few pages back about the prop wash and the possibility of damaged booms or tweaked props that don't produce the proper thrust. This is good info for newbies... Thanks.
Now on to the recent talk about the bearing that came apart and it was just "snapped" back together. I had a upper bearing come apart and there was no popping it back together as there were only 3 tiny balls that were stuck to the motor. I replaced them with the recomended blade part number for this 3x6x2 bearing. I really don't like the fact there is only one steel dust shield on one of the two sides with the other side being exposed to the cage and balls.
There is a 3X6X2.5 blade bearing that has the metal dust shields on both sides of the bearing. So I was wondering if anyone has went and replaced all their bearings with this other piece?
I could weight each of the two bearing styles next Wednesday when a fresh shipment comes in, if that could help out.
Hotrodhawk is offline Find More Posts by Hotrodhawk
Old Aug 19, 2012, 10:45 PM
TomQ is offline
Joined Mar 2012
NM this was unnecessary
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
