Old Aug 15, 2012, 04:59 PM
flying toaster is offline
Find More Posts by flying toaster
aka beerassassin
flying toaster's Avatar
Joined Dec 2009
l've found that descending via loops/rolls/etc is a much more controlled and enjoyable method rather than just decreasing the throttle. I would actually be terrified to descend by just lowering the throttle from very high up.
flying toaster is offline Find More Posts by flying toaster
Old Aug 15, 2012, 05:07 PM
krede85 is offline
Find More Posts by krede85
Joined Jun 2012
Has anyone succesfully mixed the mQX and v929 yet? Either by fitting the mQX board on the v929 frame or fitting the v929 booms in the mQX frame?
krede85 is offline Find More Posts by krede85
Old Aug 15, 2012, 05:25 PM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
Originally Posted by krede85 View Post
Has anyone succesfully mixed the mQX and v929 yet? Either by fitting the mQX board on the v929 frame or fitting the v929 booms in the mQX board?
mQX board does fit on the v929 frame 1:1 but the plugs a different.
v929 uses Micro JST 1.25 plugs :
http://www.ebay.com/itm/180933354171...#ht_1967wt_954
http://www.hobbyking.com/hobbyking/s...5pcs_bag_.html
It shouldn't be hard If you can solder
I haven't checked yet how the v929 booms fit to the mQX Frame. But I don't see any Problems. Maybe you need some hot glue to fix them.
mystman is offline Find More Posts by mystman
Old Aug 16, 2012, 04:05 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Originally Posted by Brandigan View Post
True, but not quite all, it depends on the size of the props. My U816 (UFO canopied Walkera Ladybird clone) has such tiny props and they spin so fast, (it feels like it could almost fly in a vacuum ) and I can just shut the throttle right back and it will plummet out of the sky and I max the throttle 6ft off the ground for a cushioned landing.
Yeah, but the prop wash is still there and having an affect. Try a slow descent through your own prop wash you'll get similar results to the mQX.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Eflite Gee Bee Racing
Old Aug 16, 2012, 04:17 AM
ColSonders is offline
Find More Posts by ColSonders
United Kingdom, England, Consett
Joined Feb 2012
Sounds perfectly normal behaviour from a new, old or any MQX, as well as the v929 Beetle clone.
You're possibly doing things more quickly than you used to as your flying confidence has grown.
As lowering the throttle too quickly means the props are not giving as much lift, and with no wings to keep it up, it flies much like a brick will.
Try a different technique, something like this, or like this in smaller stages if you have a small area to fly in:
http://www.youtube.com/watch?v=H83-VkKRp1g
Thanks for that.
This is actually the method i've been using to get back down to earth.
Perhaps it's completely just my confidence levels rising, i'd been mostly just hovering around gently in the house when the weather has been bad and staying fairly low with a bit of forward flight. I'm now getting the hang of things and the speed and height i'm flying at are both increasing.
After a bit more play last night I think I may have stumbled upon an extra factor though, I think the cheaper batteries I have struggle when suddenly increasing throttle to a fairly high level and this is perhaps giving unbalance in the motors that the brain of the MQx is compensating for. Using decent batteries certainly reduces the effect.
note to self * don't buy any more cheap batteries.
ColSonders is offline Find More Posts by ColSonders
Old Aug 16, 2012, 04:56 AM
krede85 is offline
Joined Jun 2012
Thanks I might give it a try sometime soon then!
Old Aug 16, 2012, 06:01 AM
pgoelz is offline
Find More Posts by pgoelz
pgoelz's Avatar
United States, MI, Rochester Hills
Joined Oct 2000
Originally Posted by fred_dot_u View Post
I would also consider unbalanced performance from the motors, relative to each other. What appears to me from the description is similar to a full-throttle take off where one or more motors are providing unbalanced power, so the ascent is not even. Reducing power for a descent with one motor dropping power more than another could result in this tendency.
There are a couple other (related) possibilities....
You could have a damaged or bent prop that as a result does not produce the same thrust as the others. If this requires its motor to reach 100% throttle at any point in the descent, you may see stability issues.
You could have a boom that is either pulled out or pushed in. My mQX had an internally damaged frame and two of the booms could be pushed in too far... or more often, one would push in and that would push the opposite boom out. It flies much better after I replaced the frame and all the booms are symmetrical again.
Try a brief full throttle climb from a power off start on the ground. It should go straight up. If it doesn't, you have a weak motor, bent prop or pushed in/out boom.
Paul
pgoelz is offline Find More Posts by pgoelz
Old Aug 16, 2012, 07:14 AM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
No, I don't get that effect with my U816, although I do with my MQX and my v929 Beetle (same thing, basically). I already tried slow U816 decents because of my expectations and was unaffected by prop wash because there isn't any to speak of with such tiny props, so I did it faster and faster until eventually I found I could just about close the throttle, drop like a stone and catch it with a full throttle burst before it hit the ground. Not advisable as the battery gets nearer its limit as there is a bit less power in the last minute of flight for stuff like that. But then I just catch it with my hand.
And to whoever asked: Yes, just about all the spares except the board, and frame section are pretty much interchangeable between the MQX and the v929, although the plugs on the board/motors are different. Booms: same, props: same (colours different). Motor mounts: different design, same fit, Motors probably same, but cable colours swapped: Red/Blue= Black/White and vice versa
On the v929 forums we're all waiting for Rev03 which has flashing LEDs on the legs, which one person got very early (presumably by mistake) but without the new Transmitter with the extra channel button to toggle them on/off - which the beta tester has reported as coming soon - (they're on permanently, no biggie)
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Old Aug 16, 2012, 07:45 AM
baddb1 is online now
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
I just received mine the other day, put on about 15 flights already and love it!
I attached my key camera #16 on it and it lifts the added weight fine but was acting very squirrelly in the air. I attached it to the battery cage with velcro and I tried to center it as best as I can but maybe I wasn't in the right exact center? Any ideas or tips?
baddb1 is online now Find More Posts by baddb1
Old Aug 16, 2012, 08:01 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
There is definitely prop wash, as all props create it. There will be a proportional affect on the U816.
Old Aug 16, 2012, 08:17 AM
Joined Jun 2012
Ok, well as you clearly don't believe me telling you it is close to negligible on mine, why don't you buy yourself a U816 and tell us how proportional it is?
Old Aug 16, 2012, 08:23 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Just looking for a UK source.
Anyway, no prop wash? I don't think so, not if the laws of physics have anything to do with it.
Old Aug 16, 2012, 09:08 AM
Joined Jun 2012
The laws of physics as you understand them? Well, have a look at this short video and prepare to be amazed.
(Not really, it's just as I described before)
http://www.youtube.com/watch?v=zcfAarsmT8M
Old Aug 16, 2012, 09:13 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Ok, but can you video a slower descent? Dropping like a stone with the throttle cut isn't quite the same thing.
Old Aug 16, 2012, 09:35 AM
Joined Jun 2012
Oh, it'll drop faster than that with the throttle cut. That was relatively controlled, fast, descent. If you go back far enough and read what the problem was: the whole point is that anyone can descend slowly and not be affected by propwash, but it takes ages to get down, after you've applied buckets of throttle to get yourself 50ft up. It's descending quickly that is the problem.
The initial instinct is to close the throttle too much, which a) reduces lift to the point where the quad is flying exactly like a brick doesn't, and b) is now falling through mucky air which - because of the reduced lift/control of the slower moving props - has a greater effect in throwing it about.
With bigger props, you have to be moving forward to get out of the mucky air and either circle down, or apply lots of pitch or roll to dive towards the ground (props still at high speed, so actually doing some work) and then aim to miss it.
The video illustrates that smaller blades are not affected by fast speed of descent, which is why it didn't wobble and I applied throttle in the middle of the last descent and went back up again. Slow descent is even less affected, just like with every other quad.
The main problems I had were trying to keep the quad in frame and also it's a lot happier in larger areas. Outside it goes like a little rocket, much faster than either my MQX or v929.
Apology accepted BTW.
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
