Old Aug 08, 2012, 08:22 PM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
Originally Posted by ColSonders View Post
I just got one of these, managed to have a little play in the living room before I was dragged out to dinner by the wife.
I must say I've never had any interest in stuff other than helicopters but this thing made me smile from ear to ear just with a little bit of hovering.
I found it to be VERY twitchy on the cyclic, i'm just using a DX5e at the moment, does anyone know if using the channel 5 switch on that handset puts the MQX into low rate mode? or is there another way of doing it? I know I can use the low rate of my DX5e, but even with that on it seems incredibly twitchy, the thought of taking that outside as a complete newby makes me think "crash"
The channel 5 switch does absolutely nothing. The hi/low rate switch on the right does that.
Jake8131 is offline Find More Posts by Jake8131
Old Aug 09, 2012, 01:08 AM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Glow In The Dark MQX
Here is a better picture with a McDonalds large coca-cola cup cut at the bottom...definitely glows nice in the dark.
Old Aug 09, 2012, 01:29 AM
not103 is offline
Find More Posts by not103
not103's Avatar
Italy
Joined Mar 2009
Parrot ARDrone style indoor protection kit
Is there any kit to protect the propellers for indoor flight?
A kit like the one for parrot would be a great idea!
not103 is offline Find More Posts by not103
Old Aug 09, 2012, 02:48 AM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
For the lighting I've got some fairly bright LED's kicking about that don't require additional resistors for this sort of voltage,
All LEDs require a resistor. To not use one is like putting a piece of wire across the battery terminals. Expect the LED to get very hot and bright for about 0.5seconds.
http://led.linear1.org/category/led-basics/
Edit: Unless they are in series and you do the relevant forward voltage calculation. I prefer them in parallel with a resistor.
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Old Aug 09, 2012, 02:56 AM
Joined Jun 2012
People have made similar shapes out of lightweight foam or polystyrene ceiling tiles. Can't find the pictures just now. I'm sure someone else will.
You may find the extra weight might make it harder to fly, which might make it more likely you bump into walls, which would mean you'd need protection, which makes it heavier and harder to fly....
Edit: Here it is in the Beetle v929 thread: http://www.rcgroups.com/forums/showt...n#post22298127
And here on a Walkera Ladybird:http://www.rcgroups.com/forums/showp...postcount=1010
Old Aug 09, 2012, 10:20 AM
MOfroggy is offline
Find More Posts by MOfroggy
East Texas
Joined Nov 2008
I am having trouble with my MQx. When I give it full throttle it goes crazy. Wild gyrations back and forth and nearly zero control over what happens next. Is that caused by something I have set wrong on my DX6i or is there something wrong with the MQx?
Joe
MOfroggy is offline Find More Posts by MOfroggy
Old Aug 09, 2012, 12:07 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Joe
Have you done anything to it, changed the blades? Try rebinding it.
Old Aug 09, 2012, 12:50 PM
fred_dot_u is offline
Find More Posts by fred_dot_u
Joined Apr 2008
If there is an imbalance between motors with respect to power output, there will be the dancing and jigging described above. When I purchased my third one new, with zero crashes, it would go nearly straight up smoothly, but after a couple crashes, it has a bit more wobble to it. Eventually, I expect the performance difference to be more pronounced and will jig around as your does.
fred_dot_u is offline Find More Posts by fred_dot_u
Old Aug 09, 2012, 12:59 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Joe
No its because with all four motors at full speed, there is nothing left for control.
jasmine2501 is offline Find More Posts by jasmine2501
Old Aug 09, 2012, 01:03 PM
potshot is online now
Find More Posts by potshot
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
It's odd how different our experiences are. Mine is still quite new; I've run maybe 8 or 10 batteries through it. I've crashed it many, many times and am amazed how durable it has been. I often fly it over a concrete patio and I've crashed it there from 8-10 feet high several times, once even upside down. After the inverted crash I had to push the motors back into their mounts so the gears engaged again, but every time it flew nicely afterward.
After a crash I let it sit for a moment to give the electronics a chance to settle down. A friend told me about shutting the Tx off for a few seconds and then back on while the battery is still plugged in. He says that lets everything reset itself - I tried it and it doesn't lose the bind. You can even shut the Tx off in flight and the thing lands itself!
I'm sure I haven't reached the severity or number of crashes that others have, but I'm amazed that there has been no damage to this thing so far.
potshot is online now Find More Posts by potshot
Old Aug 09, 2012, 04:44 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Short flight in my living room.
MQX E (1 min 2 sec)
Old Aug 09, 2012, 08:03 PM
iamsuperbleeder is offline
Find More Posts by iamsuperbleeder
Licensed Lunatic
iamsuperbleeder's Avatar
United States, FL, Lake City
Joined Mar 2012
same story with mine. would climb vertical at full throttle relatively stable when it was new, but after 30 flights or so that's not the case. full throttle is pretty much useless, lol. doesn't really bother me too much until it's time to throttle up and recover out of a low loop or something; then things get hairy. it probably wouldn't hurt to change my props though; one's pretty beat up...
iamsuperbleeder is offline Find More Posts by iamsuperbleeder
Old Aug 09, 2012, 08:06 PM
Licensed Lunatic
Joined Mar 2012
http://www.youtube.com/watch?v=jQNaZQWDLcU
lol, your cat is like "whatever dude"
my cat isn't so calm when I pull my MQx out and my dog just wants to kill it, lol
the dog has never liked any of my RCs... I use to entertain myself for hours with him when I had my Traxxas mini
mini summit RC hating chihuahua (3 min 54 sec)
Old Aug 09, 2012, 10:07 PM
TomQ is offline
Find More Posts by TomQ
Joined Mar 2012
Originally Posted by kosem View Post
Very nice!
Sorry for the dumb question but what kind of paint do you use?
I prefer the ACE Hardware Fluorescent Orange over the Rust-Oleum Fluorescent.
I started experimenting with spray painting propellers many months ago, I probably painted 30 blades before they came out with their orange blades. And this is my second attempt at painting the body.
TomQ is offline Find More Posts by TomQ
Old Aug 09, 2012, 10:25 PM
TomQ is offline
Joined Mar 2012
Originally Posted by kodak_jack View Post
A McDonalds clear dome cup top will give good protection, minimal weight and minimal drag in motion. Don't fly naked!
Originally Posted by raw89 View Post
I agree w/ Kokak Jack except I prefer a Motts applesauce tub.:
Originally Posted by Thetis View Post
If you walk through Walmart or any any other similar store the plastic covers of cheap products are the best candidates. Flying naked is a risk taking for the expensive electronic board. Better be safe than sorry
Originally Posted by BlueHavoc View Post
Thats what I use, very light but protective....
I have flown more than 100 topless flights and I have had more than 400 unintended stoppages during those flights, many of them at dawn with very heavy dew. I replaced 6 or 7 control boards during my first 750 flights, almost none of those flown topless and yet I have not replaced a control board since going topless. I stand by my recommendation of flying topless. I only speak from experience.
What makes you advise otherwise?
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
