Old Jul 23, 2012, 06:56 PM
jgestner is offline
Find More Posts by jgestner
United States, WI, Merrill
Joined Jun 2011
Originally Posted by ChrisLevo View Post
Email sent yesterday.
The battery is also in the correct place, BTW.
It just refuses to do anything but immediate FFF, nose down
Chris
Have you tried to swap right front with back left motors? Or front left with back right?
Sounds a lot like a bad motor. If you were real lucky it might just be a bad connection. Remember you have 2 connectors for each motor, one at motorside and one at circuitboard side.
Gotta be a way to isolate the problem.
John
jgestner is offline Find More Posts by jgestner
Old Jul 23, 2012, 07:45 PM
ChrisLevo is offline
Find More Posts by ChrisLevo
Australia, SA, Adelaide
Joined Apr 2010
Thanks, John.
Connectors are all good, and will swap over the motors tonight.
What is really annoying is that it hovered for the first couple of flights, before losing its brain.
Does anyone know how quickly HH responds to service requests on their site?
Thanks again,
Chris
ChrisLevo is offline Find More Posts by ChrisLevo
Old Jul 23, 2012, 09:25 PM
TomQ is offline
Find More Posts by TomQ
Joined Mar 2012
Try swapping the whole corner units (boom, landing skid, motor, etc). If that changes things then try to identify which component, probably the motor, boom wiring or wiring connections, was the problem.
TomQ is offline Find More Posts by TomQ
Old Jul 24, 2012, 01:45 AM
vlad_vy is online now
Find More Posts by vlad_vy
Joined Dec 2011
Thanks, John.
Chris
I've thought so before I realise that motor wire at board connector fixed by heatshrink only, almost without solder. As result - faulty contact. I'm resolder wire and all working fine.
vlad_vy is online now Find More Posts by vlad_vy
Old Jul 24, 2012, 02:53 AM
flying toaster is offline
Find More Posts by flying toaster
aka beerassassin
flying toaster's Avatar
Joined Dec 2009
HH responded within a couple days when I sent them questions in the past
flying toaster is offline Find More Posts by flying toaster
Old Jul 24, 2012, 04:16 AM
Joined Apr 2010
Thanks for the advice, guys.
I swapped the non-responsive unit (motor, boom, etc.) with the one diagonally opposite.
The non-responsive one then worked after the swap, and the formerly good one stopped working.
I assume that it's either the ESC or a crook on-board connector (which looks fine to me), and I certainly am not competent at fixing either.
I emailed HH and told them that assume that I take it to Modelflight here in Adelaide for a replacement, as they are the HH importer, and am awaiting their response.
BTW, I have not even managed to flatten the first battery :-(
Thanks again - Chris
Old Jul 24, 2012, 07:44 AM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
your better off calling HH. I have not always had the best luck on emailing them. They take at least 48 hours and sometimes I never hear back. Just call them.
I finally got to take my new Mqx out to an open soccer field area so I had some nice space to fly and now it seems a lot more fun! I was able to really fly around and see what it can do. I even did a few flips frontwards and sideways. flipped easier then I thought. I tried the new Hyperion battery I got for it and definitely liked it better, but surprisingly its slightly smaller then the stock battery even though it has more mah and higher c rating. so its loose in the holder and totally slid out and came unhooked in one crash.
nickelbn1 is offline Find More Posts by nickelbn1
Old Jul 24, 2012, 08:32 AM
Thetis is offline
Find More Posts by Thetis
Always, against the wind
Thetis's Avatar
United States, IL
Joined Oct 2011
A little scotch tape or electrician's tape around the battery works perfect for me.
Thetis is offline Find More Posts by Thetis
Old Jul 24, 2012, 08:47 AM
TomQ is offline
Joined Mar 2012
I use a piece of thin duct tape to secure all of my batteries. I make sure the tape is covering all of the battery surface that is exposed between the two cross braces of the frame. Thick tape like Gorilla tape does not seal as close to the edges as thinner tape. I use each piece of tape about 25 times.
I have had thousands of high speed crashes and not had a battery shift more than a quarter of an inch.
Old Jul 24, 2012, 09:33 AM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Thanks i was thinking of doing something like that. Think i need a couple more batteries. Dont know if i want more hyperions or just get three cheap turnigy nano tech ones and wait a month to get them......hmmmmm
Old Jul 24, 2012, 11:59 AM
moombe is offline
Find More Posts by moombe
Belgique, Région Wallonne, Wavre
Joined Feb 2011
A bit of fun yesterday in the garden :
mQx (2 min 45 sec)
moombe is offline Find More Posts by moombe
Old Jul 24, 2012, 02:29 PM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
http://www.youtube.com/watch?v=qTyy_gFyQtc
Some. Nice. Flying.
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Old Jul 24, 2012, 04:31 PM
Ched is offline
Find More Posts by Ched
Shawnee, Kansas
Joined Oct 2005
Good job on the video and flying!
Ched is offline Find More Posts by Ched
Old Jul 24, 2012, 06:40 PM
micros is offline
Find More Posts by micros
Joined Mar 2012
I'm in Germany at the moment where your video is blocked because it "may" contain music that hasn't been granted rights by GEMA. Shame :-(
micros is offline Find More Posts by micros
Old Jul 24, 2012, 06:56 PM
Joined Apr 2010
Thanks, Nick, but it's expensive to be put on hold when you are calling from Australia
I emailed them with the results of my swapping out motors, and will just have to wait to hear from them.
Chris
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 12:21 PM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 01:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 08:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 04:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 04:25 PM
