Old Jul 22, 2012, 03:36 PM
fred_dot_u is offline
Find More Posts by fred_dot_u
Joined Apr 2008
Does the WLToys v929 work with a Spektrum DX6i radio?
fred_dot_u is offline Find More Posts by fred_dot_u
Old Jul 22, 2012, 04:04 PM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
No, only with a 9x.
You could change the pcb with a mqx pcb. This should work but would cost anpother $30-$40.
http://www.ebay.com/itm/360430285141...84.m1439.l2649
Then you could use your dx6i
mystman is offline Find More Posts by mystman
Old Jul 22, 2012, 04:10 PM
iamsuperbleeder is offline
Find More Posts by iamsuperbleeder
Licensed Lunatic
iamsuperbleeder's Avatar
United States, FL, Lake City
Joined Mar 2012
I hit a local parking beside a baseball field today. I love this little thing. It's so nice to just be able to toss it and my DX6i in the back seat of the truck and be flying in no time This thing has easily been the best RC purchase I have ever made!
I shot some flight video too, but my stupid self aimed the camera too low so most of the flight is out of the picture, lol. I need to get me a little 808 key chain cam and strap it to this little guy
iamsuperbleeder is offline Find More Posts by iamsuperbleeder
Old Jul 22, 2012, 04:14 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Originally Posted by Brandigan View Post
Try a WLToys v929 Beetle if you lose them regularly . It's an MQx in all but name, and it does flips. I have both and I find since I got the Beetle, my MQx is still waiting for me to play with it again, but I've nicked all its batteries for the v929. ...
For me, the main disadvantage of the v929 is that one can only apply so much rate on the ailleron or elevator before it automatically flips (not a problem if you are not into really high rates).
v929 parts are much less expensive, so one guess at a hybrid is to buy a v929 bnf (about US$40 shipped) and replace its board with an mQx board (and perhaps board mount). One can get an mQx board and mount for about US$40 several places on-line, so this "hybrid" that will run on a DSM2 radio will cost about US$80.
LATER: I am too slow. I just see now that somebody else above has already described this option.
There is also this thread that marries an mQx board with the smaller Walkera Ladybird booms,motors,props, etc. which is even smaller and less expensive (I just got the Walkera Ladybird booms,motors,props, etc. from Banggood for less than US$25):
http://www.rcgroups.com/forums/showthread.php?t=1647401 .
flying-llama is offline Find More Posts by flying-llama
Old Jul 22, 2012, 11:07 PM
ChrisLevo is offline
Find More Posts by ChrisLevo
Australia, SA, Adelaide
Joined Apr 2010
Will only do Fast Forward Flight - Help!
Folks,
2 day old MQX.
Bound it to my DX7 yesterday, and it hovered pretty well.
Today, the front-right white blade does not want to spin when it is on the ground, and if I give it any throttle it just goes into a quick FFF with the nose down.
Trying to make it stop by using a little reverse elevator just flips it on its back.
I have a spare MLP4DSM transmitter, so tried binding it to that, with the same result.
No trim on either transmitter.
Everything seems to be connected OK, and the motors are turning the cogs OK.
Help!
Chris
ChrisLevo is offline Find More Posts by ChrisLevo
Last edited by ChrisLevo; Jul 14, 2013 at 06:17 PM. Reason: Changed email notification
Old Jul 23, 2012, 12:20 AM
Joined Mar 2006
Originally Posted by ChrisLevo View Post
Folks,
2 day old MQX.
Only thing I can think to try: try flying it indoors at really low rates.
Indoors will block wind, hopefully be more level ground and keep the temperature more steady (can affect gyros).
Low rates: then when you do things like a little reverse elevator, it will be really just a little.
Sometimes when I fly outdoors at the end of daylight, my mQx starts acting erratic (not sure why).
But then when I try to fly it indoors later, it acts fine.
Old Jul 23, 2012, 12:58 AM
Joined Apr 2010
Thanks, mate.
Indoors with the MLP4DSM at the low rate, and no change.
Two days old, and I can't use it
Cheers,
Chris
Old Jul 23, 2012, 02:51 AM
flying toaster is online now
Find More Posts by flying toaster
aka beerassassin
flying toaster's Avatar
Joined Dec 2009
Thanks, mate.
Cheers,
Chris
you might want to try troubleshooting by swapping out the motor etc with the parts on the boom across from it (if it's CW then with CW, or CCW with CCW). see if you can narrow down the problem that way.
maybe contact Horizon Hobby about it
also, when the mqx is on the ground not all the blades will spin at the same rate. only when the blades are up to speed do they all spin together in harmony
I have experienced this multiple times as well. I want to understand why! lol
flying toaster is online now Find More Posts by flying toaster
Old Jul 23, 2012, 03:02 AM
FlyingMcCoy is online now
Find More Posts by FlyingMcCoy
Joined Mar 2010
Do you guys have some kind of plane finder beeper when flying full fpv? Man this tiny thing must be hard to locate if you crash it.
FlyingMcCoy is online now Find More Posts by FlyingMcCoy
Old Jul 23, 2012, 03:09 AM
Sixter is offline
Find More Posts by Sixter
Flying Models for 52 Years!
Sixter's Avatar
Georgia, United States
Joined Oct 2002
Check to see if your Battery has moved. Had a flip over on a Landing and afterwards mine was almost un Flyable. Found that the Battery had move out a little ways. Causing the CG and Lateral Balance to be off. This made rthe AS3X System go a little nuts.
Bobby
Sixter is offline Find More Posts by Sixter
Old Jul 23, 2012, 03:31 AM
Joined Mar 2006
My current guess: as the sun sets, the temperature changes (drops), especially outdoors, which confuses the gyros.
Old Jul 23, 2012, 11:27 AM
Thetis is offline
Find More Posts by Thetis
Always, against the wind
Thetis's Avatar
United States, IL
Joined Oct 2011
Yes, may be during the winter but not in the middle of the summer at least where I am.
Thetis is offline Find More Posts by Thetis
Old Jul 23, 2012, 01:48 PM
Joined Mar 2006
Where I am, it is not cold in the summer, but as the sun sets, the temperature does drop.
Yesterday, from 7pm to 9pm, the temperature dropped about 9 degrees F.
Old Jul 23, 2012, 01:53 PM
Thetis is offline
Thetis's Avatar
United States, IL
Joined Oct 2011
I do not fly after sunset in order to avoid tickets for " driving without lights".
Have a good one
Old Jul 23, 2012, 05:43 PM
Joined Apr 2010
Email sent yesterday.
The battery is also in the correct place, BTW.
It just refuses to do anything but immediate FFF, nose down
Chris
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
