Old Jul 13, 2012, 01:40 AM
flying toaster is offline
Find More Posts by flying toaster
aka beerassassin
flying toaster's Avatar
Joined Dec 2009
couldn't help myself
flying toaster is offline Find More Posts by flying toaster
Old Jul 13, 2012, 01:47 AM
scotsoft is offline
Find More Posts by scotsoft
Master Of My Universe
scotsoft's Avatar
Newcastle, UK
Joined Jul 2010
Please don't restrain yourself, that looks superb
I like the way you have painted the motor guards
You should be very pleased with yourself as this is one of the better canopies I have seen made for the mQX
cheers John.
scotsoft is offline Find More Posts by scotsoft
Old Jul 13, 2012, 02:33 AM
aka beerassassin
Joined Dec 2009
cheers John.
thank you for the kind words!
painting the motor guards is a good idea, I'm lazy though and just used electrical tape I made a quick stencil so I can cut new ones easily in the future
and I am very pleased with the new canopy! thank you Frank Lachmund and Topper for making and supplying IMO hands down the most beautiful canopy for the mqx!! you can't see it but there is actually orange pearl in the green paint. not my idea, but I'm glad Frank added it. nice subtle touch!
Old Jul 13, 2012, 07:41 AM
Jim_Marconnet is offline
Find More Posts by Jim_Marconnet
Fly long and land softly
Jim_Marconnet's Avatar
Madison, Alabama USA
Joined Oct 2005
Speaking of motor guards and visibility.... has anyone figured out a way to make light-weight, high-visibility "Nerfy" motor guards that perhaps give more ground clearance?
Perhaps take pieces of colorful swim noodles. Perhaps cut down the existing motor guards into just "spikes" that would stick into the swim noodle material?
Jim_Marconnet is offline Find More Posts by Jim_Marconnet
Old Jul 13, 2012, 09:43 AM
Thetis is offline
Find More Posts by Thetis
Always, against the wind
Thetis's Avatar
United States, IL
Joined Oct 2011
Check post #282
http://www.rcgroups.com/forums/showt...589171&page=19
Thetis is offline Find More Posts by Thetis
Old Jul 13, 2012, 04:13 PM
BlueHavoc is offline
Find More Posts by BlueHavoc
Flying mostly micro's
BlueHavoc's Avatar
United States, WV, Vienna
Joined Mar 2007
Originally Posted by 4x4rc View Post
AFAIC the major selling point of the mQX -- and the reason I agree with Blade's claim "the pilot's quadcopter". You can try out whatever you want knowing it will essentially shrug off any crash and you'll keep on flying (provided you stay over longish grass). Most of the bigger tris and quads are heavy and powerful enough to sustain some sort of major damage.
I've had the mQX since January, flown probably 250 packs since then, crashed various times, and the entire damage is two props (both broken when hitting the wall or floor indoors). Booms, shell, wires, motors, shafts - all original issue.
it is very forgiving,...:and fun!
BlueHavoc is offline Find More Posts by BlueHavoc
Old Jul 13, 2012, 08:13 PM
Blackanthem is offline
Find More Posts by Blackanthem
Blackanthem's Avatar
United States, TX, Houston
Joined Aug 2011
Having a blast with mine. I do however have one motor (back right) that the the main gear and pinion gear have a black.... stuff on them.... dirty.
None of the other motors (gears) are like that. When spinning the prop by hand, I can feel a "click". like there is a burr in the main gear. Weird.
Blackanthem is offline Find More Posts by Blackanthem
Old Jul 13, 2012, 09:26 PM
micros is offline
Find More Posts by micros
Joined Mar 2012
I've had this a few times. Try cleaning the cogs of the drive gear. Although the fit is tight, fine dirt can build up between the cogs. Avoid using something metal as it could damage the brass. I use one of those triangular wooden toothpicks. Also check the teeth of the white plastic gear.
Lastly, check the tracking of the plastic gear. It should track in a nice line parallel to the prop. If it undulates up and down, re-seat it with the propellor assembly, If that doesn't help you may find it's warped in which case the replacements are pretty cheap.
micros is offline Find More Posts by micros
Old Jul 14, 2012, 12:35 AM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Motor wire insulation hides wire break
Originally Posted by flying-llama View Post
So far, I have been reading about dying motors and shorting boom wires.
I have a more mundane problem. After several crashes, the electrical plug from one of my motors to the boom wire socket is coming loose.
I have tried bending the plug pins apart, which tightens the connection a little, but the plug still soon pulls apart from the socket.
Any suggestions on what to try next? I am thinking of adding a layer of solder to the plug pins.
Thanks.
So, I tried adding a layer of solder to the plug pins: sometimes the motor receives electricity, sometimes not.
Tired of this, I cut the boom wire motor pin socket off and solder the boom wire to the motor pins: still more sometimes connected, sometimes not.
Then I noticed that the white motor "wire" bended a bit too easily at one point: it turns out that the white plastic wire insulation is in one piece, but there is a break in the wire inside the insulation. The 2 ends of the break sometimes make contact and sometimes not.
My guess is the break came from that (right front) motor popping out of motor cover several times on crashes.
I cut the insulation at the break and solder the 2 ends of the break together: the mQx is finally running.
flying-llama is offline Find More Posts by flying-llama
Old Jul 14, 2012, 12:55 AM
gitit20 is offline
Find More Posts by gitit20
gitit20's Avatar
Joined May 2012
Tray a motor you may have a dead spot or the brushes are going out
gitit20 is offline Find More Posts by gitit20
Old Jul 14, 2012, 05:40 AM
aka beerassassin
Joined Dec 2009
true, although nature is not always as forgiving!
I had a close encounter with a very large owl the other night at my local dog park. I went up right after dusk to show a friend the LED kit in action. we were standing close to a large tree and I had been in the air for about 5 min, buzzing around and doing loops in the vicinity of the tree. suddenly out of the treetop a very large bird (what I decided later had to be an owl) comes swooping in after my mqx! the mqx looked like a tiny bug in comparison. I immediately started making evasive maneuvers and brought it down as quickly and close to me as possible. the owl had chased it for a couple seconds then flew back to the treetop. the whole thing happened very quickly
I know there are owls that live in my neighborhood, they are elusive but sometimes you hear them at night..
a close call, but it was pretty damn awesome!
Old Jul 14, 2012, 06:43 AM
raw89 is online now
Find More Posts by raw89
Rapidly aging user
raw89's Avatar
United States, PA, Lancaster
Joined May 2012
Gear cleaning
Just FYI - I use a stiff bristled artist brush about 1/2 in. dia. Just brush downward while slowly rotating the gears to clean both gears at same time. Only takes 2-3 min for whole craft.
Also...re: intermittent connection problems....I had one I traced to where the boom wire connects to the motor plug. Finally found it with a continuity checker. Must have been a bad solder joint. Stripped the black insulation, re-soldered, covered w/ glue, AOK since.
Hope this helps.....fly on......
raw89 is online now Find More Posts by raw89
Old Jul 14, 2012, 09:31 AM
buck009 is offline
Find More Posts by buck009
buck009's Avatar
Joined Jul 2012
I agree - the mQX seems fragile but because it's so light it seems to not sustain too much damage on crashes.
I've had mine about 2 months and few crashes but so far nothing broken - I know that will change
Can't say the same for my helis or planes, they have had various repairs.
Starting a build on a DVI F450 quad shortly and looking forward to it.
buck009 is offline Find More Posts by buck009
Old Jul 14, 2012, 04:46 PM
BlueHavoc's Avatar
Joined Mar 2007
That is freaking incredible! I've heard fellow pilots here talk of hummingbirds & dragonflies chasing & interacting with their quad but never a large bird of prey! It would have been something to witness that!
Old Jul 14, 2012, 10:59 PM
aka beerassassin
Joined Dec 2009
it was definitely my first encounter with a bird of prey lol
I do have a regular group of visitors at my park during the daytime though. usually a hummingbird comes over follows me around for a little while, also when I fly up high I usually become encircled by this group of smaller sized birds. my most common visitor however is this large black bug that is almost always right on my tail. I see it when I fly closer, but it appears to be following the mqx around the entire time. today a couple pigeons flew by and I saw one of them craning it's neck looking over lol
Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i nyaaah!! Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 11 Oct 06, 2011 11:21 AM
For Sale New Blade 400 RTF Will sell as BNF papower Aircraft - Electric - Helis (FS/W) 8 Aug 04, 2011 12:28 PM
Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X ABADGTP Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2011 07:22 PM
Sold Blade MCX2 Like New RTF or BNF tamiyafan1975 Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2011 03:39 PM
Sold Blade mCPX RTF or BNF (factory sealed new in box) PatternFlyer Aircraft - Electric - Helis (FS/W) 5 Mar 28, 2011 03:25 PM
