Between my tx and crashed aircraft
Joined Mar 2006
Besides cutting your own CF booms (mentioned earlier in this thread), yet another alternative is to use square aluminum tubing for the booms: Post 172 of this Helifreak "Quad Mods?" thread: http://www.helifreak.com/showthread....377068&page=18 |
Joined Apr 2008
Super Light Locator Beacon for mQx?
As I've lost one 'copter and lost and found a second, I'm always on the lookout for ways to find mine should it happen again. There's an expensive and excessively heavy (for mQx) solution on the market, but heavy doesn't work for this lightweight flyer.
Just yesterday, I learned of the Hone for iPhone4S, never lose your keys again. It's a key fob that you can find with the newer models of the iPhone4S and new iPad, but not the older versions and not an iPod of any sort. That puts me out of the loop, but plenty of people have the new stuff and I may yet find that route. The key fob is designed to be on your keys, but that's not to say it could be attached elsewhere. I sent a message to the inventor and was told that the weight could be reduced to 8g, perhaps slightly less with a smaller battery. That's still a bit heavier than I'd like, but it's impressively light. With a range of 150 feet (45m), one might consider it to be limited, but I would have found loss number two that much more quickly (same day) and not had a failed battery, and I might have found loss number one straight up. It's not like our 'copters have autopilots like the big boys, so they have to come down reasonably close. Losing one in a 150 foot tall tree might complicate things though. US$49 is a bit pricey for a flyer that costs slightly less than three times that, plus an 8g payload means no other accessories while flying. http://www.kickstarter.com/projects/...again?ref=live |
Joined Jun 2012
Originally Posted by Brandigan
This is a request for a link to a post in this thread. Someone listed all the different ways to do rolls, flips etc. with instructions on how to do the various types: when to cut/restart throttle, when to pitch/roll etc. Quote:
Joined Jun 2012
![]() Actually, I might try Zoandar's 'thread and CA glue' suggestion first, as I can always scrape all that off if needed. Aluminium tubing looks interesting, although on that mod that wiring he's used looks a fair few grams heavier.
Joined Jun 2012
Range is 600ft (183m) and the tags weigh only 5g If you removed the casing you'd probably shave another gram or two off. Worth considering on a heavier, more expensive Quad at least.http://www.loc8tor.com/uk/2-mini-homing-tags.html |
Joined Jan 2012
Joined Jul 2008
I have tried this motor from HK: http://www.hobbyking.com/hobbyking/s...dProduct=18751 and can confirm that it works. You have to replace the pinion.
It replaced a CW motor and is slightly more powerful than the original, but it flies as originally. |
Anybody seen/used this canopy yet? It comes with an LED set! If so, I'd like to see your paintjobs/designs...
http://www.ebay.com/itm/Blade-MQX-En...item3f1878e159 C |
![]() attempted a couple backflips in the dark!
alright here's a question for everyone. I need help!
today I decided to try replacing my cracked cf booms with the aluminum tubes from Lowes, an idea from this thread: http://www.helifreak.com/showthread....377068&page=18 the aluminum tubes are 6" and I cut them in half. at about 3" they are shorter than the cf booms, but since they are more difficult to fit in the frame they end up fitting snug anyways. 3 of my cf booms were cracked (except for the starboard side rear boom), so I replaced the 3 of them, running the wires out side the tubing next to the wires for my LED kit. I decided to try flying it with the 3 aluminum booms and the 1 good cf boom to see if the aluminum tubes are truly interchangeable in terms of performance. they feel more snug than the cf ones, which is a good sign. well I go to take off and to my dismay something odd is happening and I'm not sure if it's related to the aluminum booms. the majority of the power seems to go to the starboard side front motor (the one cf boom is on the starboard side rear). if I keep giving it power the mqx will literally flip over, making it unable to fly. has this happened to anyone before? it was flying completely fine before taking it apart, albeit wobbly because of the cracked booms... edit: here's a quick video showing the issue http://www.youtube.com/watch?v=RIQkz37c2Z0 |
| Thread Tools | |
| Sold BNF PZ J3 Cub, BNF PZ P-51D Mustang, Blade mSR RTF & DX6i | nyaaah!! | Aircraft - Electric - Micro & Indoor Airplanes | 11 | Oct 06, 2011 11:21 AM |
| For Sale New Blade 400 RTF Will sell as BNF | papower | Aircraft - Electric - Helis (FS/W) | 8 | Aug 04, 2011 12:28 PM |
| Sold ON HOLD....FS/WTT Like New (RTF) Heli-Max AXE CPv3 For Like New (BNF) Blade mCP X | ABADGTP | Aircraft - Electric - Helis (FS/W) | 0 | Jul 26, 2011 07:22 PM |
| Sold Blade MCX2 Like New RTF or BNF | tamiyafan1975 | Aircraft - Electric - Helis (FS/W) | 1 | Jul 14, 2011 03:39 PM |
| Sold Blade mCPX RTF or BNF (factory sealed new in box) | PatternFlyer | Aircraft - Electric - Helis (FS/W) | 5 | Mar 28, 2011 03:25 PM |
